Subtitle Support on Toshiba (42YL863)
bhatiagagan
Post Sat Apr 06, 2013 2:38 pm
Hi
I'm new to Serviio, and have really enjoyed it so far, especially as it has proven to be the only DLNA server that plays all my video formats on the Toshiba. The only problem I'm facing is around subtitle support. I've gone through all subtitle related serviio forum posts, but have not found the answer to this: Can the Toshiba profile display subtitles through external .srt files? Is there a way to make this work?
Would really appreciate any help on this.
bhatiagagan
Post Mon Apr 08, 2013 1:31 am
Re: Subtitle Support on Toshiba (42YL863)
Has this questions been answered before?
slyguy42o
Post Mon Apr 08, 2013 4:17 pm
what subtitle options do you currently have set in the console? I couldn't speak to what your device supports but you should be able to get them working on way or another via console sub title options.
bhatiagagan
Post Tue Apr 09, 2013 11:12 pm
Hey Thanks for replying
I've enable all three options under the subtitle screen, but i must add none of my video files have burned in / embedded subtitles. I am using subtitles the old fashioned way - .srt file with the same name.
Have other people been able to view subtitles through Serviio in this manner?
slyguy42o
Post Wed Apr 10, 2013 2:56 pm
yea that should work, so your using the burned in sub option and it's still not showing?
Post Wed Apr 10, 2013 5:09 pm
Read this if it helps you understand: http://www.serviio.org/index.php?option ... icle&id=33
Return to Toshiba
