Unable to See Serviio after Upgrade to 1.2
DrTom
Post Sat Mar 16, 2013 8:05 pm
I recently upgraded to Serviio 1.2 on my Windows Home Server. Now I can no longer see Serviio from my Samsung Blu Ray player. :( Is there something I should know?
slyguy42o
Post Mon Mar 18, 2013 2:35 pm
Re: Unable to See Serviio after Upgrade to 1.2
is the service running?
DrTom
Post Mon Mar 18, 2013 2:54 pm
slyguy42o wrote:is the service running?
Yes, it is. There were no errors in the Serviio log.
Post Mon Mar 18, 2013 3:35 pm
Does it bind to the right ip? viewtopic.php?f=5&t=1289
DrTom
Post Mon Mar 18, 2013 3:40 pm
zip wrote:Does it bind to the right ip? viewtopic.php?f=5&t=1289
I believe so. Here is a clip from the log:
[Device] Created UPnP Device with UUID: 26f23a08-b29c-32cb-9e8e-478dc9a82680, bound address: 192.168.0.100
That is the correct IP for my Home Server.
slyguy42o
Post Mon Mar 18, 2013 4:00 pm
are you able to see the server on other devices? or even through VLC?
DrTom
Post Mon Mar 18, 2013 4:03 pm
slyguy42o wrote:are you able to see the server on other devices? or even through VLC?
I don't use VLC but I am able to connect to my Home Server via Remote Desktop as well aa NET USE.
Post Mon Mar 18, 2013 4:29 pm
DrTom
Post Mon Mar 18, 2013 4:33 pm
zip wrote:post detailed log
2013-03-14 23:30:19,421 INFO [MediaServer] Serviio DLNA media streaming server v 1.2 (rev. 7f0f253cf67d+)
2013-03-14 23:30:19,421 INFO [MediaServer] Petr Nejedly 2009-2013
2013-03-14 23:30:19,421 INFO [MediaServer] http://www.serviio.org
2013-03-14 23:30:19,421 INFO [MediaServer] Java 1.6.0_23-Sun Microsystems Inc.
2013-03-14 23:30:19,421 INFO [MediaServer] OS Windows 2003 x86 5.2
2013-03-14 23:30:19,421 INFO [MediaServer] File encoding: windows-1252
2013-03-14 23:30:19,421 INFO [MediaServer] Headless mode enabled: true
2013-03-14 23:30:19,421 INFO [MediaServer] User: SYSTEM
2013-03-14 23:30:19,421 INFO [MediaServer] User home dir: C:\Documents and Settings\Default User
2013-03-14 23:30:19,421 INFO [MediaServer] Temp dir: C:\WINDOWS\TEMP\
2013-03-14 23:30:19,421 INFO [MediaServer] ------------------------------------------------------------------------
2013-03-14 23:30:20,468 INFO [WebServer] Socket buffer set to 65535 bytes
2013-03-14 23:30:20,468 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-03-14 23:30:20,640 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-03-14 23:30:20,640 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-03-14 23:30:20,703 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-03-14 23:30:42,765 INFO [MediaServer] ------------------------------------------------------------------------
2013-03-14 23:30:42,765 INFO [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2013-03-14 23:30:46,906 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2013-03-14 23:30:49,312 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2013-03-14 23:30:49,578 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2013-03-14 23:30:49,703 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2013-03-14 23:30:49,718 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2013-03-14 23:30:49,718 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2013-03-14 23:30:49,859 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2013-03-14 23:30:49,906 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2013-03-14 23:30:49,906 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2013-03-14 23:30:49,937 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2013-03-14 23:30:49,937 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2013-03-14 23:30:49,953 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2013-03-14 23:30:49,953 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2013-03-14 23:30:49,953 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2013-03-14 23:30:49,953 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2013-03-14 23:30:50,000 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2013-03-14 23:30:50,000 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2013-03-14 23:30:50,000 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2013-03-14 23:30:50,000 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2013-03-14 23:30:50,000 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2013-03-14 23:30:50,015 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2013-03-14 23:30:50,015 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2013-03-14 23:30:50,015 INFO [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2013-03-14 23:30:50,015 INFO [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2013-03-14 23:30:50,015 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2013-03-14 23:30:50,015 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2013-03-14 23:30:50,015 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2013-03-14 23:30:50,015 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2013-03-14 23:30:50,015 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2013-03-14 23:30:50,015 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2013-03-14 23:30:50,015 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2013-03-14 23:30:50,015 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2013-03-14 23:30:50,015 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2013-03-14 23:30:50,031 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2013-03-14 23:30:50,031 INFO [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2013-03-14 23:30:50,156 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2013-03-14 23:30:50,156 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2013-03-14 23:30:50,156 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2013-03-14 23:30:50,156 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2013-03-14 23:30:56,765 INFO [Device] Created UPnP Device with UUID: 26f23a08-b29c-32cb-9e8e-478dc9a82680, bound address: 192.168.0.100
2013-03-14 23:30:58,234 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2013-03-14 23:30:58,234 INFO [UpdateChecker] Checking if a new version is available
2013-03-14 23:30:58,296 INFO [PluginCompilerThread] Started looking for plugins
2013-03-14 23:31:03,015 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-03-14 23:31:03,796 INFO [WebServer] WebServer starting on port 8895
2013-03-14 23:31:03,921 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-03-14 23:31:03,921 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-03-14 23:31:03,921 INFO [EventDispatcher] Starting EventDispatcher
2013-03-14 23:31:03,953 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2013-03-14 23:31:03,968 INFO [RendererSearchSender] Searching for Renderer devices
2013-03-14 23:31:03,984 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (SiS191 1000/100/10 Ethernet Device) and address 192.168.0.100, timeout = 0
2013-03-14 23:31:13,156 INFO [PluginCompilerThread] Added Feed plugin YouTube (Youtube.groovy), version: 1
2013-03-14 23:31:30,609 INFO [FeedUpdaterThread] Started looking for information about online resources
2013-03-14 23:31:30,812 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-03-14 23:31:31,578 INFO [PlaylistMaintainerThread] Started looking playlist changes
2013-03-14 23:31:31,578 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-03-15 09:29:36,812 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2013-03-15 09:29:39,671 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2013-03-15 09:30:58,234 WARN [ServiioStatusService] Returning error code to the REST layer: Not Found (404) - The server has not found anything matching the request URI
2013-03-15 09:38:26,421 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2013-03-15 09:38:26,453 INFO [WebServer] WebServer shutting down
2013-03-15 09:38:41,656 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2013-03-15 09:38:41,656 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2013-03-15 09:38:41,703 INFO [EventDispatcher] Leaving EventDispatcher
2013-03-15 09:38:41,734 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2013-03-15 09:38:52,515 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-03-15 09:38:52,656 INFO [RendererSearchSender] Searching for Renderer devices
2013-03-15 09:38:52,593 INFO [EventDispatcher] Starting EventDispatcher
2013-03-15 09:38:52,671 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-03-15 09:38:52,656 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (SiS191 1000/100/10 Ethernet Device) and address 192.168.0.100, timeout = 0
2013-03-15 09:38:52,656 INFO [WebServer] WebServer starting on port 8895
2013-03-15 23:30:58,343 INFO [UpdateChecker] Checking if a new version is available
2013-03-16 23:31:28,342 INFO [UpdateChecker] Checking if a new version is available
2013-03-17 23:31:23,092 INFO [UpdateChecker] Checking if a new version is available
Post Mon Mar 18, 2013 5:21 pm
it's not detailed log
DrTom
Post Mon Mar 18, 2013 5:29 pm
zip wrote:it's not detailed log
Where do I get that?
Post Mon Mar 18, 2013 5:31 pm
click on the detailed log link
DrTom
Post Mon Mar 18, 2013 5:36 pm
zip wrote:click on the detailed log link
That option doesn't appear in the Windows Home Server console. Is there a back door somewhere?
slyguy42o
Post Mon Mar 18, 2013 5:37 pm
VLC is a free piece of software you can grab and install just to check and see if your serviio server is up functioning properly.
DrTom
Post Mon Mar 18, 2013 5:41 pm
One thing I did notice is that this is an eval copy of the Pro Version - which I did not ask for.
slyguy42o
Post Mon Mar 18, 2013 6:41 pm
every copy does that, they start out as pro for 15 days then drops down if you don't have a key... the only features that this affects is streaming outside of your network and using the web browser player.
Neither of which affect what you are using serviio for.
bjurran
Post Tue Mar 19, 2013 5:28 pm
DrTom, which version of WHS is this?
I just noticed problems after I installed 1.2 on my WHS 2003 today. Not able to find it from my Samsung TV.
I do know how to post a detailed log, however the file will be more than 40 MB in only a few minutes. Any way to filter it more?
bjurran
Post Tue Mar 19, 2013 5:44 pm
Found how to filter the log.
This is what I get now.
The ip .72 is the TV, and it worked fine until I installed 1.2
(63.86 KiB) Downloaded 260 times
DrTom
Post Tue Mar 19, 2013 5:49 pm
bjurran wrote:DrTom, which version of WHS is this?
Sad to say, I don't know. It just says "Windows Home Server Service Pack 2". I have removed Serviio and am reinstalling. It has installed v 0.6.1 and is rebuilding the database.
Post Tue Mar 19, 2013 6:05 pm
DEBUG [DeviceDescriptionRequestHandler] Device /192.168.1.72 does not have access to the server, returning 403
Here is your problem. Give the device access (right click on in on the Status tab). Make sure you're not using the old WHS plugin.
Users browsing this forum: No registered users and 61 guests
