serviio Transcoding Error
kevin.trivedi
Post Mon Apr 01, 2013 2:04 pm
I have added below URL in serviio,
URL : http://wms10.iviplanet.com/alfa
rtsp://guateservicios.info/shoutcast/radioamor
in DNLA Master Profile.
But some times serviio is getting crash and returns
2013-04-01 00:29:46,851 WARN [ProcessExecutor] Process /usr/bin/ffmpeg has a return code of 1! This is a possible error.
2013-04-01 02:30:54,489 WARN [ProcessExecutor] Process /usr/bin/ffmpeg has a return code of 1! This is a possible error.
2013-04-01 02:31:19,901 WARN [ProcessExecutor] Process /usr/bin/ffmpeg has a return code of 1! This is a possible error.
2013-04-01 02:31:45,367 WARN [ProcessExecutor] Process /usr/bin/ffmpeg has a return code of 1! This is a possible error.
There are other streaming urls also in Serviio DB. can you tell me why i am facing above error?
Can you look into it ASAP, i have attached the log file
serviio (copy).log
(79.62 KiB) Downloaded 428 times
Post Mon Apr 01, 2013 10:43 pm
Re: serviio Transcoding Error
First, it looks like your access rights for /opt/serviio/library/ are not right (cannot write).
Second, you are using version 1.1, which is no longer supported here. Upgrade to 1.2.1 and if you're still having problems, post the new log here
kevin.trivedi
Post Fri Apr 05, 2013 5:44 am
Can you provide me the steps to upgrade the serviio???, because there are lots of online media streaming urls already saved into the Serviio DB.
As i dont want to lose them and add all those urls again.
Post Fri Apr 05, 2013 10:41 pm
Look at the download page.
kevin.trivedi
Post Mon Apr 08, 2013 2:57 pm
I had upgraded the serviio and still Facing the same issue. It hangs while transcoding and none of the radio streaming working after it.
I need to restart the serviio again.. :(
Can you please check the log and update me back, we are facing this issue regularly
(410.22 KiB) Downloaded 468 times
Post Mon Apr 08, 2013 3:16 pm
kevin.trivedi wrote:I had upgraded the serviio ...
Did you upgrade the ffmpeg too with proper library options ?
kevin.trivedi
Post Tue Apr 09, 2013 6:24 am
Below is the ffmpeg version and enabled options, is newer version avalaible??
ffmpeg version 0.10.2 Copyright (c) 2000-2012 the FFmpeg developers
built on Mar 20 2012 04:34:50 with gcc 4.4.6 20110731 (Red Hat 4.4.6-3)
configuration: --prefix=/usr --libdir=/usr/lib64 --shlibdir=/usr/lib64 --mandir=/usr/share/man --enable-shared --enable-runtime-cpudetect --enable-gpl --enable-version3 --enable-postproc --enable-avfilter --enable-pthreads --enable-x11grab --enable-vdpau --disable-avisynth --enable-frei0r --enable-libopencv --enable-libdc1394 --enable-libdirac --enable-libgsm --enable-libmp3lame --enable-libnut --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --extra-cflags='-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic -fPIC' --disable-stripping
libavutil 51. 35.100 / 51. 35.100
libavcodec 53. 61.100 / 53. 61.100
libavformat 53. 32.100 / 53. 32.100
libavdevice 53. 4.100 / 53. 4.100
libavfilter 2. 61.100 / 2. 61.100
libswresample 0. 6.100 / 0. 6.100
Post Tue Apr 09, 2013 12:46 pm
Yes, they are now on 1.2 and beyond.
Users browsing this forum: No registered users and 303 guests
