No Online Playback on LG BD390
daniel_2k
Post Sun Apr 07, 2013 6:04 pm
I try to play online music streams (MP3) on ymy LG BD390. But when I try to play such stream the whole device hangs and a few minutes later it turns off.
On my Samsung 37LEB650 it works very well. What can it be?
I also tried to set the profile for my LG Device to LG TV /player.
slyguy42o
Post Mon Apr 08, 2013 4:08 pm
Re: No Online Playback on LG BD390
Can you post detailed server logs? Also you may want to try generic profile to see if it makes a difference.
Post Tue Apr 09, 2013 4:53 pm
LG's suck :-) It this an old model?
daniel_2k
Post Wed Apr 10, 2013 6:52 pm
I get only this log entries:
2013-04-10 20:49:02,073 WARN  [GETMethodProcessor] A range header was found on the incoming request for a live stream, sending back the whole stream
2013-04-10 20:49:08,073 WARN  [GETMethodProcessor] A range header was found on the incoming request for a live stream, sending back the whole stream
Yes the player is from 2009. On newer LG BD-player (like BD620) it works well.
Post Fri Apr 12, 2013 10:20 pm
The old players ignore some of the things Serviio tells them and send requests that are not supported. So transcoding doesn't really work on these.
Return to LG
