fedora18-samsung tv
adriaan
Post Sun Mar 31, 2013 1:30 pm
fedora18-samsung tv
For some time I try to get Serviio working, but so far without success.
I installed and launched the serviio server on my fedora18 system, adjusted two ports in the firewall. In the console I can see the IP-adress of my TV (samsung UE37ES6710). The device name is "unrecognized device", I chose the profile "Samsung TV/player C/D/E-series). Most of the time there is an orange dot.
I added some videos en music files to the library.
The TV shows the serviio server, but when I select the server there are no video or music files. All folders are empty.
I have tried this many times, I read many items on this forum, I googled on this subject, but I can't get it working.
I must be missing something. I hope someone can give me a clue to get me around this problem.
Adriaan
Post Sun Mar 31, 2013 1:48 pm
Re: fedora18-samsung tv
Which version of ffmpeg do you have installed / did you build it from source?
Post the output of
ffmpeg -version
adriaan
Post Sun Mar 31, 2013 2:59 pm
This is the output of ffmpeg -version:
$ ffmpeg -version
ffmpeg version 1.0.1
built on Dec 4 2012 08:14:17 with gcc 4.7.2 (GCC) 20121109 (Red Hat 4.7.2-8)
configuration: --prefix=/usr --bindir=/usr/bin --datadir=/usr/share/ffmpeg --incdir=/usr/include/ffmpeg --libdir=/usr/lib64 --mandir=/usr/share/man --arch=x86_64 --optflags='-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic' --enable-bzlib --disable-crystalhd --enable-frei0r --enable-gnutls --enable-libass --enable-libcdio --enable-libcelt --enable-libdc1394 --disable-indev=jack --enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-openal --enable-libopencv --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libv4l2 --enable-libvpx --enable-libx264 --enable-libxvid --enable-x11grab --enable-avfilter --enable-postproc --enable-pthreads --disable-static --enable-shared --enable-gpl --disable-debug --disable-stripping --shlibdir=/usr/lib64 --enable-runtime-cpudetect
libavutil 51. 73.101 / 51. 73.101
libavcodec 54. 59.100 / 54. 59.100
libavformat 54. 29.104 / 54. 29.104
libavdevice 54. 2.101 / 54. 2.101
libavfilter 3. 17.100 / 3. 17.100
libswscale 2. 1.101 / 2. 1.101
I did not build it from source, I installed the rpm.
Adriaan
Post Sun Mar 31, 2013 9:44 pm
looks good. Check the log to see if any files have been added. if not, check your access rights (or those of the user running serviio)
Users browsing this forum: Baidu [Spider] and 40 guests
