LG BD660 Missing Folders
caprioles9000
Post Mon Mar 18, 2013 7:23 pm
Hello everyone. I have an LG Blue Disc Player LG BD660. I am using it with the latest serviio version 1.2. My computer is running windows 8 professional.
My problem is that i am missing files. I cannot see them on my LG player. I looked through the forum and saw a post with a similar problem:
viewtopic.php?f=12&t=4037
The thing is i ran AV Media Controller that wqas inidcated in the post above and browsed to the Serviio folders and under there also did not get the folders i should have seen.
So any suggestions?
Note: I have used the generic and LG Player profiles and both have not helped. BTW since my installation the light is always orange in Serviio it has never turned green! Could this be the issue?
Regards,
C
Post Mon Mar 18, 2013 7:33 pm
Re: LG BD660 Missing Folders
check your log if the files have been added
caprioles9000
Post Mon Mar 18, 2013 8:27 pm
Hi zip i went through the whole log (detailed log file) and no they do not appear in the log files....
Post Tue Mar 19, 2013 8:22 pm
Is there a message about the folder not being accessible? Check access rights on your folders and files.
Return to LG
