UA55ES7100 possible connection problem wont play files
PMGrasby
Post Sat Mar 16, 2013 2:40 am
I have a Samsung UA55ES7100 and have been using Servviio with limited success until now, when i go to sources in the Samsung TV the icon for serviio has changed from the yellow circle to a white rectangle with a question mark. I can still browse my folders but no files will play. Message says file not supported or something along those lines. In status on the serviio console there is a green light next to the Samsung TV but I think it has changed its IP address. However when I check the network status on the TV it has that same IP address for itself that Serviio does. Does this make any sense to anyone? Im not fantastic with computers, am I doing something wrong?
Thunder
Post Mon Mar 25, 2013 11:00 pm
Re: UA55ES7100 possible connection problem wont play files
I think you have the same problem as mine
viewtopic.php?f=10&t=2790
