Old serviio issues and now new serviio issues
Tangerine
Post Mon Mar 25, 2013 8:13 pm
Hi
I was running serviio 0.6 on FreeBSD 9.1, aside from the limitations imposed by my TV it was working a treat, watched a movie last night with no issues. Today I wanted to stream something and was greeted by "playback not available". After trying the obvious restarting serviio and then the server neither of which solved the issues, I decided to update to 1.2 as this was now in the ports tree.
I can stream music with no problems but not a single video will play.
When starting serviio on the server I am getting after a few seconds
java.io.IOException: No such file or directory
at java.io.UnixFileSystem.createFileExclusively(Native Method)
at java.io.File.createNewFile(File.java:900)
at net.padlocksoftware.padlock.validator.history.FileHistory.setEarliestRun(FileHistory.java:79)
at net.padlocksoftware.padlock.validator.plugins.ExpiredPlugin.getFirstRun(ExpiredPlugin.java:170)
at net.padlocksoftware.padlock.validator.plugins.ExpiredPlugin.validate(ExpiredPlugin.java:76)
at net.padlocksoftware.padlock.validator.Validator.validate(Validator.java:343)
at net.padlocksoftware.padlock.validator.Validator.validate(Validator.java:298)
at org.serviio.licensing.LicenseValidator.validateLicense(LicenseValidator.java:105)
at org.serviio.licensing.LicenseValidator.validateBundledLicense(LicenseValidator.java:124)
at org.serviio.licensing.LicenseValidator.getCurrentLicense(LicenseValidator.java:74)
at org.serviio.licensing.LicensingManager.updateLicense(LicensingManager.java:128)
at org.serviio.licensing.LicensingManager.<init>(LicensingManager.java:103)
at org.serviio.licensing.LicensingManager.getInstance(LicensingManager.java:113)
at org.serviio.MediaServer.printLicenseInformation(MediaServer.java:262)
at org.serviio.MediaServer.main(MediaServer.java:115)
at net.padlocksoftware.padlock.validator.plugins.ExpiredPlugin.getTimeRemaining(ExpiredPlugin.java:133)
at net.padlocksoftware.padlock.validator.Validator.getTimeRemaining(Validator.java:367)
at org.serviio.licensing.LicenseValidator.validateLicense(LicenseValidator.java:106)
and the last few lines of the serviio.log file are
2013-03-25 20:12:08,161 DEBUG [RepositoryDAOImpl] Marking Repository 6 as scanned with current timestamp
2013-03-25 20:12:08,165 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 7)
2013-03-25 20:12:08,205 DEBUG [RepositoryDAOImpl] Marking Repository 7 as scanned with current timestamp
2013-03-25 20:12:24,611 WARN [prefs] Could not lock User prefs. Unix error code 2.
2013-03-25 20:12:24,611 WARN [prefs] Couldn't flush user prefs: java.util.prefs.BackingStoreException: Couldn't get file lock.
2013-03-25 20:12:53,449 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-03-25 20:12:53,449 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-03-25 20:12:54,612 WARN [prefs] Could not lock User prefs. Unix error code 2.
2013-03-25 20:12:54,612 WARN [prefs] Couldn't flush user prefs: java.util.prefs.BackingStoreException: Couldn't get file lock.
2013-03-25 20:13:05,756 DEBUG [WebServer] I/O error: Connection reset
Any clues would be much appreciated.
Post Mon Mar 25, 2013 9:06 pm
Re: Old serviio issues and now new serviio issues
Create a home directory for the user you run serviio under. Although that shouldn't affect playback, which is probably because Serviio now requires a recent version of ffmpeg which is probably newer than what you have, which version do you have?
Tangerine
Post Mon Mar 25, 2013 10:56 pm
Created a folder called dlna in /usr/home and I still get the exceptions when starting serviio.
I am pretty sure that the new port of serviio updated ffmpeg as well, it is showing from pkg_info as ffmpeg1-1.0.5 Realtime audio/video encoder/converter and streaming server
Serviio.log still shows
2013-03-25 22:56:17,898 WARN [prefs] Could not lock User prefs. Unix error code 2.
2013-03-25 22:56:17,898 WARN [prefs] Couldn't flush user prefs: java.util.prefs.BackingStoreException: Couldn't get file lock.
2013-03-25 22:56:46,756 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-03-25 22:56:46,756 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-03-25 22:56:47,899 WARN [prefs] Could not lock User prefs. Unix error code 2.
2013-03-25 22:56:47,899 WARN [prefs] Couldn't flush user prefs: java.util.prefs.BackingStoreException: Couldn't get file lock.
Post Tue Mar 26, 2013 12:52 am
does the process have write access to the home folder?
Tangerine
Post Tue Mar 26, 2013 7:46 am
I believe it does,
drwxr-xr-x 2 dlna dlna 512 Mar 25 22:53 dlna
it has the same perms and settings as other user folders
Post Tue Mar 26, 2013 1:33 pm
I'm not sure how that works in Linux, it you can just create a dlna folder under /home and it's automatically considered user's home dir, or if you have to create the user with a home dir initially.
The cause is the user running serviio has no writeable home dir.
Tangerine
Post Tue Mar 26, 2013 6:29 pm
Well the the user already exists as it is created by Serviio when its compiled. I am not that fussed about that error unless that is related somehow to the fact that Serviio will not play an video files.
The user running Serviio is 7660 dlna 47 20 0 887M 176M uwait 0 8:30 0.00% java
I have made sure that all the video files have been set to dlna:dlna just incase as if I copy something to the server it will go with me being the user and not dlna
Post Tue Mar 26, 2013 11:06 pm
what is your FFmpeg version?
Tangerine
Post Tue Mar 26, 2013 11:37 pm
ffmpeg1-1.0.5
Post Tue Mar 26, 2013 11:52 pm
post output of
ffmpeg -version
Tangerine
Post Wed Mar 27, 2013 10:25 am
Ok there seems to be two ffmpegs hanging about the system, now I cannot be 100% sure but I think I saw ffmpeg1 flash past when I was installing the port of serviio.
there was no actual ffmpeg on the system, but I have installed that now and its version is eris# ffmpeg -version
ffmpeg version 0.7.15, Copyright (c) 2000-2013 the FFmpeg developers
There is also eris# ffmpeg1 -version
ffmpeg version 1.0.5
The serviiod script points to ffmpeg1
JAVA_OPTS="-Djava.net.preferIPv4Stack=true -Djava.awt.headless=true -Dderby.system.home=/var/db/serviio -Dserviio.home=$SERVIIO_HOME -Dffmpeg.location=/usr/local/bin/ffmpeg1"
I have tried changing that to ffmpeg and restarting serviio, with either it will browse media fine but the TV always shows playback not available when trying to watch something, which is the same problem that serviio started giving before the upgrade.
Post Wed Mar 27, 2013 1:42 pm
0.7 is too old
the 1.0.5 looks weird. You should build ffmpeg from the sources, as described on the wiki
Tangerine
Post Sat Mar 30, 2013 10:46 pm
Tried following the wiki but it is more geared towards Linux and I did try but could not get the sources to build for that version of FFmpeg at all. But given the problem of "playback unavailable" had just started literally overnight, I did wonder if it was something else on the system causing the issue. So I have done a completely fresh install of FreeBSD and Serviio and the problem still exists the TV will browse media and will play MP3 but not any form of video file, when the system was working you would occasionally get a video file which would not play but the system would at least make an attempt, you would get a spinning wait icon in the corner of the screen, this error occurs the instant you press play.
Tangerine
Post Sat Mar 30, 2013 11:20 pm
I just tried Serviio for windows on Server 2008R2 and got the same results on the TV, which made me start to suspect it was not FFmpeg or BSD ... etc. I had a look for a firmware update for the Sony TV but I am on the latest version .... as a last result I did a factory reset of the system and it is now playing media again, so I am not sure what had happened to it or why it happened but it is now fixed. I guess should have considered that as an option earlier. Cheers for all the suggestion and help offered.
jshg46
Post Thu Jun 27, 2013 1:20 am
I am having this same exact problem on Freebsd 9.1 as we speak. The updated ports had a compile error in openjdk for me. I went to ports/java/openjdk6 and ran make install clean and it installed. I cannot find a way around these errors. When you compile serviio in ports why doesnt it have a prefs folder?
