Serviio 1.2.1 and CBS plugin isn't working..
headputty
Post Mon Apr 01, 2013 11:19 pm
I upgraded to 1.2.1 yesterday. The CBS plugin isn't working anymore . Before the upgrade all my shows from CBS were working well with the plugin. Stack trace below....
013-04-01 19:01:43,742 INFO [PlaylistMaintainerThread] Started looking playlist changes
2013-04-01 19:05:19,755 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Unexpected error while invoking plugin (CBS.com): index is out of range 0..-1 (index = 0)
at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:58)
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:171)
Caused by: java.lang.IndexOutOfBoundsException: index is out of range 0..-1 (index = 0)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.getAt(DefaultGroovyMethods.java:6202)
at org.codehaus.groovy.runtime.dgm$310.invoke(Unknown Source)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite$PojoMetaMethodSiteNoUnwrapNoCoerce.invoke(PojoMetaMethodSite.java:271)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite.call(PojoMetaMethodSite.java:53)
at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:108)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116)
at CBS.extractItems(CBS.groovy:53)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:32)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:29)
at org.serviio.library.online.PluginExecutionProcessor$1.call(PluginExecutionProcessor.java:50)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
2013-04-01 19:05:20,182 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
DrJay
Post Tue Apr 02, 2013 1:47 pm
Re: Serviio 1.2.1 and CBS plugin isn't working..
I don't think it is Serviio 1.2.1 that is the problem. I haven't upgraded to 1.2.1 yet and I noticed the CBS plugin stopped working this morning with version 1.2.0 and it had been working fine last week. My guess is CBS did something and the groovy isn't working anymore. Hope this gets fixed soon.
headputty
Post Wed Apr 03, 2013 8:27 pm
That's correct. I went back to 1.2 and still had the issue. Looks like something changed on CBS.
Post Thu Apr 04, 2013 7:23 am
Post on CBS plugin forum section.
Users browsing this forum: Baidu [Spider] and 44 guests
