No Audio
scottrotton
Post Wed Apr 10, 2013 11:50 am
No Audio
Here is another one, this time no audio.
is it supposed to pick the right codec itself?
Unique ID : 172794159172083187768127089480877795446 (0x81FEF1CD246D22FB937F27EE4048E876)
Format : Matroska
Format version : Version 2
File size : 922 MiB
Duration : 2h 16mn
Overall bit rate : 946 Kbps
Encoded date : UTC 2012-10-25 08:39:29
Writing application : mkvmerge v4.0.0 ('The Stars were mine') built on Jun 6 2010 16:18:42
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 16mn
Nominal bit rate : 909 Kbps
Width : 1 280 pixels
Height : 536 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.055
Title : ==== 300mbunited.me | rpnet.biz ====
Writing library : x264 core 120 r2120 0c7dab9
Encoding settings : cabac=1 / ref=8 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=909 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : No
Forced : No
Format : AAC
Format profile : HE-AAC / LC
Codec ID : A_AAC
Duration : 2h 16mn
Channel(s) : 2 channels
Sampling rate : 48.0 KHz / 24.0 KHz
Compression mode : Lossy
Default : Yes
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Default : Yes
Forced : No
Post Wed Apr 10, 2013 1:56 pm
Re: No Audio
Yep, HE-AAC / LC is not supported by Sony Bravia devices, but yet serviio could not distinguish AAC to HE-AAC.
NX3
Post Wed Apr 10, 2013 6:04 pm
Re: No Audio
So isn't it best to just transcode all AAC to AC3 so at least audio works ?
Post Wed Apr 10, 2013 6:18 pm
Re: No Audio
NX3 wrote:So isn't it best to just transcode all AAC to AC3 so at least audio works ?
Yes but for some syteme based on NAS, it's prefered to minimize transcoding, and sony device support AAC audio, so AAC is not transcoded. Btw you can comment all "aac match" lines on sony profile to force ac3 transcoding.
