Allshare Serviio network not found and disconnect issue
pitstopper
Post Sat Apr 06, 2013 12:41 am
I use Serviio 1.2.1 Pro (PC version) with SAMSUNG un46es6580. I get Network Not found or Device Disconnected message exactly at 8th minute. I tried disable Windows Media server service as well, browsed thru forum on other options, nothing helped. Attached is the detailed debug log.
Can you post the options I have to try or is there any solution at all?
Error message on TV is as follows:
Device Disconnected
Device name: Servio US...
(327.62 KiB) Downloaded 495 times
Post Sun Apr 07, 2013 11:17 pm
Re: Allshare Serviio network not found and disconnect issue
Does it disconnect when you play a file (after 8 minutes) or just turn on the TV?
pitstopper
Post Mon Apr 08, 2013 1:41 am
After 8 minutes, I get network not found or Device disconnect message (either of this message) and then it returns to the TV. Also, I find comedy central shows(dailyshow etc..) playing little longer, not any other feeds or videos.
Post Mon Apr 08, 2013 12:14 pm
But is it 8 minutes of playing movie, or does it happen if you just browse folders or don't do anything.. ?
pitstopper
Post Wed Apr 10, 2013 12:38 am
8 minutes of playing video, message pops up network notfound. Is there something i can try to fix?
Post Wed Apr 10, 2013 5:01 pm
Are you on wifi or wireless?
pitstopper
Post Thu Apr 11, 2013 10:56 am
I am wi-fi, home network firewall disabled
edit: I believe it is do with some file format (which happens to be majority of the one). for eg: http://www.hgtv.com/full-episodes/package/index.html able to watch without interuption. but not youtube videos (which stops streaming at 8 min)
edit2: Dailyshow streaming works fine as well. But none of the other videos like youtube etc..
Users browsing this forum: Google [Bot] and 20 guests
