Reusage of cached transcoded video stream
bobosan
Post Mon Apr 01, 2013 6:49 pm
Hello, I have installed Serviio as a service on Synology DS413j. Unfortunatelly, DS413j is not powerfull enough to transcode streams in a real-time. However, I have noticed that the transcoded files are stored in /volume1/@tmp directory as files with .stf extension). After some time the file is ready and I can view the selected stream on my TV without any lag. Unfortunatelly, these files disaapear (probable after restart, or after specific timeout). Then I cannot view the original file and have to wait again for the result of transcoding.
I have question if it is possible to persist .stf files and use them to view the selected movies several times for a specific period of time (e.g. 1 month) without transcoding?
Is there any configuration available? How these files matches with original files?
Any tip is more than welcome.
Post Mon Apr 01, 2013 10:34 pm
Re: Reusage of cached transcoded video stream
this file will be removed when you restart Serviio and/or when you play other file that needs transcoding. There is no way to keep them longer.
Users browsing this forum: Baidu [Spider] and 25 guests
