humux hdr1000s doesnt suuport dts need help
eddie1
Post Thu Mar 28, 2013 7:19 pm
my hdr1000s will play any video codec but wont play dts audio can i change it to ac3 or something
can some nice person explain step to step and help with creating a profile i can use with my mkvs please im completely new to serviio so go easy please
slyguy42o
Post Thu Mar 28, 2013 7:24 pm
Re: humux hdr1000s doesnt suuport dts need help
what profile are you currently using for your device?
eddie1
Post Thu Mar 28, 2013 7:25 pm
wdtv live
slyguy42o
Post Thu Mar 28, 2013 7:41 pm
ok, you need to edit the wdtv profile to transcode DTS audio into AC3
open up profiles.xml in notepad (note you can find this in the config folder of your serviio install.
search for "wdtv" and find this section
<Matches container="wtv" />
<Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384">
<Matches container="flv" /> <!-- this is used by online content, assuming WDTV cannot play local flv either -->
<Matches container="rm" />
you need to add this to the profile.
<Audio targetContainer="ac3" forceInheritance="true">
<Matches container="adts" />
</Audio>
This should be the end result.
</Audio>
eddie1
Post Thu Mar 28, 2013 7:45 pm
thank you so much
Users browsing this forum: Google [Bot] and 12 guests
