Subtitles will not show up
Bobbysercy
Post Mon Apr 01, 2013 8:44 pm
I have a Sony BDP-S590 player that will play any file type that I have tried so far if I use the Sony Bravia TV (2012) - US profile. But while i use this profile a .mkv video i was watching and several other .mkv files subtitles will not show up. If i switch to Sony BDP-Sx90 (2012) profile i can play the same .mkv files and i can turn the subtitles on and off from the remote but there are several other files that i have that will not play under this profile. I was wondering if there was anything i could do to maybe fix the Bravia profile to play my subtitles like the Sx90 profile since the Bravia profile works the best. Thanks for any help.
patters
Post Wed Apr 03, 2013 10:03 pm
Re: Subtitles will not show up
Can you post "ffmpeg -i" details of those videos that won't play when you use the BDP profile?
http://wiki.serviio.org/doku.php?id=file_np
Bobbysercy
Post Thu Apr 04, 2013 4:16 pm
Thanks for the reply. Here are a few that would not play, I have others but I believe they have the same problems as these. If you need i can get the info for the files that have subtitles. Thanks
C:\Program Files\Serviio\lib>ffmpeg.exe -i C:\Users\Dustin\Desktop\a.avi
ffmpeg version 1.1.1 Copyright (c) 2000-2013 the FFmpeg developers
built on Feb 5 2013 21:59:54 with gcc 4.7.2 (GCC)
p --enable-fontconfig --enable-libfreetype --enable-zlib --extra-libs='-lrtmp -l
polarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-
runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-
mingw32- --pkg-config=pkg-config
libavutil 52. 13.100 / 52. 13.100
libavcodec 54. 86.100 / 54. 86.100
libavformat 54. 59.106 / 54. 59.106
libavdevice 54. 3.102 / 54. 3.102
libavfilter 3. 32.100 / 3. 32.100
libswscale 2. 1.103 / 2. 1.103
Input #0, avi, from 'C:\Users\Dustin\Desktop\a.avi':
encoder : MediaCoder 0.6
Duration: 00:43:13.92, start: 0.000000, bitrate: 510 kb/s
Stream #0:0: Video: h264 (High) (h264 / 0x34363268), yuv420p, 640x480 [SAR 1
:1 DAR 4:3], 29.97 fps, 29.97 tbr, 29.97 tbn, 59.94 tbc
Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 24000 Hz, stereo, s16p, 16 kb/s
C:\Program Files\Serviio\lib>ffmpeg.exe -i C:\Users\Dustin\Desktop\b.mkv
Input #0, matroska,webm, from 'C:\Users\Dustin\Desktop\b.mkv':
creation_time : 2007-02-05 14:28:52
Duration: 00:24:12.12, start: 0.000000, bitrate: 1528 kb/s
Stream #0:0: Video: h264 (High) (H264 / 0x34363248), yuv420p, 704x396 [SAR 1
:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
Stream #0:1(eng): Audio: vorbis, 48000 Hz, stereo, fltp (default)
Stream #0:2(eng): Audio: vorbis, 48000 Hz, stereo, fltp
Stream #0:3(jpn): Audio: vorbis, 48000 Hz, stereo, fltp
Stream #0:4(eng): Subtitle: ssa (default)
C:\Program Files\Serviio\lib>ffmpeg.exe -i C:\Users\Dustin\Desktop\c.mkv
Input #0, matroska,webm, from 'C:\Users\Dustin\Desktop\c.mkv':
creation_time : 2007-01-30 04:33:31
Duration: 00:22:59.75, start: 0.000000, bitrate: 1428 kb/s
Chapter #0.0: start 0.000000, end 90.400000
title : Chapter 1
Chapter #0.1: start 90.400000, end 532.334000
title : Chapter 2
Chapter #0.2: start 532.334000, end 1299.801000
title : Chapter 3
Chapter #0.3: start 1299.801000, end 1359.334000
title : Chapter 4
Chapter #0.4: start 1359.334000, end 1379.754000
title : Chapter 5
Stream #0:0(eng): Audio: aac, 48000 Hz, stereo, fltp (default)
title : Audio
Stream #0:1(jpn): Audio: aac, 48000 Hz, stereo, fltp
title : Audio
Stream #0:2(eng): Subtitle: subrip (default)
title : Subtitles
Stream #0:3(jpn): Video: h264 (High), yuv420p, 720x480, SAR 8:9 DAR 4:3, 29.
97 fps, 29.97 tbr, 1k tbn, 59.94 tbc (default)
title : Video
Bobbysercy
Post Sun Apr 21, 2013 1:38 am
please reply
Post Sun Apr 21, 2013 7:30 am
Bobbysercy wrote:C:\Program Files\Serviio\lib>ffmpeg.exe -i C:\Users\Dustin\Desktop\a.avi
AVI/h264/mp3 not supported by Sony BDP, should be transcoded
Bobbysercy wrote:C:\Program Files\Serviio\lib>ffmpeg.exe -i C:\Users\Dustin\Desktop\b.mkv
MKV/h264/vorbis/ssa : Vorbis Audio not supported, so should be transcoded to AC3 and remuxed with h264 video over mpegts.
Bobbysercy wrote:C:\Program Files\Serviio\lib>ffmpeg.exe -i C:\Users\Dustin\Desktop\c.mkv
MKV/h264/aac, the video track of this mkv file is not in first position, I'm not sure Sony BDP support that, you have to remux track with mkvtoolnix tool.
When MKV with subtitles are delivered in native format, Sony BDPmay support it.
When remuxed or transcoded, depends on serviio console settings, subtitles may be burned in video stream.
