aspect ratio problem returned after update
johndriscoll
Post Sat Mar 23, 2013 2:29 pm
A whileback I posted for help on getting the aspect ratio correct on my panasonic viera TV. MP4 files were being stretched vertically to fill the screen. The forum sorted me out by adding some script to the panasonic profile. Now after updating the prog to latest addition the aspect ratio problem is back. Below is the part of the script that you asked me to modify with the added parts in red italics. I added this to the profile in the latest version.
Please help me get this working again.I re installed the original serviio and it works again.Do I even need the update? What are the differences please.
<!-- Transcode h264 videos with profile level > 4.1 to mpegts with ac3 audio -->
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" DAR="16:9" forceInheritance="true">
Post Sat Mar 23, 2013 3:49 pm
Re: aspect ratio problem returned after update
you can make the same change to the profile you're using. There are release notes for each of the releases, you can search for them on the web site.
johndriscoll
Post Sat Mar 23, 2013 9:29 pm
sorry that doesn't help much. I know I should be able to make the same changes to the new profile. That's the point of this post.I have tried this and it doesn''t work, see the profile scripts I posted. Also I can't find any release notes relevent to my problem. Do you have a link maybe?
Post Sun Mar 24, 2013 12:53 am
List of release notes: http://www.serviio.org/news/9-release-notes/
Not sure about the scripts - you posted them above, didn't you? Which profile are you using?
johndriscoll
Post Sun Mar 24, 2013 9:56 pm
this is the first line of the profile
<Profile id="viera2011a" name="Panasonic Viera G/GT/DT/UT/VT (2011/2012)" extendsProfileId="1">
thanks again
johndriscoll
Post Wed Mar 27, 2013 8:57 pm
Is Anybody Out There?
slyguy42o
Post Wed Mar 27, 2013 10:02 pm
is the profile the you edited the same as the one listed in the console for your device? might be detecting under a different profile in the new version
johndriscoll
Post Thu Mar 28, 2013 9:33 pm
yes its the one for my panasonic. The first line is posted above
johndriscoll
Post Thu Apr 04, 2013 6:42 pm
Are you all on holiday ? ;)
slyguy42o
Post Thu Apr 04, 2013 7:26 pm
could you post the entire profile section that you edited? it's tough to see if it got edited correctly with just the snip you posted.
johndriscoll
Post Mon Apr 08, 2013 8:51 pm
I had to re install serviio 1.21 again to get you the profile. However now when I try to run the console I get The Mesage "Cannot connect to serviio server, it does not seem to be running.......exiting"
This is a different problem from before so I am attatching the whole profile file. The one I am trying to use is "<Profile id="viera2011a" name="Panasonic Viera G/GT/DT/UT/VT (2011/2012)"
profiles.xml
(91.61 KiB) Downloaded 466 times
johndriscoll
Post Mon Apr 08, 2013 10:32 pm
here is the attatched profile that gave me the first problem, ie. no error message buy incorrect aspect ratio.
thanks again
profiles.xml
(91.84 KiB) Downloaded 439 times
johndriscoll
Post Wed Apr 10, 2013 7:26 pm
Don't want to see impatient but while I have got serviio 1.21 installed to investigate problem I can't stream properly. Only 1.1 works for me. :|
slyguy42o
Post Wed Apr 10, 2013 9:46 pm
I am far from an profile expert, but I would try adding the DAR setting to each "Video targetContainer" line under your profile, the file your playing may be using a different profile sub section to dictate it's transcoding settings.
johndriscoll
Post Thu Apr 11, 2013 8:55 pm
tried that but no difference
Post Thu Apr 11, 2013 11:00 pm
I added your lines to the profile - try this:
      <!-- Panasonic Viera G30, GT30, DT30, UT30 With avi (2011), xx50 (2012)  With AVI Support -->
      <Detection>
         <UPnPSearch>
            <FriendlyName>(VIERA (G|D|U)T?(3|5)0?.*)|(VIERA VT50.*)</FriendlyName>
            <Manufacturer>Panasonic</Manufacturer>
         </UPnPSearch>
      </Detection>
      <MediaFormatProfiles>
      </MediaFormatProfiles>
         <!-- remux VORBIS/FLAC/LPCM in MKV/MP4 to AC3 -->
         <Video targetContainer="mpegts" targetACodec="ac3" forceInheritance="true">
             <!-- Some models support DTS natively, so the folowing line can be removed for those -->
             <Matches container="matroska" vCodec="h264" aCodec="dca" /> <!-- ST50 supports DTS, remove this line -->
            <Matches container="mp4" vCodec="h264" aCodec="lpcm" />
            <Matches container="mp4" vCodec="h264" aCodec="aac" />
         <!-- Remux MPEG-TS with no transcoding -->
         <Video targetContainer="mpegts" forceInheritance="true">
         <!-- Remux WTV files to MPEG-PS with no transcoding -->
         <Video targetContainer="mpeg" forceInheritance="true">
            <Matches container="wtv" />
         <!-- unsupported codecs will be transcoded into mpeg-ts, mpeg2 video and ac3 audio -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" forceInheritance="true">
            <Matches container="mp4" vCodec="dvvideo" />
            <Matches container="mp4" vCodec="mpeg4" />
            <Matches container="mpeg" vCodec="mpeg1video" />
            <Matches container="matroska" vCodec="mpeg4" />
            <Matches container="asf" />
            <Matches container="flv" />
            <Matches container="ogg" />
            <Matches container="3gp" />
            <Matches container="rm" />
         <!-- unsupported audio will be transcoded into lpcm audio -->
         <Audio targetContainer="lpcm" forceInheritance="true">
            <Matches container="flac" />
            <Matches container="adts" />
         </Audio>
      <Subtitles>
         <SoftSubs mime-type="text/srt" />
         <HardSubs>
            <RequiredFor container="mp4" />
         </HardSubs>
      </Subtitles>
johndriscoll
Post Thu Apr 11, 2013 11:43 pm
ZIP you are a genius, it works! The profile looks quite a bit different from the original not just a few tweaks. Should it replace the panasonic profile in the update?
Can you help with another problem? I have a humax HDR FOX T2 which handles streaming better than my Panny. However it will not play any MKV files through serviio (message on screen says format not supported). Mezzmo will play these but I don't like the programme, it stutters to much when transcoding whereas serviio plays very smoothly.
Thanks again ZIP.
Post Fri Apr 12, 2013 10:32 pm
It's just 2 lines changed to the viera2011a profile from what is bundled with 1.2.1. For he other thing start a new thread of search for an existing one
Users browsing this forum: No registered users and 304 guests
