Subtitle does not work
newnews
Post Mon Apr 01, 2013 5:13 pm
I installed Serviio on Win8. My asus o!play can find it and play the video normally. However, I am not able to get subtitle to work. The file name is like test.avi, test.eng.srt, test.chi.srt. They are playing fine on PC itself. What is the problem? The asus player can play subtitles if I use KooRaRoo.
slyguy42o
Post Mon Apr 01, 2013 5:16 pm
Re: Subtitle does not work
in your serviio console, under the Delivery tab then subtitles.. what options do you have selected for subs?
newnews
Post Mon Apr 01, 2013 6:38 pm
I have Enable Subtitle checked. All others are blank
slyguy42o
Post Mon Apr 01, 2013 7:00 pm
try enabling the burned in subtitle option to see if that helps.
newnews
Post Tue Apr 02, 2013 3:44 pm
Hi, It is the same. I guess the subtitle only works if I enable transcoding?
Post Tue Apr 02, 2013 4:23 pm
no. What is your OS?
newnews
Post Wed Apr 03, 2013 5:44 am
zip wrote:no. What is your OS?
I have windows 8 pro 64-bit.
Post Wed Apr 03, 2013 4:26 pm
did you select preferred language?
Return to General discussion
