subtitle working with external sub but not for embedded sub
thenamelessthing
Post Thu Apr 04, 2013 2:59 am
Hi, I can play mkv with external subtitle but embedded doesn't work.
Anybody can give me help on this?
Here is one of the files who doesn't show embedded subtitle:
media@mediastation:/opt/serviio/serviio-1.x/log$ ffmpeg -i /data/Teleseries/Revolution/Saison\ 01/Revolution.2012.S01E11.720p.HDTV.X264-DIMENSION\ VOST.mkv
ffmpeg version git-2013-03-04-393dcbf Copyright (c) 2000-2013 the FFmpeg developers
built on Mar 5 2013 20:54:39 with gcc 4.6 (Ubuntu/Linaro 4.6.3-1ubuntu5)
configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-libvpx --enable-librtmp --enable-libxvid --enable-libass --enable-libfreetype --enable-fontconfig
libavutil 52. 17.103 / 52. 17.103
libavcodec 54. 92.100 / 54. 92.100
libavformat 54. 63.102 / 54. 63.102
libavdevice 54. 3.103 / 54. 3.103
libavfilter 3. 41.100 / 3. 41.100
libswscale 2. 2.100 / 2. 2.100
libpostproc 52. 2.100 / 52. 2.100
Input #0, matroska,webm, from '/data/Teleseries/Revolution/Saison 01/Revolution.2012.S01E11.720p.HDTV.X264-DIMENSION VOST.mkv':
creation_time : 2013-04-04 02:05:19
Duration: 00:42:12.94, start: 0.000000, bitrate: 4152 kb/s
Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x720, SAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
Stream #0:1: Audio: ac3, 48000 Hz, 5.1(side), fltp, 384 kb/s (default)
Stream #0:2(fre): Subtitle: subrip (default)
Here is the log about this file when I try to play the file with subtitle:
2013-04-03 22:28:20,587 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-03 22:28:20,588 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
2013-04-03 22:28:20,588 DEBUG [ResourceDeliveryProcessor] Request for resource 7278 and type 'MEDIA_ITEM' received
2013-04-03 22:28:20,588 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 7278 (local)
2013-04-03 22:28:20,588 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7278)
2013-04-03 22:28:20,588 DEBUG [VideoDAOImpl] Reading a Video (id = 7278)
2013-04-03 22:28:20,589 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 7278, format MATROSKA and profile Panasonic Viera E/S/ST/VT (2011)
2013-04-03 22:28:20,589 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 7278 (local)
2013-04-03 22:28:20,589 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7278)
2013-04-03 22:28:20,589 DEBUG [VideoDAOImpl] Reading a Video (id = 7278)
2013-04-03 22:28:20,590 DEBUG [VideoDeliveryEngine] Delivering item '7278' for client 'Identifier=192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
2013-04-03 22:28:20,590 DEBUG [VideoDeliveryEngine] Delivering file 'Revolution.2012.S01E11.720p.HDTV.X264-DIMENSION VOST.mkv' in native format
2013-04-03 22:28:20,590 DEBUG [MediaItemDAOImpl] Getting file of media item 7278
2013-04-03 22:28:20,590 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 7278) as read
2013-04-03 22:28:20,594 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-04-03 22:28:20,594 DEBUG [GETMethodProcessor] Stream entity has length: 27959
2013-04-03 22:28:20,594 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-matroska,Content-Length: 27959,Date: Thu, 04 Apr 2013 02:28:20 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.2,Cache-control: no-cache,Content-Range: bytes 1314739552-1314767510/1314767511,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-04-03 22:28:20,600 DEBUG [WebServer] I/O error: Broken pipe
2013-04-03 22:28:20,607 DEBUG [WebServer] Incoming connection from /192.168.1.134:41977
2013-04-03 22:28:20,608 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-03 22:28:20,608 DEBUG [ResourceTransportRequestHandler] GET /resource/7278/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.1, headers = [User-Agent: Panasonic,Accept: */*,Range: bytes=5635-,Connection: close,Host: 192.168.1.3:8895]]
2013-04-03 22:28:20,609 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-03 22:28:20,609 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
2013-04-03 22:28:20,609 DEBUG [ResourceDeliveryProcessor] Request for resource 7278 and type 'MEDIA_ITEM' received
2013-04-03 22:28:20,609 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 7278 (local)
2013-04-03 22:28:20,609 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7278)
2013-04-03 22:28:20,609 DEBUG [VideoDAOImpl] Reading a Video (id = 7278)
2013-04-03 22:28:20,610 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 7278, format MATROSKA and profile Panasonic Viera E/S/ST/VT (2011)
2013-04-03 22:28:20,610 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 7278 (local)
2013-04-03 22:28:20,610 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7278)
2013-04-03 22:28:20,610 DEBUG [VideoDAOImpl] Reading a Video (id = 7278)
2013-04-03 22:28:20,611 DEBUG [VideoDeliveryEngine] Delivering item '7278' for client 'Identifier=192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
2013-04-03 22:28:20,611 DEBUG [VideoDeliveryEngine] Delivering file 'Revolution.2012.S01E11.720p.HDTV.X264-DIMENSION VOST.mkv' in native format
2013-04-03 22:28:20,611 DEBUG [MediaItemDAOImpl] Getting file of media item 7278
2013-04-03 22:28:20,611 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 7278) as read
2013-04-03 22:28:20,619 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-04-03 22:28:20,619 DEBUG [GETMethodProcessor] Stream entity has length: 1314761876
2013-04-03 22:28:20,619 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-matroska,Content-Length: 1314761876,Date: Thu, 04 Apr 2013 02:28:20 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.2,Cache-control: no-cache,Content-Range: bytes 5635-1314767510/1314767511,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-04-03 22:28:21,937 DEBUG [WebServer] Incoming connection from /192.168.1.134:41978
2013-04-03 22:28:21,938 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-03 22:28:21,938 DEBUG [ResourceTransportRequestHandler] GET /resource/7278/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.1, headers = [User-Agent: Panasonic,Accept: */*,Range: bytes=5631-,Connection: close,Host: 192.168.1.3:8895]]
2013-04-03 22:28:21,939 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
2013-04-03 22:28:21,939 DEBUG [ResourceDeliveryProcessor] Request for resource 7278 and type 'MEDIA_ITEM' received
2013-04-03 22:28:21,939 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 7278 (local)
2013-04-03 22:28:21,939 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7278)
2013-04-03 22:28:21,939 DEBUG [VideoDAOImpl] Reading a Video (id = 7278)
2013-04-03 22:28:21,940 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 7278, format MATROSKA and profile Panasonic Viera E/S/ST/VT (2011)
2013-04-03 22:28:21,940 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 7278 (local)
2013-04-03 22:28:21,940 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7278)
2013-04-03 22:28:21,940 DEBUG [VideoDAOImpl] Reading a Video (id = 7278)
2013-04-03 22:28:21,941 DEBUG [VideoDeliveryEngine] Delivering item '7278' for client 'Identifier=192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
2013-04-03 22:28:21,941 DEBUG [VideoDeliveryEngine] Delivering file 'Revolution.2012.S01E11.720p.HDTV.X264-DIMENSION VOST.mkv' in native format
2013-04-03 22:28:21,941 DEBUG [MediaItemDAOImpl] Getting file of media item 7278
2013-04-03 22:28:21,941 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 7278) as read
2013-04-03 22:28:21,950 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-04-03 22:28:21,950 DEBUG [GETMethodProcessor] Stream entity has length: 1314761880
2013-04-03 22:28:21,950 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-matroska,Content-Length: 1314761880,Date: Thu, 04 Apr 2013 02:28:21 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.2,Cache-control: no-cache,Content-Range: bytes 5631-1314767510/1314767511,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-04-03 22:28:21,956 DEBUG [WebServer] I/O error: Broken pipe
2013-04-03 22:28:31,767 DEBUG [WebServer] Incoming connection from /192.168.1.134:41979
2013-04-03 22:28:31,768 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-03 22:28:31,768 DEBUG [ResourceTransportRequestHandler] GET /resource/7278/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.1, headers = [User-Agent: Panasonic,Accept: */*,Range: bytes=5631-,Connection: close,Host: 192.168.1.3:8895]]
2013-04-03 22:28:31,769 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
2013-04-03 22:28:31,769 DEBUG [ResourceDeliveryProcessor] Request for resource 7278 and type 'MEDIA_ITEM' received
2013-04-03 22:28:31,769 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 7278 (local)
2013-04-03 22:28:31,769 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7278)
2013-04-03 22:28:31,770 DEBUG [VideoDAOImpl] Reading a Video (id = 7278)
2013-04-03 22:28:31,770 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 7278, format MATROSKA and profile Panasonic Viera E/S/ST/VT (2011)
2013-04-03 22:28:31,770 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 7278 (local)
2013-04-03 22:28:31,770 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7278)
2013-04-03 22:28:31,771 DEBUG [VideoDAOImpl] Reading a Video (id = 7278)
2013-04-03 22:28:31,771 DEBUG [VideoDeliveryEngine] Delivering item '7278' for client 'Identifier=192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
2013-04-03 22:28:31,771 DEBUG [VideoDeliveryEngine] Delivering file 'Revolution.2012.S01E11.720p.HDTV.X264-DIMENSION VOST.mkv' in native format
2013-04-03 22:28:31,771 DEBUG [MediaItemDAOImpl] Getting file of media item 7278
2013-04-03 22:28:31,771 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 7278) as read
2013-04-03 22:28:31,793 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-04-03 22:28:31,793 DEBUG [GETMethodProcessor] Stream entity has length: 1314761880
2013-04-03 22:28:31,794 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-matroska,Content-Length: 1314761880,Date: Thu, 04 Apr 2013 02:28:31 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.2,Cache-control: no-cache,Content-Range: bytes 5631-1314767510/1314767511,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-04-03 22:28:31,797 DEBUG [WebServer] I/O error: Broken pipe
2013-04-03 22:28:32,219 DEBUG [WebServer] Incoming connection from /192.168.1.134:41980
2013-04-03 22:28:32,219 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-03 22:28:32,220 DEBUG [ResourceTransportRequestHandler] GET /resource/9459/COVER_IMAGE HTTP/1.1, headers = [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.1.3:8895,transferMode.dlna.org: Interactive]]
2013-04-03 22:28:32,220 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-03 22:28:32,221 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
2013-04-03 22:28:32,221 DEBUG [ResourceDeliveryProcessor] Request for resource 9459 and type 'COVER_IMAGE' received
2013-04-03 22:28:32,221 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 9459)
2013-04-03 22:28:32,221 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 9459
2013-04-03 22:28:32,222 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 9459
2013-04-03 22:28:32,222 DEBUG [GETMethodProcessor] Stream entity has length: 6374
2013-04-03 22:28:32,222 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 6374,Date: Thu, 04 Apr 2013 02:28:32 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.2,Cache-control: no-cache,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-04-03 22:28:32,230 DEBUG [WebServer] Incoming connection from /192.168.1.134:41981
2013-04-03 22:28:32,231 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-03 22:28:32,231 DEBUG [ResourceTransportRequestHandler] GET /resource/9458/COVER_IMAGE HTTP/1.1, headers = [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.1.3:8895,transferMode.dlna.org: Interactive]]
2013-04-03 22:28:32,232 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
2013-04-03 22:28:32,232 DEBUG [ResourceDeliveryProcessor] Request for resource 9458 and type 'COVER_IMAGE' received
2013-04-03 22:28:32,232 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 9458)
2013-04-03 22:28:32,232 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 9458
2013-04-03 22:28:32,233 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 9458
2013-04-03 22:28:32,233 DEBUG [GETMethodProcessor] Stream entity has length: 6374
2013-04-03 22:28:32,233 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 6374,Date: Thu, 04 Apr 2013 02:28:32 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.2,Cache-control: no-cache,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-04-03 22:28:32,240 DEBUG [WebServer] Incoming connection from /192.168.1.134:41982
2013-04-03 22:28:32,240 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-03 22:28:32,241 DEBUG [ResourceTransportRequestHandler] GET /resource/8791/COVER_IMAGE HTTP/1.1, headers = [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.1.3:8895,transferMode.dlna.org: Interactive]]
2013-04-03 22:28:32,241 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-03 22:28:32,241 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
2013-04-03 22:28:32,242 DEBUG [ResourceDeliveryProcessor] Request for resource 8791 and type 'COVER_IMAGE' received
2013-04-03 22:28:32,242 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 8791)
2013-04-03 22:28:32,242 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 8791
2013-04-03 22:28:32,242 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 8791
2013-04-03 22:28:32,242 DEBUG [GETMethodProcessor] Stream entity has length: 5601
2013-04-03 22:28:32,243 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 5601,Date: Thu, 04 Apr 2013 02:28:32 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.2,Cache-control: no-cache,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-04-03 22:28:32,257 DEBUG [WebServer] Incoming connection from /192.168.1.134:41983
2013-04-03 22:28:32,257 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-03 22:28:32,258 DEBUG [ResourceTransportRequestHandler] GET /resource/8793/COVER_IMAGE HTTP/1.1, headers = [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.1.3:8895,transferMode.dlna.org: Interactive]]
2013-04-03 22:28:32,258 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-03 22:28:32,258 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
2013-04-03 22:28:32,258 DEBUG [ResourceDeliveryProcessor] Request for resource 8793 and type 'COVER_IMAGE' received
2013-04-03 22:28:32,258 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 8793)
2013-04-03 22:28:32,259 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 8793
2013-04-03 22:28:32,259 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 8793)
2013-04-03 22:28:32,259 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 8793
2013-04-03 22:28:32,259 DEBUG [GETMethodProcessor] Stream entity has length: 3306
2013-04-03 22:28:32,260 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 3306,Date: Thu, 04 Apr 2013 02:28:32 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.2,Cache-control: no-cache,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-04-03 22:28:32,281 DEBUG [WebServer] Incoming connection from /192.168.1.134:41984
2013-04-03 22:28:32,281 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-03 22:28:32,282 DEBUG [ResourceTransportRequestHandler] GET /resource/8794/COVER_IMAGE HTTP/1.1, headers = [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.1.3:8895,transferMode.dlna.org: Interactive]]
2013-04-03 22:28:32,282 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-03 22:28:32,283 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
2013-04-03 22:28:32,283 DEBUG [ResourceDeliveryProcessor] Request for resource 8794 and type 'COVER_IMAGE' received
2013-04-03 22:28:32,283 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 8794)
2013-04-03 22:28:32,283 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 8794
2013-04-03 22:28:32,284 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 8794
2013-04-03 22:28:32,284 DEBUG [GETMethodProcessor] Stream entity has length: 5025
2013-04-03 22:28:32,284 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 5025,Date: Thu, 04 Apr 2013 02:28:32 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.2,Cache-control: no-cache,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-04-03 22:28:32,296 DEBUG [WebServer] Incoming connection from /192.168.1.134:41985
2013-04-03 22:28:32,297 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-03 22:28:32,298 DEBUG [ResourceTransportRequestHandler] GET /resource/8792/COVER_IMAGE HTTP/1.1, headers = [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.1.3:8895,transferMode.dlna.org: Interactive]]
2013-04-03 22:28:32,298 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-03 22:28:32,298 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
2013-04-03 22:28:32,298 DEBUG [ResourceDeliveryProcessor] Request for resource 8792 and type 'COVER_IMAGE' received
2013-04-03 22:28:32,299 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 8792)
2013-04-03 22:28:32,299 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 8792
2013-04-03 22:28:32,300 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 8792
2013-04-03 22:28:32,300 DEBUG [GETMethodProcessor] Stream entity has length: 6099
2013-04-03 22:28:32,300 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 6099,Date: Thu, 04 Apr 2013 02:28:32 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.2,Cache-control: no-cache,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-04-03 22:28:32,317 DEBUG [WebServer] Incoming connection from /192.168.1.134:41986
2013-04-03 22:28:32,319 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-03 22:28:32,320 DEBUG [ResourceTransportRequestHandler] GET /resource/8790/COVER_IMAGE HTTP/1.1, headers = [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.1.3:8895,transferMode.dlna.org: Interactive]]
2013-04-03 22:28:32,320 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-03 22:28:32,321 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
2013-04-03 22:28:32,321 DEBUG [ResourceDeliveryProcessor] Request for resource 8790 and type 'COVER_IMAGE' received
2013-04-03 22:28:32,321 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 8790)
2013-04-03 22:28:32,321 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 8790
2013-04-03 22:28:32,322 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 8790
2013-04-03 22:28:32,322 DEBUG [GETMethodProcessor] Stream entity has length: 5724
2013-04-03 22:28:32,322 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 5724,Date: Thu, 04 Apr 2013 02:28:32 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.2,Cache-control: no-cache,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-04-03 22:28:32,333 DEBUG [WebServer] Incoming connection from /192.168.1.134:41987
2013-04-03 22:28:32,334 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-03 22:28:32,334 DEBUG [ResourceTransportRequestHandler] GET /resource/8795/COVER_IMAGE HTTP/1.1, headers = [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.1.3:8895,transferMode.dlna.org: Interactive]]
2013-04-03 22:28:32,335 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-03 22:28:32,335 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
2013-04-03 22:28:32,335 DEBUG [ResourceDeliveryProcessor] Request for resource 8795 and type 'COVER_IMAGE' received
2013-04-03 22:28:32,335 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 8795)
2013-04-03 22:28:32,336 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 8795
2013-04-03 22:28:32,336 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 8795)
2013-04-03 22:28:32,336 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 8795
2013-04-03 22:28:32,336 DEBUG [GETMethodProcessor] Stream entity has length: 5046
2013-04-03 22:28:32,337 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 5046,Date: Thu, 04 Apr 2013 02:28:32 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.2,Cache-control: no-cache,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-04-03 22:28:32,349 DEBUG [WebServer] Incoming connection from /192.168.1.134:41988
2013-04-03 22:28:32,349 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-03 22:28:32,350 DEBUG [ResourceTransportRequestHandler] GET /resource/8796/COVER_IMAGE HTTP/1.1, headers = [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.1.3:8895,transferMode.dlna.org: Interactive]]
2013-04-03 22:28:32,350 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-03 22:28:32,350 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
2013-04-03 22:28:32,350 DEBUG [ResourceDeliveryProcessor] Request for resource 8796 and type 'COVER_IMAGE' received
2013-04-03 22:28:32,350 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 8796)
2013-04-03 22:28:32,351 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 8796
2013-04-03 22:28:32,351 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 8796)
2013-04-03 22:28:32,351 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 8796
2013-04-03 22:28:32,351 DEBUG [GETMethodProcessor] Stream entity has length: 5553
2013-04-03 22:28:32,352 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 5553,Date: Thu, 04 Apr 2013 02:28:32 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.2,Cache-control: no-cache,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-04-03 22:28:32,361 DEBUG [WebServer] Incoming connection from /192.168.1.134:41989
2013-04-03 22:28:32,361 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-03 22:28:32,362 DEBUG [ResourceTransportRequestHandler] GET /resource/8788/COVER_IMAGE HTTP/1.1, headers = [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.1.3:8895,transferMode.dlna.org: Interactive]]
2013-04-03 22:28:32,362 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-03 22:28:32,362 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
2013-04-03 22:28:32,363 DEBUG [ResourceDeliveryProcessor] Request for resource 8788 and type 'COVER_IMAGE' received
2013-04-03 22:28:32,363 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 8788)
2013-04-03 22:28:32,363 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 8788
2013-04-03 22:28:32,364 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 8788
2013-04-03 22:28:32,364 DEBUG [GETMethodProcessor] Stream entity has length: 3998
2013-04-03 22:28:32,364 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 3998,Date: Thu, 04 Apr 2013 02:28:32 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.2,Cache-control: no-cache,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-04-03 22:28:32,372 DEBUG [WebServer] Incoming connection from /192.168.1.134:41990
2013-04-03 22:28:32,373 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-03 22:28:32,373 DEBUG [ResourceTransportRequestHandler] GET /resource/8789/COVER_IMAGE HTTP/1.1, headers = [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.1.3:8895,transferMode.dlna.org: Interactive]]
2013-04-03 22:28:32,374 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
Here is a second file who doesn't work:
File info:
media@mediastation:/opt/serviio/serviio-1.x/log$ ffmpeg -i /data/Teleseries/Spartacus/Saison\ 03/Spartacus.S03E08.FASTSUB.VOST.720p.HDTV.X264-ADDiCTiON/Spartacus.S03E08.FASTSUB.VOST.720p.HDTV.X264-ADDiCTiON.mkv
Input #0, matroska,webm, from '/data/Teleseries/Spartacus/Saison 03/Spartacus.S03E08.FASTSUB.VOST.720p.HDTV.X264-ADDiCTiON/Spartacus.S03E08.FASTSUB.VOST.720p.HDTV.X264-ADDiCTiON.mkv':
creation_time : 2013-03-23 13:05:50
Duration: 00:54:15.78, start: 0.000000, bitrate: 3960 kb/s
title : Video
Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 384 kb/s (default)
title : Audio
title : Subs
Log:
013-04-03 22:53:33,351 DEBUG [WebServer] Incoming connection from /192.168.1.134:33764
2013-04-03 22:53:33,351 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-03 22:53:33,352 DEBUG [ResourceTransportRequestHandler] GET /resource/7160/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.1, headers = [User-Agent: Panasonic,Accept: */*,Range: bytes=5717-,Connection: close,Host: 192.168.1.3:8895]]
2013-04-03 22:53:33,352 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-03 22:53:33,353 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
2013-04-03 22:53:33,353 DEBUG [ResourceDeliveryProcessor] Request for resource 7160 and type 'MEDIA_ITEM' received
2013-04-03 22:53:33,353 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 7160 (local)
2013-04-03 22:53:33,353 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7160)
2013-04-03 22:53:33,353 DEBUG [VideoDAOImpl] Reading a Video (id = 7160)
2013-04-03 22:53:33,354 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 7160, format MATROSKA and profile Panasonic Viera E/S/ST/VT (2011)
2013-04-03 22:53:33,354 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 7160 (local)
2013-04-03 22:53:33,354 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7160)
2013-04-03 22:53:33,354 DEBUG [VideoDAOImpl] Reading a Video (id = 7160)
2013-04-03 22:53:33,355 DEBUG [VideoDeliveryEngine] Delivering item '7160' for client 'Identifier=192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
2013-04-03 22:53:33,355 DEBUG [VideoDeliveryEngine] Delivering file 'Spartacus.S03E08.FASTSUB.VOST.720p.HDTV.X264-ADDiCTiON.mkv' in native format
2013-04-03 22:53:33,355 DEBUG [MediaItemDAOImpl] Getting file of media item 7160
2013-04-03 22:53:33,355 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 7160) as read
2013-04-03 22:53:33,376 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-04-03 22:53:33,376 DEBUG [GETMethodProcessor] Stream entity has length: 1611956504
2013-04-03 22:53:33,376 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-matroska,Content-Length: 1611956504,Date: Thu, 04 Apr 2013 02:53:33 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.2,Cache-control: no-cache,Content-Range: bytes 5717-1611962220/1611962221,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-04-03 22:53:33,382 DEBUG [WebServer] I/O error: Broken pipe
Here is screenshot of my subtitle setting in serviio:
My Setup : BDT220 Panasonic Bluray player, TC-L55ET5 and TC-L42ET5 Panasonic TV. My home media server run Serviio 1.4.2 Pro under GNU/Linux Ubuntu 14.04 LTS server x64 and the hardware is Amd 1045t Phenom II X6, 6Gb DDR3 1333 mhz on SSD and data on soft raid 5 (3x1tb).
thenamelessthing
Post Thu Apr 04, 2013 3:57 am
Re: subtitle working with external sub but not for embedded
And one additionnal question, if a file is named: Revolution.2012.S01E12.FASTSUB.VOSTFR.720p.HDTV.x264-ADDiCTiON and it contain embedded subtitle (fre). Is French subtitles will be displayed? How he understands the term VOSTFR in the file name?
Post Thu Apr 04, 2013 6:59 am
No image on previous post....
Your two mkv files are delivered in native format.
Its up to your device to select or extract embedded subtitles.
If you want to force hardsub, on serviio console select enable it.
thenamelessthing
Post Thu Apr 04, 2013 10:25 am
It's enable! I will fix image links at work in 2hours.
Post Thu Apr 04, 2013 12:04 pm
thenamelessthing wrote:It's enable! I will fix image links at work in 2hours.
You didn't use the official serviio console, on image I see you used ServiioGo (post on specific forum topic). (Images are blocked by my work IT)
thenamelessthing
Post Fri Apr 05, 2013 1:56 am
which console are official for Ubuntu users? I also have an Android smartphone and Ipad..
thenamelessthing
Post Fri Apr 05, 2013 2:01 am
If my file is Revolution.S01E01.VOSTFR.720p.WEBDL.AVC.AC3-BiG.mkv and it contain a (fre) embedded sub track will it show it or not??
Post Fri Apr 05, 2013 11:10 pm
It should, depends on the speed of the IO. And file size. If it's quick to extract it before the tv times out, it should work.
thenamelessthing
Post Sat Apr 06, 2013 2:01 am
Any way to test if it's the problem or not with my pc?
Post Tue Apr 09, 2013 4:54 pm
try to enable detailed log, play the file with subs, find the ffmpeg command when it extracts to subtitles from the file and try to run that command manually - how long does it take?
Basically, disable burned in subs, it should then deliver the extracted srt as a separate resource, which Viera should support
thenamelessthing
Post Thu Apr 11, 2013 1:29 am
I have disable burnedin sub and tried to play file with external sub without success. I also tried the srtwiz to "repair" the srt too ;-(
in my log I only have these errors I see no log about the file I try to play with sub!!! I see in the webui (Ajax WebUI v1.0.1-c) the Transcoding tab is empty in my browser (chrome and firefox) maybe these error are related to this strange behavior?
2013-04-04 21:48:23,941 INFO [PluginCompilerThread] Looking for plugins at /opt/serviio/serviio-1.x/plugins
2013-04-04 21:48:23,942 INFO [PluginCompilerThread] Started looking for plugins
2013-04-04 21:48:23,943 INFO [UpdateChecker] Checking if a new version is available
2013-04-04 21:48:23,967 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "dcraw": error=2, No such file or directory
java.io.IOException: Cannot run program "dcraw": error=2, No such file or directory
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
at org.serviio.external.ProcessExecutor.run(ProcessExecutor.java:135)
Caused by: java.io.IOException: error=2, No such file or directory
at java.lang.UNIXProcess.forkAndExec(Native Method)
at java.lang.UNIXProcess.<init>(UNIXProcess.java:135)
at java.lang.ProcessImpl.start(ProcessImpl.java:130)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1021)
... 1 more
2013-04-04 21:48:23,969 WARN [MediaServer] DCRAW not found. Support for raw image files will be missing.
2013-04-04 21:48:23,976 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-04-04 21:48:23,999 INFO [WebServer] WebServer starting on port 8895
2013-04-04 21:48:24,003 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-04-04 21:48:24,003 INFO [EventDispatcher] Starting EventDispatcher
2013-04-04 21:48:24,003 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-04-04 21:48:24,005 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (eth0) and address 192.168.1.3, timeout = 0
2013-04-04 21:48:24,006 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2013-04-04 21:48:24,006 INFO [RendererSearchSender] Searching for Renderer devices
2013-04-04 21:48:50,029 INFO [FeedUpdaterThread] Started looking for information about online resources
2013-04-04 21:48:50,032 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-04-04 21:48:50,038 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-04-04 21:48:50,039 INFO [PlaylistMaintainerThread] Started looking playlist changes
2013-04-04 21:49:03,802 WARN [ServiioStatusService] Returning error code to the REST layer: Not Found (404) - The server has not found anything matching the request URI
2013-04-04 21:49:10,822 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2013-04-04 21:49:11,452 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: fr
2013-04-04 21:49:14,130 WARN [ServiioStatusService] Returning error code to the REST layer: Not Found (404) - The server has not found anything matching the request URI
2013-04-04 21:49:17,834 WARN [ServiioStatusService] Returning error code to the REST layer: Not Found (404) - The server has not found anything matching the request URI
2013-04-04 21:49:33,362 WARN [ServiioStatusService] Returning error code to the REST layer: Not Found (404) - The server has not found anything matching the request URI
2013-04-04 21:49:34,869 WARN [ServiioStatusService] Returning error code to the REST layer: Not Found (404) - The server has not found anything matching the request URI
2013-04-04 21:49:54,405 WARN [ServiioStatusService] Returning error code to the REST layer: Not Found (404) - The server has not found anything matching the request URI
2013-04-05 21:48:24,327 INFO [UpdateChecker] Checking if a new version is available
2013-04-06 21:48:24,327 INFO [UpdateChecker] Checking if a new version is available
2013-04-07 21:48:24,327 INFO [UpdateChecker] Checking if a new version is available
2013-04-08 21:48:24,327 INFO [UpdateChecker] Checking if a new version is available
2013-04-09 21:48:24,327 INFO [UpdateChecker] Checking if a new version is available
2013-04-10 21:17:01,954 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2013-04-10 21:17:01,989 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2013-04-10 21:17:01,989 INFO [EventDispatcher] Leaving EventDispatcher
2013-04-10 21:17:01,989 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2013-04-10 21:17:01,970 INFO [WebServer] WebServer shutting down
2013-04-10 21:17:04,009 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2013-04-10 21:17:04,710 INFO [WebServer] WebServer starting on port 8895
2013-04-10 21:17:04,710 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-04-10 21:17:04,711 INFO [EventDispatcher] Starting EventDispatcher
2013-04-10 21:17:04,711 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (eth0) and address 192.168.1.3, timeout = 0
2013-04-10 21:17:04,711 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-04-10 21:17:04,711 INFO [RendererSearchSender] Searching for Renderer devices
2013-04-10 21:17:12,121 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2013-04-10 21:17:12,221 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2013-04-10 21:17:12,321 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-04-10 21:17:12,322 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
Post Fri Apr 12, 2013 10:23 pm
you have to enable detailed log to see if the subtitle file is found and sent/extracted
thenamelessthing
Post Sat Apr 13, 2013 1:34 am
Oups! Here is the debug log.. I don't know why I doesn't see any transcoding job or any mention about subtitle!
The file I use for my test is:
Spartacus.S03E07.FASTSUB.VOSTFR.720p.HDTV.x264-ADDiCTiON.mkv
Spartacus.S03E07.FASTSUB.VOSTFR.720p.HDTV.x264-ADDiCTiON - FR.srt
or
Spartacus.S03E07.FASTSUB.VOST.720p.HDTV.x264-ADDiCTiON.mkv
Spartacus.S03E07.FASTSUB.VOST.720p.HDTV.x264-ADDiCTiON - FR.srt
2013-04-12 21:33:13,678 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
2013-04-12 21:33:13,679 DEBUG [ResourceDeliveryProcessor] Request for resource 7161 and type 'MEDIA_ITEM' received
2013-04-12 21:33:13,679 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 7161 (local)
2013-04-12 21:33:13,679 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7161)
2013-04-12 21:33:13,679 DEBUG [VideoDAOImpl] Reading a Video (id = 7161)
2013-04-12 21:33:13,680 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 7161, format MATROSKA and profile Panasonic Viera E/S/ST/VT (2011)
2013-04-12 21:33:13,680 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 7161 (local)
2013-04-12 21:33:13,680 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7161)
2013-04-12 21:33:13,681 DEBUG [VideoDAOImpl] Reading a Video (id = 7161)
2013-04-12 21:33:13,681 DEBUG [VideoDeliveryEngine] Delivering item '7161' for client 'Identifier=192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
2013-04-12 21:33:13,682 DEBUG [VideoDeliveryEngine] Delivering file 'Spartacus.S03E07.FASTSUB.VOST.720p.HDTV.x264-ADDiCTiON.mkv' in native format
2013-04-12 21:33:13,682 DEBUG [MediaItemDAOImpl] Getting file of media item 7161
2013-04-12 21:33:13,682 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 7161) as read
2013-04-12 21:33:13,701 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-04-12 21:33:13,701 DEBUG [GETMethodProcessor] Stream entity has length: 1866002366
2013-04-12 21:33:13,702 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-matroska,Content-Length: 1866002366,Date: Sat, 13 Apr 2013 01:33:13 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.2.1,Cache-control: no-cache,Content-Range: bytes 0-1866002365/1866002366,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-04-12 21:33:13,711 DEBUG [ServiioHttpService] Incoming request from /192.168.1.134:39988: GET /resource/7161/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.1, headers = [User-Agent: Panasonic,Accept: */*,Range: bytes=1865969785-,Connection: close,Host: 192.168.1.3:8895]]
2013-04-12 21:33:13,712 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-12 21:33:13,713 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
2013-04-12 21:33:13,713 DEBUG [ResourceDeliveryProcessor] Request for resource 7161 and type 'MEDIA_ITEM' received
2013-04-12 21:33:13,713 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 7161 (local)
2013-04-12 21:33:13,713 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7161)
2013-04-12 21:33:13,714 DEBUG [VideoDAOImpl] Reading a Video (id = 7161)
2013-04-12 21:33:13,714 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 7161, format MATROSKA and profile Panasonic Viera E/S/ST/VT (2011)
2013-04-12 21:33:13,715 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 7161 (local)
2013-04-12 21:33:13,715 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7161)
2013-04-12 21:33:13,715 DEBUG [VideoDAOImpl] Reading a Video (id = 7161)
2013-04-12 21:33:13,716 DEBUG [VideoDeliveryEngine] Delivering item '7161' for client 'Identifier=192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
2013-04-12 21:33:13,716 DEBUG [VideoDeliveryEngine] Delivering file 'Spartacus.S03E07.FASTSUB.VOST.720p.HDTV.x264-ADDiCTiON.mkv' in native format
2013-04-12 21:33:13,717 DEBUG [MediaItemDAOImpl] Getting file of media item 7161
2013-04-12 21:33:13,717 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 7161) as read
2013-04-12 21:33:13,726 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-04-12 21:33:13,726 DEBUG [GETMethodProcessor] Stream entity has length: 32581
2013-04-12 21:33:13,727 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-matroska,Content-Length: 32581,Date: Sat, 13 Apr 2013 01:33:13 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.2.1,Cache-control: no-cache,Content-Range: bytes 1865969785-1866002365/1866002366,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-04-12 21:33:13,731 DEBUG [WebServer] I/O error: Broken pipe
2013-04-12 21:33:13,740 DEBUG [ServiioHttpService] Incoming request from /192.168.1.134:48601: GET /resource/7161/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.1, headers = [User-Agent: Panasonic,Accept: */*,Range: bytes=5639-,Connection: close,Host: 192.168.1.3:8895]]
2013-04-12 21:33:13,740 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-12 21:33:13,741 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-12 21:33:13,742 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
2013-04-12 21:33:13,742 DEBUG [ResourceDeliveryProcessor] Request for resource 7161 and type 'MEDIA_ITEM' received
2013-04-12 21:33:13,742 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 7161 (local)
2013-04-12 21:33:13,742 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7161)
2013-04-12 21:33:13,742 DEBUG [VideoDAOImpl] Reading a Video (id = 7161)
2013-04-12 21:33:13,743 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 7161, format MATROSKA and profile Panasonic Viera E/S/ST/VT (2011)
2013-04-12 21:33:13,744 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 7161 (local)
2013-04-12 21:33:13,744 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7161)
2013-04-12 21:33:13,744 DEBUG [VideoDAOImpl] Reading a Video (id = 7161)
2013-04-12 21:33:13,744 DEBUG [VideoDeliveryEngine] Delivering item '7161' for client 'Identifier=192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
2013-04-12 21:33:13,745 DEBUG [VideoDeliveryEngine] Delivering file 'Spartacus.S03E07.FASTSUB.VOST.720p.HDTV.x264-ADDiCTiON.mkv' in native format
2013-04-12 21:33:13,745 DEBUG [MediaItemDAOImpl] Getting file of media item 7161
2013-04-12 21:33:13,745 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 7161) as read
2013-04-12 21:33:13,751 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-04-12 21:33:13,751 DEBUG [GETMethodProcessor] Stream entity has length: 1865996727
2013-04-12 21:33:13,752 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-matroska,Content-Length: 1865996727,Date: Sat, 13 Apr 2013 01:33:13 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.2.1,Cache-control: no-cache,Content-Range: bytes 5639-1866002365/1866002366,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-04-12 21:33:15,451 DEBUG [ServiioHttpService] Incoming request from /192.168.1.134:26182: GET /resource/7161/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.1, headers = [User-Agent: Panasonic,Accept: */*,Range: bytes=5635-,Connection: close,Host: 192.168.1.3:8895]]
2013-04-12 21:33:15,451 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-12 21:33:15,452 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.134
2013-04-12 21:33:15,453 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
2013-04-12 21:33:15,453 DEBUG [ResourceDeliveryProcessor] Request for resource 7161 and type 'MEDIA_ITEM' received
2013-04-12 21:33:15,453 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 7161 (local)
2013-04-12 21:33:15,453 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7161)
2013-04-12 21:33:15,454 DEBUG [VideoDAOImpl] Reading a Video (id = 7161)
2013-04-12 21:33:15,454 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 7161, format MATROSKA and profile Panasonic Viera E/S/ST/VT (2011)
2013-04-12 21:33:15,455 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 7161 (local)
2013-04-12 21:33:15,455 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7161)
2013-04-12 21:33:15,456 DEBUG [VideoDAOImpl] Reading a Video (id = 7161)
2013-04-12 21:33:15,456 DEBUG [VideoDeliveryEngine] Delivering item '7161' for client 'Identifier=192.168.1.134, Profile=Panasonic Viera E/S/ST/VT (2011)'
2013-04-12 21:33:15,457 DEBUG [VideoDeliveryEngine] Delivering file 'Spartacus.S03E07.FASTSUB.VOST.720p.HDTV.x264-ADDiCTiON.mkv' in native format
2013-04-12 21:33:15,457 DEBUG [MediaItemDAOImpl] Getting file of media item 7161
2013-04-12 21:33:15,457 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 7161) as read
2013-04-12 21:33:15,465 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-04-12 21:33:15,465 DEBUG [GETMethodProcessor] Stream entity has length: 1865996731
2013-04-12 21:33:15,466 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-matroska,Content-Length: 1865996731,Date: Sat, 13 Apr 2013 01:33:15 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.2.1,Cache-control: no-cache,Content-Range: bytes 5635-1866002365/1866002366,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-04-12 21:33:15,471 DEBUG [WebServer] I/O error: Broken pipe
kram
Post Sun Apr 14, 2013 7:57 pm
Does that file play on the TV with transcoding OFF? If it does then try to select subtitles and see what happens.
Ive just discovered that my TV wont play a SRT file when transcoding is ON but does when OFF, I assume the Panasonic profile needs changing, at least for my TV anyway.
Post Mon Apr 15, 2013 4:32 pm
Your srt file is not named correctly, you have spaces around ' - fr'.
Name the file like this:
Spartacus.S03E07.FASTSUB.VOST.720p.HDTV.x264-ADDiCTiON-fr.srt
thenamelessthing
Post Mon Apr 15, 2013 4:50 pm
OK fine about the "space". But about the sub included in the mkv file? Why he doesn't use it? (I have added the srt file after because I was unable to use the embedded sub)
Post Fri Apr 19, 2013 1:06 pm
Try to only use "fre" as your preferred language, there might be a bug
thenamelessthing
Post Thu May 02, 2013 1:48 am
I confirm with fre it's working! So I think we have found a bug here! ;-)
Post Tue May 07, 2013 9:57 am
Should be fixed in next version.
Return to Panasonic
