mbil74
Post Sat Mar 23, 2013 8:19 am
hi.
i've just installed you app on my tablet and it looks great.
anyway, unfortunately, serviigo can't list folders with tons of files in (300+). i suppose the problem is connected to request timeout. could you increase that to 60 seconds or add a configuration parameter for that?
could you add director and full cast (as from serviio metadata) to movie detail page?
thanks
regards
Post Sat Mar 23, 2013 9:13 am
Is that 300± videos? I have tested 1000± audio and image, but possibly not video which do have more data.
Director and cast is not provided by default by Serviio for remote clients, so instead I have look up the data online. At the same time I also fetch high res posters and backdrops. However, this feature requires the ServiiGo donate key, have a look on Google Play to see the differences.
mbil74
Post Sat Mar 23, 2013 10:50 am
yes 300+ videos but I've got a bunch of folders with almost 1000 videos... :)
please remark that timeout and overall tramission speed might also be affected by wifi connection quality... (and mine is quite poor in the room I need serviigo to run)
i'm already considering buying full serviigo but I need to be sure it works where and when i need it to... ;)
thanks
regards
jsebright
Post Sat Mar 23, 2013 11:45 am
Re: Access Group Restrictions
will wrote:Hi, at the moment this only works when using traditional DLNA clients such as TVs, Serviio does not have the ability to identify remote clients (ServiiGo or MediaBrowser) and until it is added to Serviio there isn't anything I can do for ServiiGo.
@zip, cannot check bitbucket atm, is this scheduled for anytime soon?
Actually the group restrictions are working now. I think it's possibly because I left it overnight and perhaps Serviio did a re-scan...
So the outcome is that you've got to be careful and patient when setting it up, then wait (probably for a scan to finish) then it works as per setup.
Great solution!
Post Sat Mar 23, 2013 11:59 am
Ok I'll try to reproduce the problem and then fix it. I'm very busy atm so probably won't get a chance until later next week to make a new release.
mbil74
Post Sat Mar 23, 2013 11:30 pm
thanks.
it shouldn't be difficult to reproduce: just stuff 600 (or more) movies in a folder and try to browse there... the problem occurs here 99.999% ;)
regards
Post Sun Mar 24, 2013 12:00 pm
OK I've reproduced and fixed the problem (tested with 800 movies with full metadata descriptions etc...). I do not have access to fixed line broadband at the moment, and google play and bitbucket aren't playing nice with the rather weak 3G signal that I have so you will have to make do with dropbox for now. Download the apk from https://www.dropbox.com/s/elmewvu3059y7 ... er-fix.apk, make sure installing from unknown sources is enabled in the advanced/developer options on your device, then install this apk over your current version. When a new one is out on Goolg Play it will update automatically.
mbil74
Post Mon Mar 25, 2013 7:46 pm
hi
just tested with a 1757 items folder and it works fine...
problem seems to be solved ;)
thanks
regards
markusl67
Post Wed Mar 27, 2013 3:43 pm
I have a quick question and hope you can help. I have downloaded serviigo on my kindle fire, but am unable to login at all. I get the error message that "serviigo has crashed and a report has been sent".
I have a dynamic DNS set up and have port forwarding enabled for 23424 and have no issues accessing MediaBrowser.
Is there a limitation with Kindle Fire that I am unaware of?
Any help you can provide would be greatly appreciated!
Post Wed Mar 27, 2013 3:58 pm
From the crash reports it looks like you are using a very old version which most definitely won't work with newer versions of Serviio. Where did you download it from? There is a preview of the next version a few posts back, you could use that for now.
markusl67
Post Wed Mar 27, 2013 5:26 pm
Is this the link you are referencing?
https://bitbucket.org/willlunniss/servi%20...%20.2-PRE.apk
I attempted to access this link and get a 404 error on bitbucket. Do I need an account there to access?
Post Wed Mar 27, 2013 5:46 pm
Was 2 posts above your post.
Where did you get such an old version from?
markusl67
Post Wed Mar 27, 2013 6:19 pm
Here is the link where I found the old version:
http://android.brothersoft.com/serviigo-267628-download.html
Working on installing the newer version now! Thank you!
markusl67
Post Wed Mar 27, 2013 6:30 pm
That was the issue! Serviigo is working like a champ now! Thanks so much for your help!
Post Sun Mar 31, 2013 2:07 pm
FYI, I'll be out of the country for the next two weeks so probably won't be able to give any support until I'm back around the 15th ish. Once I'm back I'll be able to focus some real effort on the next version.
Xmantium
Post Sun Mar 31, 2013 4:56 pm
Emjoy your holidays.
Thanks for some great kick-ass apps!
Im sure you'll be using ServiiGo at a wifi hotspot on your holiday! :D
carda
Post Mon Apr 01, 2013 11:12 pm
Hi Guys,
I am having trouble playing back videos. If I don't select original, the playback doesn't work. I ideally would pick medium or low when over 4g. I am using MX Player.
I think I have included the right section of the log :)
2013-04-02 09:56:47,611 DEBUG [CDSRetrieveMediaServerResource] GET http://SERVER:23424/cds/resource/6282/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/LOW,serviigo?authToken=c531a849bf7d4903bf816197e9ed8cd2 HTTP/1.1
2013-04-02 09:56:47,612 DEBUG [CDSRetrieveMediaServerResource] Creating client with id 'x.x.x.x'
2013-04-02 09:56:47,612 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=x.x.x.x, Profile=ServiiGo'
2013-04-02 09:56:47,613 DEBUG [ResourceDeliveryProcessor] Request for resource 6282 and type 'MEDIA_ITEM' received
2013-04-02 09:56:47,613 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 6282 (local)
2013-04-02 09:56:47,613 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6282)
2013-04-02 09:56:47,617 DEBUG [VideoDAOImpl] Reading a Video (id = 6282)
2013-04-02 09:56:47,622 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 6282, format MPEG_TS_SD_KO_ISO and profile ServiiGo
2013-04-02 09:56:47,622 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file The Big Bang Theory - S06E02 - The Decoupling Fluctuation.mkv
2013-04-02 09:56:47,623 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file The Big Bang Theory - S06E02 - The Decoupling Fluctuation.mkv: MPEG_TS_SD_EU_ISO
2013-04-02 09:56:47,623 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file The Big Bang Theory - S06E02 - The Decoupling Fluctuation.mkv: MPEG_TS_SD_NA_ISO
2013-04-02 09:56:47,623 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file The Big Bang Theory - S06E02 - The Decoupling Fluctuation.mkv: MPEG_TS_SD_KO_ISO
2013-04-02 09:56:47,623 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 6282 (local)
2013-04-02 09:56:47,623 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6282)
2013-04-02 09:56:47,624 DEBUG [VideoDAOImpl] Reading a Video (id = 6282)
2013-04-02 09:56:47,629 DEBUG [VideoDeliveryEngine] Delivering item '6282' for client 'Identifier=x.x.x.x, Profile=ServiiGo'
2013-04-02 09:56:47,630 DEBUG [VideoDeliveryEngine] Delivering file 'The Big Bang Theory - S06E02 - The Decoupling Fluctuation.mkv' using transcoding
2013-04-02 09:56:47,630 DEBUG [AbstractTranscodingDeliveryEngine] No other client uses transcoding job of file 'transcoding-temp-6286-serviigo-LOW.stf', will stop the job
2013-04-02 09:56:47,630 DEBUG [AbstractTranscodingDeliveryEngine] Stopping previous transcoding job of file 'transcoding-temp-6286-serviigo-LOW.stf'
2013-04-02 09:56:47,632 DEBUG [TranscodingJobListener] Deleted temp file '/tmp/Serviio/transcoding-temp-6286-serviigo-LOW.stf': true
2013-04-02 09:56:47,632 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=x.x.x.x, Profile=ServiiGo'
2013-04-02 09:56:47,632 DEBUG [MediaItemDAOImpl] Getting file of media item 6282
2013-04-02 09:56:47,635 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: /MEDIA/The Big Bang Theory - S06E02 - The Decoupling Fluctuation.mkv
2013-04-02 09:56:47,636 DEBUG [ProcessExecutor] Starting ffmpeg -threads auto -i /MEDIA/The Big Bang Theory - S06E02 - The Decoupling Fluctuation.mkv -y -c:v mpeg2video -b:v 500k -maxrate:v 500k -bufsize:v 500k -vf scale=428:240 -r 24000/1001 -g 15 -c:a libmp3lame -b:a 192k -ar 22050 -ac 2 -map 0:0 -map 0:1 -sn -f mpegts /tmp/Serviio/transcoding-temp-6282-serviigo-LOW.stf
2013-04-02 09:56:47,724 DEBUG [FFmpegMetadataRetriever] File '/share/Multimedia/TV Shows/Real Time With Bill Maher/Real Time With Bill Maher - 2012-11-02 - November 2, 2012.mp4' has H264 profile HIGH, levels [{RF=2.2, H=3.1}] and 5 ref frames
2013-04-02 09:56:47,724 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve thumbnail for file: /share/Multimedia/TV Shows/Real Time With Bill Maher/Real Time With Bill Maher - 2012-11-02 - November 2, 2012.mp4
2013-04-02 09:56:47,725 DEBUG [ProcessExecutor] Starting ffmpeg -ss 120 -i /share/Multimedia/TV Shows/Real Time With Bill Maher/Real Time With Bill Maher - 2012-11-02 - November 2, 2012.mp4 -an -frames:v 1 -f image2 pipe:
2013-04-02 09:56:47,787 DEBUG [FFmpegMetadataRetriever] File 'rtmp://cp53909.edgefcs.net:1935/mp4:flash/playback/_definst_/haven_01_05.mp4 app=ondemand?auth=daEaccEcIcfbPb1dob5cBcEbbdQaCd0aYd.-brwHcN-8-lml_vGwoG&aifp=v001 playpath=mp4:flash/playback/_definst_/haven_01_05.mp4 swfUrl=http://www.abc.net.au/iview/images/iview.jpg swfVfy=1' has H264 profile HIGH, levels [{RF=2.2, H=3}] and 6 ref frames
2013-04-02 09:56:47,793 DEBUG [TechnicalMetadataCacheDecorator] Stored technical metadata for online item '32150' in the cache (online_technical_metadata), returning it
2013-04-02 09:56:47,794 DEBUG [OnlineLibraryManager] Thumbnail http://tviview.abc.net.au/thumbs/i/haven.jpg not in cache yet, loading it
2013-04-02 09:56:48,166 WARN  [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
Stream #0:1: Audio: mp3, 22050 Hz, 2 channels, s16, 192 kb/s (default)
Stream mapping:
Stream #0:0 -> #0:0 (h264 -> mpeg2video)
Stream #0:1 -> #0:1 (ac3 -> libmp3lame)
Error while opening decoder for input stream #0:0
2013-04-02 09:56:48,167 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2013-04-02 09:56:48,405 DEBUG [CoverImageService] Resizing and storing cover art image
2013-04-02 09:56:48,405 DEBUG [ImageUtils] Starting image resize, size = 19452 bytes
2013-04-02 09:56:48,460 DEBUG [ImageUtils] Returning resized image, size = 5182 bytes
2013-04-02 09:56:48,460 DEBUG [CoverImageService] Image successfully resized
2013-04-02 09:56:48,477 DEBUG [ThumbnailCacheDecorator] Stored entry in the cache (thumbnails), returning it
Below is the ffmpeg command that is run when selecting LOW. seems to have an issue settings threads to auto. If I remove the threads command, the ffmpeg works. So I assume of I set the transcoding threads to 1 or 2 instead of optimal it would work, but I would prefer not to do this. Any help?
EDIT: Can confirm that if I change the server variable for CPU cores to a number other than optimal it works.
sudo ffmpeg -threads auto -i /MEDIA/The\ Big\ Bang\ Theory\ -\ S06E02\ -\ The\ Decoupling\ Fluctuation.mkv -y -c:v mpeg2video -b:v 500k -maxrate:v 500k -bufsize:v 500k -vf scale=428:240 -r 24000/1001 -g 15 -c:a libmp3lame -b:a 192k -ar 22050 -ac 2 -map 0:0 -map 0:1 -sn -f mpegts /tmp/Serviio/transcoding-temp-6282-serviigo-LOW.stf
[sudo] password for paul:
  built on Apr  1 2013 00:44:57 with gcc 4.6.3
  configuration: --enable-static --disable-shared --bindir=/tmp/ffmpeg --disable-ffplay --disable-ffserver --enable-pthreads --disable-mmx --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libass --enable-nonfree --enable-version3 --enable-librtmp --pkg-config=pkg-config
  libavutil    51. 32. 0 / 51. 32. 0
  libavcodec   53. 42. 0 / 53. 42. 0
  libavformat  53. 24. 0 / 53. 24. 0
  libavfilter   2. 53. 0 /  2. 53. 0
  libpostproc  51.  2. 0 / 51.  2. 0
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/1001) -> 48.00 (48/1)
Input #0, matroska,webm, from '/MEDIA/The Big Bang Theory - S06E02 - The Decoupling Fluctuation.mkv':
  Duration: 00:21:30.08, start: 0.000000, bitrate: 3251 kb/s
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x720, SAR 1:1 DAR 16:9, 23.98 fps, 48 tbr, 1k tbn, 47.95 tbc
    Stream #0:1: Audio: ac3, 48000 Hz, 5.1(side), s16, 384 kb/s (default)
[buffer @ 0xad7f110] w:1280 h:720 pixfmt:yuv420p tb:1/1000000 sar:1/1 sws_param:
[scale @ 0xae3ffd0] w:1280 h:720 fmt:yuv420p -> w:428 h:240 fmt:yuv420p flags:0x4
[mpeg2video @ 0xad7e1f0] impossible bitrate constraints, this will fail
[NULL @ 0xad7d470] [Eval @ 0xbfbe4cb8] Undefined constant or missing '(' in 'auto'
[NULL @ 0xad7d470] Unable to parse option value "auto"
[NULL @ 0xad7d470] Error setting option threads to value auto.
Output #0, mpegts, to '/tmp/Serviio/transcoding-temp-6282-serviigo-LOW.stf':
    Stream #0:0(eng): Video: mpeg2video, yuv420p, 428x240 [SAR 320:321 DAR 16:9], q=2-31, 500 kb/s, 90k tbn, 23.98 tbc
Stream mapping:
Post Tue Apr 02, 2013 6:36 am
That version of ffmpeg looks quite old, can you get a newer one / build it from the latest source.
carda
Post Tue Apr 02, 2013 8:29 am
will wrote:That version of ffmpeg looks quite old, can you get a newer one / build it from the latest source.
Building 1.2 from source now. You give my feedback
EDIT: All good using 1.2. Thanks will
mbil74
Post Wed Apr 03, 2013 8:49 am
Hi.
How is plot rendered on details page?
Is that html or plain text? (I need to have some new line shown here and there but "\n" doesn't work... how about <br /> or else?)
Thanks! :)
