Web UI in PHP - support thread
greenythebeast
Post Sat Mar 23, 2013 8:14 pm
Re: Web UI in PHP (revised)
Any update on 1.2 compatibility?
Bruno
Post Thu Mar 28, 2013 9:27 am
is there any svn or git repo where anyone can develop with?
I would like to take over a part of the further development, but it should not result in fragmentation or two developers do the same...
Xmantium
Post Thu Mar 28, 2013 8:05 pm
Bruno wrote:is there any svn or git repo where anyone can develop with?
https://github.com/mpemberton5/Web-UI-for-Serviio
PM Mark, love to see collaboration with skilled web devs on this, Mark done a fantastic taking over the project the original Web UI
Swoop
Post Fri Mar 29, 2013 10:30 am
Hi guys,
i already made some required amendments so that the transcoding tab works with version 1.21 again due to the changed API. That was really a pain in the ... :D What's also missing are the subtitle properties from the latest versions.
Not sure how I can hook in but I will send Mark a PM.
Cheers!
Post Fri Mar 29, 2013 10:39 am
The best way would be to fork the repo, commit your changes to your fork, and then create a pull request for Mark to merge them back into his. That way other users can clone your repo in the mean time. Depending on how much time Mark is going to have, he may be open to switching to a github organisation with write access given to a few users to help ensure it is kept upto date with changes to Serviio. I'm a member of a github organisation for a different open source project I contribute to and it works quite well.
There are a few more changes other than transcoding/subtitles, the bound ip field has been replaced, new remote settings, and the http status code is no longer in the response, you have to read it from the header.
Swoop
Post Fri Mar 29, 2013 12:59 pm
Ok, did a fork and send a pull request to Mark. I'm new to git but I think I'll get used to it :D
https://github.com/SwoopX/Web-UI-for-Serviio
I'll see if I can get more stuff to work but I'm not a web programmer but good at reverse engineering. Looks like a new challenge here. Btw, Ive read all the changes at the header but the transcoding fix was the most important one for me.
Swoop
Post Wed Apr 03, 2013 5:34 am
WebUI v1.4 available (requires Serviio v1.2 or above)!!
Swoop
Post Wed Apr 03, 2013 9:07 am
Made some small updates.
Mister XY
Post Wed Apr 03, 2013 9:40 am
Hello, i have downloaded this version from this site (https://github.com/SwoopX/Web-UI-for-Serviio) and get this Web-UI-for-Serviio-master.zip. And when i copy this (bevor, i have clear my cache and delete the old webui) and open this new webui and go to "Delivery". It hang. I use the german translation. Is this an error?
Under about (über) i have this version "Serviio v 1.2.1 - WebUI v 1.4beta"
Swoop
Post Wed Apr 03, 2013 11:12 am
Sorry, forgot to upload the code for the delivery tab. Updated the code, thanks for highlighting!
Wanna try again?
Mister XY
Post Wed Apr 03, 2013 11:41 am
Yes i want. Now it shows the menu.
mpemberton5
Post Tue Apr 16, 2013 2:55 am
Thanks to some awesome work by Swoop, WebUI is now fully compatible with 1.2 and above. I've updated the Wiki to reflect the latest code.
Who says open source isn't alive! Big cheers for Swoop!
Blessings to all,
Post Tue Apr 16, 2013 8:30 am
Way to go, guys!
Swoop
Post Tue Apr 16, 2013 9:04 am
Thanks Mark!
Will also try to maintain the code because I hate it if things don't work the way I want :D
However, I still know about two issues:
- New library entries can't be added after Pro Evaluation license has expired
- Renderers are not removed while being selected and the "remove" button has been pressed.
@zip: Are those valid restrictions?
Thanks!
Post Tue Apr 16, 2013 11:46 am
Swoop wrote:- New library entries can't be added after Pro Evaluation license has expired
There is no such restriction on the server side.
Looks like UI bug.
qoolbox
Post Tue Apr 16, 2013 2:01 pm
Just made the Thecus NAS module...
Backend Serviio 1.2.1 and front end php ui 1.4beta
apache 2.2 + PHP 5.3.19 + OracleJRE6
Serviio is well launch in process
but web interface keep tell me that the Serviio status is not launched (stay in red) even if i start it manually.
adding files in library failed once select and saved, nothing display in the list... (may be due that server is diplay as not launched)
I tried with Chrome and Firefox, same issue.
I will still propose the remote version to Thecus users, until this was fix :(
I will try to tweak with Apache 2.4.4, but i have no hope.
Third Party Thecus NAS Develloper
http://forum.thecus.com
http://www.tsuga.fr
qoolbox
Post Tue Apr 16, 2013 3:00 pm
All problem resolved on Thecus Module using Apache 2.4.4
:lol:
i didnt trust about it
http://www.tsuga.fr
mpemberton5
Post Tue Apr 16, 2013 3:17 pm
qoolbox wrote:All problem resolved on Thecus Module using Apache 2.4.4
:lol:
That's fantastic! Great work!
Xmantium
Post Fri Apr 19, 2013 10:52 pm
Thanks for the update Mark and Swoop! Working well.
I use ServiiDB alot, ive added alot more content to the database, was hoping this bug could be fixed in the web UI - https://github.com/mpemberton5/Web-UI-f ... o/issues/7
Theres been big changes to ServiiDB to make adding sources easier, all plugins are in catergories. The best internet sources are from custom Serviio plugins.
Ive done a mockup of what the new Serviio API can look like on Web UI rather than having a search, similar to ServiiDroid [Screenshot] and ServiiMetro [Screenshot] is doing with new API
Swoop
Post Mon May 06, 2013 10:14 am
Hi Xmantium,
I might give it a shot within the next days. As I personally don't use ServiiDB, I got exactly zero experience with that :oops:
Can you elaborate further on the bug you've described? Are the sources addedd automatically as RSS and you later need to edit it accordingly? Is maybe a category parameter somewhere to be found?
Thx
Swoop
