Can't save renderer profiles & Transcoding settings
wtrdk
Post Thu Apr 04, 2013 7:59 am
I'm a satisfied Serviio user, I love this piece of software. The only thing is that I can't save the settings for the render profiles. After every attempt to save the profile in the webinterface it resets itself to 'Generic DLNA Profile'.
This also happens with the Transcoding options. When I enable transcoding, move away from the tab and return, transcoding is disabled again.
All the other settings are saved perfectly.
I'm running Serviio on Ubuntu Server 12.10. Is it a permission problem for the config files? If so, can anyone help me to get the permissions right?
Thanks in advance!
Post Thu Apr 04, 2013 9:17 am
Re: Can't save renderer profiles & Transcoding settings
wtrdk wrote:The only thing is that I can't save the settings for the render profiles. After every attempt to save the profile in the webinterface it resets itself to 'Generic DLNA Profile'.
WebInterface ?
Do you mean a Third-party tools integration (Web UI in PHP...) ? Post on this forum section for support.
Post Thu Apr 04, 2013 12:21 pm
And there was a bug in 1.2 regrding saving transcoding settings, it's been fixed in 1.2.1. Your problem might sill be due to the web interface being out-ofdate
wtrdk
Post Fri Apr 05, 2013 7:26 pm
I'm sorry for posting in the wrong section!
I'll try to look for an answer/solution in the other section.
Thanks anyway!
