After Sleep, the server not run
ACE
Post Mon Mar 25, 2013 8:38 pm
If my computer going to sleep, after wake up, the serviio server not run, or not work.
That if I run "Stop serviio service" and "Start serviio service", the server is working fine.
Post Tue Mar 26, 2013 8:42 pm
Re: After Sleep, the server not run
Are you running Serviio 1.2.1 (the very latest). This version improved the recovery from sleep. What operating system are you using?
ACE
Post Tue Mar 26, 2013 10:09 pm
DenyAll wrote:Are you running Serviio 1.2.1 (the very latest). This version improved the recovery from sleep. What operating system are you using?
Yes I trying 1.2.1. I use Windows 7 SP1 64bit
Post Sun Apr 07, 2013 10:20 am
Hi - try this workaround from jammoblammo.
Return to General discussion
Users browsing this forum: Baidu [Spider] and 2 guests
