Library + XBMC .nfo
pony_wong
Post Tue Apr 09, 2013 12:51 pm
Library + XBMC .nfo
I have Serviio 1.1 running on a Zyxel NSA325 and a XBMC PC with an exported library to .nfo (1 file per movie).
After configuring servio do add this share to its library, Serviio is ignoring the nfo and is still trying to guess the Movies names, probably from online sources (even thought i've select XBMC as metada source).
Shouldn't serviio be showing in its library exactly the same content as I see in XBMC? Since I can't force a refresh of metada - the button in windows console is disabled- what is the best way to achieve this setup (XBMC exported nfos to be interpreted bt serviio).
Thank you in advance and sorry if this question has been posted before but I could not find anything.
Post Tue Apr 09, 2013 4:42 pm
Re: Library + XBMC .nfo
It should only look at the .nfo files if you select that as your metadata source. try to click Refresh Video metadata button on the metadata tab.
Users browsing this forum: No registered users and 317 guests
