1.2.1 bugs with video
aleph
Post Mon Mar 25, 2013 5:36 am
upgraded from 1.2 snapshot to 1.2
1.2 blu-ray don't seed serviio at all
upgrade to 1.2.1
1.2.1 photo's work well at least jpg
didn't check music
problem with video: only top folders shown. when I enter folder that contains video files always receive error something like can't get access to media files or folder is empty.
rollback to 1.2 snapshot everything is fine.
Post Tue Mar 26, 2013 4:37 pm
Re: 1.2.1 bugs with video
can you post the log with the error message?
aleph
Post Wed Mar 27, 2013 7:05 am
player say "Cant get access to device. check the device and try again"
ps3 say "dlna protocol error 501"
log for player attached
photos: jpg and raw work fine, mp3 also work fine.
os win8 x64, java 1.7.0_17 64-bit
(25.07 KiB) Downloaded 484 times
Post Wed Mar 27, 2013 1:48 pm
did you try a clean install? It looks like your library is in inconsistent state, probably due to you having used the snapshot.
aleph
Post Wed Mar 27, 2013 6:38 pm
not yet.
aleph
Post Thu Mar 28, 2013 2:16 pm
thank you after clean install everything work fine.
