Transcoding when no needed
agucortes
Post Thu Apr 11, 2013 1:20 am
movie2.txt
this file is transcoded
(2.06 KiB) Downloaded 746 times
movie1.txt
this play without trancode
(2.06 KiB) Downloaded 720 times
Hi, i'm new here...
i'll go straight to the point.
I have two files with exactly the same codecs and container (container: MP4, codec: AVC1 AAC), in one case it play normally without transcoding. But in the other case the movie is transcoded, and cause a slow image.
I've been looking in profiles, but i didnt found anything; serviio is configured with Sony Bravia TV (2012) profile.
The tv i'm using is a Sony Bravia kdl-32ex655.
Can someone help to solving this issue? because i'm dry of ideas.
Thanks in advance.
ps: i atached two fourcc codec analysis.
The two files play fine with the windows dnla server by default (play to option)
Post Thu Apr 11, 2013 3:19 am
Re: Transcoding when no needed
Have a look at both files using MediaInfo (and/or do an fmpeg -i for each - see here for details) and post the results. There must be some difference in the files that is triggering transcoding in one case but not the other - once you find it, you can modify the profile so that it is no longer a trigger. For example, the Sony Bravia (2012) profile will transcode if the h264 profile level is over 4.1 - your attachments don't show this level of detail.
agucortes
Post Thu Apr 11, 2013 5:34 pm
Thanks for the help. Here is the result for ffmpeg -i for each file:
this one play:
ffmpeg version N-51683-g9dc88ac Copyright (c) 2000-2013 the FFmpeg developers
  built on Apr  8 2013 21:19:21 with gcc 4.8.0 (GCC)
  configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av
isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab
le-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetyp
e --enable-libgsm --enable-libilbc --enable-libmp3lame --enable-libopencore-amrn
b --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libr
tmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheo
ra --enable-libtwolame --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-li
bvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --ena
ble-zlib
  libavutil      52. 25.100 / 52. 25.100
  libavcodec     55.  2.100 / 55.  2.100
  libavformat    55.  1.100 / 55.  1.100
  libavdevice    55.  0.100 / 55.  0.100
  libavfilter     3. 49.101 /  3. 49.101
  libswscale      2.  2.100 /  2.  2.100
  libpostproc    52.  2.100 / 52.  2.100
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Hitchcock.2012.1080p.BluRay.x264.YIFY.m
p4':
    major_brand     : isom
    minor_version   : 1
    compatible_brands: isomavc1
    creation_time   : 2013-03-05 05:56:31
  Duration: 01:38:20.95, start: 0.000000, bitrate: 2191 kb/s
    Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1920x800
[SAR 1:1 DAR 12:5], 2091 kb/s, 23.98 fps, 23.98 tbr, 24k tbn, 47.95 tbc
      handler_name    : mkv.264#trackID=1:fps=23.976@GPAC0.5.1-DEV-rev4283
    Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 95
 kb/s
      creation_time   : 2013-03-05 03:17:38
      handler_name    : Sound Media Handler
this one, don't play:
ble-zlib
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Django.Unchained.2012.1080p.BluRay.x264
.YIFY.mp4':
    major_brand     : isom
    minor_version   : 1
    creation_time   : 2013-03-26 12:09:32
  Duration: 02:45:22.79, start: 0.000000, bitrate: 1906 kb/s
[SAR 1:1 DAR 12:5], 1806 kb/s, 23.98 fps, 23.98 tbr, 24k tbn, 47.95 tbc
      handler_name    : unchained.2012.1080p.bluray.x264-sparks.mkv.264#trackID=
    Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 96
 kb/s
      creation_time   : 2013-03-26 07:10:36
i didn't see any diference, but perhaps i'm missing something.
edit: here is the analysis with media info
filesr.7z
the two htmls results from mediainfo
(1.74 KiB) Downloaded 550 times
Post Thu Apr 11, 2013 6:37 pm
Please in future, extract MediaInfo in text format in english langage.
I don't know why these two files are not play in same way... :(
agucortes
Post Thu Apr 11, 2013 8:07 pm
i've tried some modes in the profile, but nothing seems to make it work properly.
here is the media info in english for the two files.
this one use transcode:
Complete name                            : D:\MediaCenter\Peliculas\Django Unchained (2012) [1080p]\Django.Unchained.2012.1080p.BluRay.x264.YIFY.mp4
Format profile                           : Base Media
Codec ID                                 : isom
File size                                : 2.20 GiB
Duration                                 : 2h 45mn
Overall bit rate                         : 1 907 Kbps
Encoded date                             : UTC 2013-03-26 12:09:32
Tagged date                              : UTC 2013-03-26 12:09:32
Format profile                           : High@L4.0
Format settings, ReFrames                : 5 frames
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Duration                                 : 2h 45mn
Bit rate                                 : 1 807 Kbps
Maximum bit rate                         : 12.2 Mbps
Height                                   : 800 pixels
Display aspect ratio                     : 2.40:1
Bits/(Pixel*Frame)                       : 0.049
Stream size                              : 2.09 GiB (95%)
Title                                    : unchained.2012.1080p.bluray.x264-sparks.mkv.264#trackID=1:fps=23.976@GPAC0.5.1-DEV-rev4283
Writing library                          : x264 core 129 r2245 bc13772
Encoding settings                        : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=1807 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Tagged date                              : UTC 2013-03-26 12:09:53
Codec ID                                 : 40
Duration                                 : 2h 45mn
Bit rate                                 : 96.0 Kbps
Maximum bit rate                         : 136 Kbps
Stream size                              : 114 MiB (5%)
Encoded date                             : UTC 2013-03-26 07:10:36
this one not:
Complete name                            : D:\MediaCenter\Peliculas\Hitchcock (2012) [1080p]\Hitchcock.2012.1080p.BluRay.x264.YIFY.mp4
Codec ID                                 : isom
File size                                : 1.51 GiB
Duration                                 : 1h 38mn
Overall bit rate                         : 2 191 Kbps
Encoded date                             : UTC 2013-03-05 05:56:31
Tagged date                              : UTC 2013-03-05 05:56:31
Codec ID                                 : avc1
Duration                                 : 1h 38mn
Bit rate                                 : 2 092 Kbps
Maximum bit rate                         : 15.5 Mbps
Height                                   : 800 pixels
Bits/(Pixel*Frame)                       : 0.057
Stream size                              : 1.44 GiB (95%)
Title                                    : mkv.264#trackID=1:fps=23.976@GPAC0.5.1-DEV-rev4283
Encoding settings                        : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=2092 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Tagged date                              : UTC 2013-03-05 05:57:00
Codec ID                                 : 40
Duration                                 : 1h 38mn
Maximum bit rate                         : 153 Kbps
Stream size                              : 67.4 MiB (4%)
Encoded date                             : UTC 2013-03-05 03:17:38
i keep looking forward any solution.
Thanks for answering.
Post Thu Apr 11, 2013 10:56 pm
Do you have hardsubs enabled? maybe the one that transcodes has a subtitle file.
agucortes
Post Fri Apr 12, 2013 11:37 am
Yes, but in both cases have subtitles files. I already tried that.
That's why i'm thinking only in the video file
Post Fri Apr 12, 2013 5:25 pm
So do you have subtitles enabled? try to disable them
agucortes
Post Sat Apr 13, 2013 1:00 am
Yes.. you hit in the nail!
so, with subtitles it always transcode the movie, just to paste them.
There is any chance to configure the transcode so the video and audio are copied as is? i mean, with no decode and encode.
slyguy42o
Post Sat Apr 13, 2013 5:20 pm
when it's transcoding with subtitles... it means that the device your playing it on doesn't support pulling subs from a source so they must be burned into the video.. in order to do this... the video has to be transcoded so that the resulting output can have the subs burned into the play back stream
it's very strange that two exact same movies are triggering transcoding differently due to the sub title file. here's an idea. switch the sub title files between the movies and rename them accordingly and see if the problem follows the subtitle file and not the movie itself.
If this turns out to be the case, post the file here so we can try to figure out why it's triggering a transcode.
agucortes
Post Sun Apr 14, 2013 4:58 pm
Well... i don't know what i do, but now is transcoding allways with the subtitle.
So i'll paste the subtitles outside serviio and all solved.
Thanks for helping me
