Can not play .ts files
SaschaE76
Post Mon Apr 01, 2013 10:47 pm
i have a Sony KDL 55 ex 725 and serviio 1.2.1 running on a Mac Mini.
when i record Movies on my VU+ Solo2, i get .ts files.
but i can not play this files on my TV!
the files are shown on the menu, but when i play, is is only a blank screen.
Thank you!
Post Tue Apr 02, 2013 7:02 am
Re: Can not play .ts files
Could you provide information about your Solo recorded file (see my signature links) ?
Could you read this topic, I think that could solved your problem : viewtopic.php?f=11&t=9690#p66298
SaschaE76
Post Tue Apr 02, 2013 7:05 pm
Hi Illico
Illico wrote:Could you read this topic, I think that could solved your problem : viewtopic.php?f=11&t=9690#p66298
Sorry, it does not work.
Illico wrote:Could you provide information about your Solo recorded file (see my signature links) ?
yes...
ffmpeg version 1.1.1 Copyright (c) 2000-2013 the FFmpeg developers
built on Jan 29 2013 00:10:12 with gcc 4.0.1 (GCC) (Apple Inc. build 5493)
configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-libmp3lame --enable-librtmp --enable-libfreetype --enable-fontconfig --enable-libass --enable-pthreads --disable-mmx --extra-ldflags=-L/Users/MacAdmin/Desktop/build/target/lib --extra-cflags=-I/Users/MacAdmin/Desktop/build/target/include --extra-libs='-lpolarssl -lfreetype -lexpat -liconv'
libavutil 52. 13.100 / 52. 13.100
libavcodec 54. 86.100 / 54. 86.100
libavformat 54. 59.106 / 54. 59.106
libavdevice 54. 3.102 / 54. 3.102
libavfilter 3. 32.100 / 3. 32.100
libswscale 2. 1.103 / 2. 1.103
[h264 @ 0x1258000] non-existing PPS referenced
[h264 @ 0x1258000] non-existing PPS 0 referenced
[h264 @ 0x1258000] decode_slice_header error
[h264 @ 0x1258000] no frame!
[h264 @ 0x1258000] mmco: unref short failure
Last message repeated 5 times
[mpegts @ 0x1251a00] max_analyze_duration 5000000 reached at 5024000
[NULL @ 0x1257c00] start time is not set in estimate_timings_from_pts
[mpegts @ 0x1251a00] PES packet size mismatch
Last message repeated 1 times
Input #0, mpegts, from '/Volumes/Daten HDD/Movies/Bad Teacher.ts':
Duration: 01:28:10.05, start: 6688.146544, bitrate: 10732 kb/s
Program 105
Program 106
Program 107
Stream #0:0[0x20](deu): Subtitle: dvb_teletext ([6][0][0][0] / 0x0006)
Stream #0:1[0x2ff]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 25 fps, 50 tbr, 90k tbn, 50 tbc
Stream #0:2[0x303](deu): Audio: ac3 ([6][0][0][0] / 0x0006), 48000 Hz, 5.1(side), fltp, 384 kb/s (clean effects)
Stream #0:3[0x304](eng): Audio: ac3 ([6][0][0][0] / 0x0006), 48000 Hz, stereo, fltp, 384 kb/s (clean effects)
Program 108
Program 242
Program 3997
Program 3998
Program 4017
Program 4028
Program 4035
