[Solved] Samsung D and TS
Midyr
Post Thu Mar 28, 2013 6:37 pm
Hi there,
my serviio v 1.2.1 want play TS-Files.
TV: UE40D5700
ffmpeg version 0.10.3 Copyright (c) 2000-2012 the FFmpeg developers
  built on Jun  5 2012 11:36:20 with gcc 4.5.3
  configuration: --prefix=/usr --libdir=/usr/lib --shlibdir=/usr/lib --mandir=/usr/share/man --enable-shared --cc=i686-pc-linux-gnu-gcc --cxx=i686-pc-linux-gnu-g++ --ar=i686-pc-linux-gnu-ar --optflags='-march=pentium4 -O2 -pipe -fomit-frame-pointer' --extra-cflags='-march=pentium4 -O2 -pipe -fomit-frame-pointer' --extra-cxxflags='-O2 -march=i686 -pipe' --disable-static --enable-gpl --enable-version3 --enable-postproc --enable-avfilter --disable-stripping --disable-debug --disable-doc --disable-network --disable-vaapi --disable-vdpau --enable-gnutls --enable-libmp3lame --enable-libvo-aacenc --enable-libvorbis --enable-libxvid --disable-indev=v4l --disable-indev=v4l2 --disable-indev=jack --enable-x11grab --enable-libopenjpeg --disable-amd3dnow --disable-amd3dnowext --disable-altivec --disable-avx --disable-mmx --disable-mmx2 --disable-ssse3 --disable-vis --disable-neon --cpu=pentium4 --enable-hardcoded-tables
  libavutil      51. 35.100 / 51. 35.100
  libavcodec     53. 61.100 / 53. 61.100
  libavformat    53. 32.100 / 53. 32.100
  libavdevice    53.  4.100 / 53.  4.100
  libavfilter     2. 61.100 /  2. 61.100
  libswresample   0.  6.100 /  0.  6.100
[h264 @ 0x80734c0] non-existing PPS referenced
[h264 @ 0x80734c0] non-existing PPS 0 referenced
[h264 @ 0x80734c0] decode_slice_header error
[h264 @ 0x80734c0] no frame!
[h264 @ 0x80734c0] mmco: unref short failure
    Last message repeated 3 times
[h264 @ 0x80734c0] Increasing reorder buffer to 1
[h264 @ 0x80734c0] Increasing reorder buffer to 2
    Last message repeated 1 times
[mpegts @ 0x806baa0] max_analyze_duration 5000000 reached at 5024000
[mpegts @ 0x806baa0] decoding for stream 0 failed
[NULL @ 0x8072ca0] start time is not set in estimate_timings_from_pts
[mpegts @ 0x806baa0] PES packet size mismatch
Input #0, mpegts, from 'TheWalkinDead01.ts':
  Duration: 00:45:04.73, start: 22248.271644, bitrate: 10297 kb/s
  Program 120
  Program 121
  Program 122
  Program 124
    Stream #0:0[0x20](deu): Subtitle: dvb_teletext ([6][0][0][0] / 0x0006)
    Stream #0:1[0x1ff]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 50 fps, 50 tbr, 90k tbn, 50 tbc
    Stream #0:2[0x203](deu): Audio: ac3 ([6][0][0][0] / 0x0006), 48000 Hz, 5.1(side), s16, 384 kb/s (clean effects)
    Stream #0:3[0x204](eng): Audio: ac3 ([6][0][0][0] / 0x0006), 48000 Hz, stereo, s16, 384 kb/s (clean effects)
nuada series01 #
Any clue?
Thanks Midyr
slyguy42o
Post Thu Mar 28, 2013 7:28 pm
Re: Samsung D and TS
is this something that worked under a previous version? or is this a new issue?
Midyr
Post Thu Mar 28, 2013 8:21 pm
No, I had the same problem with a previous version.
Post Thu Mar 28, 2013 8:44 pm
Does it play using AllShare server?
Midyr
Post Fri Mar 29, 2013 10:37 am
you mean the tvmobili-server under linux?
No it does.
But it works with serviio with my tablet
I found another TS which works:
ffmpeg -i Gesetz\ der\ Rache.ts
[mpegts @ 0x806baa0] max_analyze_duration 5000000 reached at 5000000
Input #0, mpegts, from 'Gesetz der Rache.ts':
  Duration: 01:26:05.04, start: 1.400000, bitrate: 2913 kb/s
  Program 1
      service_name    : Service01
      service_provider: FFmpeg
    Stream #0:0[0x100]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p, 704x576 [SAR 1989:1100 DAR 221:100], 9000 kb/s, 25 fps, 25 tbr, 90k tbn, 50 tbc
    Stream #0:1[0x101]: Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, s16, 192 kb/s
Post Fri Mar 29, 2013 11:47 am
No it does.... Does it or doesn't it?
The file is played natively, so it's something in the encoding causing the file not being played by the TV.
Midyr
Post Fri Mar 29, 2013 1:23 pm
ups, it doesn't.... 8-)
It seem to be all TS from one Dreambox aren't played.
Is there a possibility to repair them or get it played on the tv?
slyguy42o
Post Fri Mar 29, 2013 2:47 pm
The video is mpeg2 which should stream, but the audio is funky.. I would try editing the profile to transcode the mp2 audio
Post Fri Mar 29, 2013 4:38 pm
Midyr wrote:ups, it doesn't.... 8-)
Try to remux them with TsMuxer or something.
Midyr
Post Fri Mar 29, 2013 9:14 pm
I use ffmpeg and "copy" for all streams and now I've TS which work on TV.
Here the command, if someone need it too:
ffmpeg -i <input> -c:v copy -c:a copy -c:s copy <outpu>
Midyr
