Serviio Stuck on Same Folder
wulfrun
Post Thu Mar 21, 2013 6:44 pm
Problems began yesterday when playing long video files , the screen would suddenly go black and i'd get a Device Is Disconnected message.
Today every time i try to access Video , i can only access the files on the one sub folder that i was using yesterday. Its impossible to navigate out of this one sub folder. In all i've about 18 Folders in the video section , but i can't access any of them bar the one sub folder. Folders in the Music section can be accessed normally.
Serviio is still working ok on my Sony BD player.
System details : LG 32LD690------Serviio 1.0.1------Windows XP
Post Thu Mar 21, 2013 10:48 pm
Re: Serviio Stuck on Same Folder
maybe the LG caches something then, if it works on the Sony. Did you try to restart Serviio?
wulfrun
Post Thu Mar 21, 2013 11:29 pm
Thanks for replying , yes i've tried turning off both the PC and the TV , but with no change.
wulfrun
Post Fri Mar 22, 2013 10:24 pm
Upgrading to Serviio 1.2.1 didn't solve the problem , so i uninstalled and reinstalled , hopefully all ok now.
Return to LG
