Since 1.2.1 I cannot add some video files to folders
udontneedlightspeed
Post Tue Mar 26, 2013 1:45 pm
I have some video files *.wmv and *.mp4 which when I add to a folder and 'refresh' cannot be seen on my dlna clients. The folders can be seen but these files cannot, I tried adding them to existing folders but I have the same problem. When i check the log after hitting a refresh I see the same message repeated exactly the same amount of times as there are files being added:
2013-03-26 13:04:44,512 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video codec.
If I go back to 1.1 they add fine with no log errors, just the usual message about adding a file, and play with out issue (I use no transcoding and have the box ticked).
If I upgrade to back to 1.2.1 the files are still OK unless I remove and re-add them, then the error appears in the log and they are not seen in the folders by the clients.
The onlÿ common thing I can find with these files is that when I view them with vlc and view the codec information it descibes both the wmv and these mp4 files as "MPEG-4 Video (mp4v)
I would be grateful for any help with this problem.
Thanks for reading.
Post Tue Mar 26, 2013 4:24 pm
Re: Since 1.2.1 I cannot add some video files to folders
can you post ffmpeg -i of the video using ffmpeg in 1.1 and then ffmpeg in 1.2.1 ?
udontneedlightspeed
Post Tue Mar 26, 2013 5:01 pm
Thanks, here are the outputs from the ffmpeg's
1.1 output
C:\Users\peter\Desktop\serviio\serviio-1.1-win-setup (1)\$_OUTDIR\lib>ffmpeg -i
test.mp4
g-config
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'test.mp4':
major_brand : mp42
minor_version : 0
compatible_brands: mp42isom
track : 2
genre : Pop
album : Pop Party 11 [+video] [+digital booklet]
artist : One Direction
album_artist : Various artists
title : Video: Live While We're Young
Duration: 00:03:19.00, start: 0.000000, bitrate: 1374 kb/s
Stream #0:0(eng): Video: mpeg4 (Advanced Simple Profile) (mp4v / 0x7634706D)
, yuv420p, 640x480 [SAR 1:1 DAR 4:3], 1199 kb/s, 25 fps, 25 tbr, 1k tbn, 25 tbc
handler_name : Media Handler
Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, s16, 170
kb/s
1.2.1 output
C:\Users\peter\Desktop\serviio\serviio-1.2.1-win-setup\$_OUTDIR\lib>ffmpeg -i te
st.mp4
ffmpeg version 1.1.1 Copyright (c) 2000-2013 the FFmpeg developers
built on Feb 5 2013 21:59:54 with gcc 4.7.2 (GCC)
p --enable-fontconfig --enable-libfreetype --enable-zlib --extra-libs='-lrtmp -l
polarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-
runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-
mingw32- --pkg-config=pkg-config
libavutil 52. 13.100 / 52. 13.100
libavcodec 54. 86.100 / 54. 86.100
libavformat 54. 59.106 / 54. 59.106
libavdevice 54. 3.102 / 54. 3.102
libavfilter 3. 32.100 / 3. 32.100
libswscale 2. 1.103 / 2. 1.103
major_brand : mp42
minor_version : 0
creation_time : 2013-03-04 22:00:52
track : 2
genre : Pop
Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 17
0 kb/s
Post Tue Mar 26, 2013 6:57 pm
Fixed, thanks. It's due to the 'Video:' string in title metadata field. If you remove that (there must be some tool to do that without reencoding), the file should be added. Fix coming in a next release.
udontneedlightspeed
Post Tue Mar 26, 2013 7:30 pm
Thanks for the quick reply, can you just humour me for a moment.\
Maybe I am looking at this wrong as I am nearly 50 :(
When I look at the output from both ffmpeg versions the line that says:
"title : Video: Live While We're Young"
is the same in both?
Are you referring to a different part of the ouput?
Apologies if I have missed the point of your reply..........
Post Tue Mar 26, 2013 11:05 pm
There has been some change in the code around parsing FFmpeg output and this has been introduced as a bug.
udontneedlightspeed
Post Wed Mar 27, 2013 8:33 am
Thats great,
Thanks for the Clarification.
And thanks again for your help :D
Users browsing this forum: No registered users and 61 guests
