problems with vlc
siriusblack
Post Thu Apr 04, 2013 5:08 pm
problems with vlc
HI
just wondering have anyone come across this problem
every time I try to check something on vlc I get a message saying cant open mrl
I've checked my firewall and everything seems ok
do anyone know any solution please
thanks appreciated
Beta Tester
slyguy42o
Post Thu Apr 04, 2013 5:52 pm
Re: problems with vlc
In VLC.. click on tools and select messages
then change the drop down to debug and try it again.
Post your resulting logs here
siriusblack
Post Thu Apr 04, 2013 6:07 pm
THANKS
Here is the attachment
vlc debug.log
vlc Debug
(3.54 KiB) Downloaded 683 times
Beta Tester
siriusblack
Post Thu Apr 04, 2013 6:28 pm
Sorry last post did wrong
new attachment
vlc debug.log
Vlc debug log
(7.71 KiB) Downloaded 689 times
thanks again
Beta Tester
slyguy42o
Post Thu Apr 04, 2013 6:34 pm
so what do you mean by "check on something" are you getting an error when opening VLC? I assumed you meant that when you tried to stream off serviio you were getting an error.
siriusblack
Post Thu Apr 04, 2013 6:42 pm
on serviio my live feeds + RSS feeds work
however when I try to test the rss feeds which I know works
don't when I open them on vlc
none of them work so I found one to check which I know should work
but still don't
when I try to open vlc I get a message saying Cant open the mrl
thanks
Beta Tester
slyguy42o
Post Thu Apr 04, 2013 7:22 pm
is your media browser functional? are you able to test them via the web interface?
siriusblack
Post Thu Apr 04, 2013 7:29 pm
sorry don't understand
do you mean test it on internet search box ?
Beta Tester
siriusblack
Post Thu Apr 04, 2013 7:31 pm
Just tried it on internet search box don't work m8
Beta Tester
slyguy42o
Post Thu Apr 04, 2013 9:17 pm
open this URL on your serviio server
http://localhost:23424/mediabrowser/
use the embedded player to see if you can get the videos to work that aren't playing via VLC
siriusblack
Post Fri Apr 05, 2013 7:57 am
I opened the link you sent me put my password in
Then where do I try the links out please
Sorry dont mean to be think but can't see anywhere
To put it
Beta Tester
slyguy42o
Post Fri Apr 05, 2013 2:49 pm
you should be able to see your library once you login, so you are not seeing any items listed in the media browser?
siriusblack
Post Fri Apr 05, 2013 2:51 pm
in my media I get my live streams and my rss files
Beta Tester
slyguy42o
Post Fri Apr 05, 2013 2:59 pm
post detailed server logs please
viewtopic.php?f=5&t=7
siriusblack
Post Fri Apr 05, 2013 3:16 pm
sorry m8
I've read the link, gone to log4j in serviio, changed it says its to big
trying to figure it out
can you please help
do appreciate everything your doing for me
thanks
Beta Tester
siriusblack
Post Fri Apr 05, 2013 3:43 pm
I think this is it hopefully
log4j.xml
(1.75 KiB) Downloaded 796 times
Beta Tester
slyguy42o
Post Fri Apr 05, 2013 3:57 pm
the file we want to see is called serviio.log
siriusblack
Post Fri Apr 05, 2013 4:42 pm
ive been checking for serviio log
log4j serviio log.txt
(2.22 KiB) Downloaded 591 times
I hope this can help
this is the vlc debug
vlc debug.log
(13.7 KiB) Downloaded 665 times
hope this could help to
Beta Tester
slyguy42o
Post Fri Apr 05, 2013 5:17 pm
what is the URL of the feed that is not working?
siriusblack
Post Fri Apr 05, 2013 5:35 pm
here are some which don't work
http://vlchelper.com/turn_off_subtitles.mp4
vlc vlc.log
(3.81 KiB) Downloaded 572 times
https://sites.google.com/site/serviiors ... N_News.rss
vlc news.log
(5.66 KiB) Downloaded 560 times
https://sites.google.com/site/serviiors ... annels.rss
vlc hd.log
(13.86 KiB) Downloaded 474 times
Beta Tester
Return to General discussion
