[SOLVED] bdp-s590 no longer showing up in 1.2.1
martialartsguy
Post Fri Mar 29, 2013 1:35 am
I had my bdp-s590 showing up fine in Serviio prior to the upgrade to 1.2.1
When it wouldn't play, I removed the profile, saved, unplugged the player (power & Ethernet), restarted Serviio service & console, restarted it, then plugged in the player. Now I've lost not only the profile, but now my Sony doesn't even show up at all.
slyguy42o
Post Fri Mar 29, 2013 1:59 am
Re: bdp-s590 no longer showing up in 1.2.1
what version were you running before you upgraded? also can you see your server with other devices?
martialartsguy
Post Fri Mar 29, 2013 2:03 am
I had 1.2 running until today.
I don't have any other items attached to the server except the Sony.
slyguy42o
Post Fri Mar 29, 2013 2:09 am
try VLC just to see if you can browse to your serviio instance and play a movie. from what you have said so far, I have a suspicion that it may not be running.
martialartsguy
Post Fri Mar 29, 2013 2:12 am
Not seeing it from VLC.
martialartsguy
Post Fri Mar 29, 2013 2:32 am
Uninstalled and reinstalled, but now I can't get anything to show up in the Renderer Profile.
slyguy42o
Post Fri Mar 29, 2013 2:51 am
ok so you got an installation issue... try removing and reinstalling java first.
martialartsguy
Post Fri Mar 29, 2013 3:16 am
Removed and reinstalled Java & restarted, but nothing is still showing in Renderer Profile.
slyguy42o
Post Fri Mar 29, 2013 3:41 am
can you post your logs?
martialartsguy
Post Fri Mar 29, 2013 3:48 am
Here it is.
(296.88 KiB) Downloaded 610 times
Post Fri Mar 29, 2013 8:00 am
- Cleanup the device list on serviio console.
- Cleanup the server list in Sony device network settings.
What is the IP address of your Sony device ? Did you fixed it or used a automatic DHCP server ?
martialartsguy
Post Fri Mar 29, 2013 2:31 pm
It's fixed at 10.*.*.8.
I ran network connections diagnostics on the Sony just to double check it, and it's still the same IP address.
Still not showing in Renderer. :(
martialartsguy
Post Fri Mar 29, 2013 2:53 pm
Sorry, it's DHCP at *.*.8
slyguy42o
Post Fri Mar 29, 2013 3:07 pm
from the logs it appears to be running, but the fact that you can't see it from VLC is an issue. Until you get it working from VLC you should ignore the TV part of your issue. Does the service show as running in the services console?
martialartsguy
Post Fri Mar 29, 2013 3:09 pm
Yeah, the service is running both in the Serviio console and when I go through Start menu and press "Start Serviio service".
slyguy42o
Post Fri Mar 29, 2013 3:13 pm
hmmm.. have you tried disabling your firewall yet?
martialartsguy
Post Fri Mar 29, 2013 3:14 pm
I'm also now able to use VLC to get to a shared film via Serviio.
martialartsguy
Post Fri Mar 29, 2013 3:15 pm
slyguy42o wrote:hmmm.. have you tried disabling your firewall yet?
Even with firewall disabled, the Sony doesn't show up in Serviio.
Post Fri Mar 29, 2013 4:59 pm
On router, do you try to fixe the Sony device IP address ?
martialartsguy
Post Fri Mar 29, 2013 5:15 pm
I have tried that as well. :(
Users browsing this forum: Google [Bot] and 27 guests
