Panasonic 65GT50 Sound Problem
brent01
Post Fri Mar 29, 2013 5:10 am
HI guys - I am streaming movies to my Panasonic 65GT50. The video is fine, however the sound is not great using the TV speakers. I have connected the digital audio output to my A/V receiver using a digital audio cable and digital audio to RCA converter. When I connect to Serviio and browse through my movies, the preview starts playing the movie and the sound works fine on my receiver. When I select the movie to play, the video is fine, however I do not get any sound.
I am using "Panasonic Viera G/GT/DT/UT/VT (2011/2012)" profile, and I tried changing the </Audio> transcoding from lpcm to ac3 and mp3 and still get no sound. Any suggestions would be greatly appreciated in how to resolve this issue.
Thank you.
slyguy42o
Post Fri Mar 29, 2013 2:57 pm
Re: Panasonic 65GT50 Sound Problem
maybe try swapping out the digital audio cable for just a set of RCA's using the analog outputs on your TV to your receiver just to see if it's an issue with the digital output?
brent01
Post Fri Mar 29, 2013 11:39 pm
My tv does not have analog (RCA) audio output. I changed to the generic profile and now sound works on some of the movies that didn't work previously, but still see the same effect on other movies. Not sure why this is happening. I thought the idea of transcoding was to change the audio format if the device was not capable of processing the format. I guess I have need to spend more time trying to figure this out.
slyguy42o
Post Sat Mar 30, 2013 12:41 am
the generic profile does not transcode anything.. so the formats that are playing under that profile are natively supported by your device. for the ones that aren't playing under the generic profile, you will need to dig into the formats and adjust your transocding profile accordingly.
do an ffmpeg -i in the file to dump the details of what video and audio codecs are being used.
brent01
Post Thu Apr 04, 2013 4:10 am
I am still having problems with getting an optimum profile for my Pansonic 65GT50. Here are the formats that the TV supports based on the specifications.
AVCHD 3D / Progressive, SD-VIDEO / MotionJPEG
(Lumix) / MKV / MP4 / MOV / M4v / FLV / 3GPP / VRO
/ VOB / TS / PS, MP3 / AAC / FLAC, JPEG / MPO
I started with the Panasonic Viera G/GT/DT/UT/VT (2011/2012) profile, however I assume I should switch to Panasonic Viera E/S/ST/VT (2011) since this profile uses the updated (2011/2012) profile and transcodes AVI files which is needed.
Since the TV does not support AC3, I went through the video section and changed all the AC3 references to MP3, however things are still not optimal as some video files are freezing and still not getting video on all files.
Any suggestions on how I can obtain an optimized profile? Here is a file that does not play audio, however the AC3 format should be transcoded to MP3 based on my profile attached.
Unique ID : 178177052205700337618863241775839653488 (0x860BA6EB14E3FEFD96659227783B2E70)
Complete name : D:\Another.Cinderella.Story.2008.1080p.BluRay.x264-Japhson\japhson-acs.mkv
Format : Matroska
Format version : Version 1
File size : 7.95 GiB
Duration : 1h 31mn
Overall bit rate : 12.4 Mbps
Encoded date : UTC 2009-02-10 11:31:05
Writing application : mkvmerge v2.0.2 ('You're My Flame') built on Feb 21 2007 23:40:55
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 31mn
Bit rate : 11.7 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.236
Stream size : 7.38 GiB (93%)
Writing library : x264 core 66 r1093M 1df50b9
Encoding settings : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=7 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=11739 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 1h 31mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 421 MiB (5%)
Language : English
Default : Yes
Forced : No
profiles_test.txt
(91.79 KiB) Downloaded 887 times
brent01
Post Mon Apr 08, 2013 1:13 pm
I am still having setup issues. My mkv files that have DTS audio are fine. The mkv files that have AC3 audio are causing me problems. I have tried changing profiles.xml to to transcode AC3 audio to AAC, DCA or DTS, however these formats do not seem to allow transcoding. Is there something else that needs to be added to allow AC3 audio to be transformed to one of these formats?
Post Mon Apr 08, 2013 2:06 pm
I think you are missing the bit where it matches the source mkv file with AC3 audio... try the following (in the Viera 2011/12 profile):
<Video targetContainer="mpegts" targetACodec="mp3" forceInheritance="true">
    <!-- Some models support DTS natively, so the folowing line can be removed for those -->
   <Matches container="matroska" vCodec="h264" aCodec="dca" /> <!-- ST50 supports DTS, remove this line -->
   <Matches container="matroska" vCodec="h264" aCodec="ac3" />  <!-- ADD THIS LINE -->
   <Matches container="mp4" vCodec="h264" aCodec="lpcm" />
   <Matches container="mp4" vCodec="h264" aCodec="aac" />
   <Matches container="mp4" vCodec="h264" aCodec="ac3" />  <!-- ADD THIS LINE -->
ps. you may also be able to remove the other two mp4 lines in the above (ie. not the one I added), as it looks like your TV supports this natively.
brent01
Post Tue Apr 09, 2013 5:13 am
Won't that transcode to mp3 audio format that will lose audio channels and only leave stereo format that has only 2 channels of audio? Left and right?
Post Tue Apr 09, 2013 8:32 am
Errr... yes, but that what I thought you were trying to achieve :? .
As I understand it your TV wont support AC3, hence you need to transcode the audio to another format (you had already written the transcoding bit, I was just giving you the bits to match where the source file uses AC3 audio). You could try setting the targetACodec="aac" now that you are matching the files containing ac3, but I've never done that so not sure whether it will transcode all the channels (or whether the m2ts container will support it). I'll try it later tonight.
brent01
Post Thu Apr 11, 2013 2:15 pm
I had the ac3 format match in my profile previously and this did not help.
jim79
Post Thu Jan 16, 2014 1:15 am
Did you find a solution? I have the same problem. The only way i have sound is to disable my home theater sound and to enable sound from tv directly. But it works correctly with the preview on menus.
P.S. Sorry for my english.
Return to Panasonic
