TC-P50ST30 Not able to select Serviio
TheJawa
Post Sat Mar 30, 2013 11:33 pm
Every time that I try to use the DLNA Client for my Panny TV, I can't even select the Serviio server. It shows on the list but when I click it it cycles through the servers and ends back up on the top one. Serviio recognizes the Panny TV, and I'm using the Viera E/S/ST/VT (2011) profile.
Post Sun Mar 31, 2013 1:26 am
Re: TC-P50ST30 Not able to select Serviio
Not much help, but I have the same TV and use the same profile with no issues. You say it cycles through the servers. What other servers, and does it work with any of them?
TheJawa
Post Sun Mar 31, 2013 1:46 am
My girlfriend's computer and my computer are both listed on the DLNA list, and I can't select anything or even scroll to anything. It just moves straight to the top of the list.
slyguy42o
Post Sun Mar 31, 2013 4:19 am
sounds like a bug in the tv..check and see if the tv has the latest firm ware maybe? there should be a menu for you to check..
Return to Panasonic
