Transcode for mkv with too high ReFrames
Maliniak
Post Sat Mar 30, 2013 8:55 pm
As you all know some players have problems when playing files with higher than 4.1 profile or with too high level of ReFrames - video stutters - example below:
Unique ID                                : 230808226207599177178383155315190419820 (0xADA40C242327A9C191ECE673C6E2516C)
Complete name                            : I:\Terminator.Salvation.2009.Director's.Cut.720p.BluRay.DTS.x264-WiKi.mkv
File size                                : 6.56 GiB
Duration                                 : 1h 57mn
Overall bit rate                         : 7 991 Kbps
Encoded date                             : UTC 2009-10-30 12:34:01
Writing application                      : mkvmerge v2.9.7 ('Tenderness') built on Jul  1 2009 18:43:35
Writing library                          : libebml v0.7.7 + libmatroska v0.8.1
Format settings, ReFrames                : 10 frames
Duration                                 : 1h 57mn
Bit rate                                 : 6 481 Kbps
Height                                   : 534 pixels
Display aspect ratio                     : 2.40:1
Bits/(Pixel*Frame)                       : 0.395
Stream size                              : 5.19 GiB (79%)
Writing library                          : x264 core 68 r1179M 96e2229
Encoding settings                        : cabac=1 / ref=10 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=esa / subme=9 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=12 / nr=0 / decimate=1 / mbaff=0 / bframes=6 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=1 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=6481 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.90
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Mode                                     : 16
Codec ID                                 : A_DTS
Duration                                 : 1h 57mn
Bit rate                                 : 1 509 Kbps
Bit depth                                : 24 bits
Stream size                              : 1.24 GiB (19%)
Title                                    : DTS 5.1CH@1.5M
To fix it you must encode with lower ReFrames but it takes time. How about to fix it by transcoding? I'm using Viera G30 profile but it doesn't work as I would like it to. Video is still stuttering and it is transcoding as audio is transcoded (DD instead of DTS). PS3 Media Server has no problem with such files but I prefer Serviio :)
Post Sun Mar 31, 2013 10:42 am
Re: Transcode for mkv with too high ReFrames
You can set up the rule to transcode files with profile higher than 4.1. And set H264LevelCheck to FILE_ATTRIBUTES.
