Temp folder placement
ialomia
Post Thu Mar 21, 2013 6:23 am
Changed the from c:\windows\temp to e:\temp, another disk and save the configure. When I reboot the system, the configure goes back to c:\windows\temp. How can I make the change permanent. It worked before I upgrade to 1.2.
Post Thu Mar 21, 2013 1:20 pm
Re: Temp folder placement
it's a bug, will be fixed in 1.2.1
ialomia
Post Fri Mar 29, 2013 3:23 am
Thanks. The latest released version 1.2.1 fixed the problem.
