ability to add files from other shared folders to a playlist
Kraal
Post Wed Mar 20, 2013 10:52 pm
Currently it seems that playlists can only point to files in the same shared folder they are in. I.e. it is impossible to have a shared folder with only playlists which point to music files being in other shared folders.
For instance, given the following list of shared folders, Playlists in /volume1/Audio/Playlists cannot access files the two other shared folders :
/volume1/Audio/Artists
/volume1/Audio/Compilations
It would be great if you could remove this restriction. Note, having /volume1/Audio as shared folder is not what i want, I have other Audio files in subfolders I don't want to share via serviio.
Thanks in advance
Post Thu Mar 21, 2013 1:17 pm
Re: ability to add files from other shared folders to a play
I think this should work already. As long as the item in the playlist is in the library.
Kraal
Post Thu Mar 21, 2013 9:10 pm
Well, i moved back the files, changed the path and indeed it works...
My apologies !
wieri347
Post Fri Jan 31, 2014 7:01 pm
Would be a great feature though, if I could also put files in the playlist that aren't already in the library. This would mean I wouldn't have to scan all directories, just the playlist directory.
Return to Feature requests
