Samsung 3D BDP c-5900
siriusblack
Post Wed Apr 10, 2013 8:56 pm
Hi
Just wondering if any one knows how to fix my Samsung c-5900
It keeps disconnecting on live streams and my liabary
Thanks in advance
Beta Tester
slyguy42o
Post Wed Apr 10, 2013 9:41 pm
Re: Samsung 3D BDP c-5900
please post your server logs after a disconnect has occurred.
siriusblack
Post Fri Apr 19, 2013 8:38 pm
here is the log [attachment=0]samsung.txt[/attachment
just wondering chelsea tv works with my laptop not my bdp
thanks for ur help
samsung.txt
(73.4 KiB) Downloaded 562 times
Beta Tester
siriusblack
Post Sat Apr 20, 2013 12:48 pm
bdp.txt
(73.51 KiB) Downloaded 527 times
hopefully this is the right one
sorry for last attachment
Beta Tester
siriusblack
Post Sat May 04, 2013 10:18 am
Hope this can help + its the right content
This is my log for live stream
live content log.txt
(12.87 KiB) Downloaded 526 times
This is the log for my library
normal content.txt
(7.55 KiB) Downloaded 592 times
Thanks a lot
if its not the right content
can you please tell me what it starts with and ends with so I can send the part
really appreciate it
Beta Tester
slyguy42o
Post Mon May 06, 2013 5:29 pm
not really seeing any errors. Is there a specific stream this is happening on?
siriusblack
Post Mon May 06, 2013 5:36 pm
On the library it happens with any programme
But not all the time
live channels is solved by changing the profile with those 3 lines
To change it to mpeg2
Beta Tester
slyguy42o
Post Mon May 06, 2013 5:42 pm
seeing this entry a few times
2013-05-04 10:29:45,360 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
which is basically a network error.
Are either your server or TV on wireless?
siriusblack
Post Mon May 06, 2013 5:45 pm
Thanks for your help
I am using wireless the router is Netgear DGND4000
BT infinity 2
I only gets disconnecting problems with this BDP
Not with ps3 or my Samsung tv
Beta Tester
