Serviio server on pc, can't be seen on Galaxy S2 mobile
firefrog
Post Thu Apr 11, 2013 7:53 pm
Hey folks,
I'm just trying to get serviio and some clients on my mobile to work together. Serviio itself works without any problems (I can watch movies on my Bravia TV without any issue), but I can't make my phone find the server. I tried several clients (ArkMC, MediaHouse, AndroMote, UPnPlay and some others I already de-installed again) but none even finds the stream. ServiiDroid works, after I entered the IP adress of my PC manually, but that is not possible on any of the streaming clients. I am in the same WiFi, just before you ask ;) it shouldn't be of concern, but I'm using the trial-pro version of Serviio.
Anyone got an idea of what might be wrong or even got a solution for this?
Thanks in advance.
/edit: I just tried PS3 Media Server, which I used before but causes trouble with my TV, and it works without any problem.
/edit 2: as if it (whatever "it" is) knew i wrote this post. I tried to get it working all yesterday's night and half this day long, now all of a sudden it does. What the...? Well, thanks to you guys anyways for making it magically work or so :mrgreen: hope it doesn't seize to work as spontaneously as it started...
firefrog
Post Sat Apr 13, 2013 12:22 am
Re: Serviio server on pc, can't be seen on Galaxy S2 mobile
Okay, well - that was just a short flickering of "hey, I'm working, don't worry". As soon as I lay in bed and actually tried to use the wifi connection, it ceased. I completely don't understand this. =(
slyguy42o
Post Sat Apr 13, 2013 6:03 pm
have you tried ServiiGo?
viewtopic.php?f=17&t=6803
firefrog
Post Thu Apr 18, 2013 9:32 pm
Sorry, I've been busy lately.
I have not seen ServiioGo until now. It works, or at least it does find the server - but it won't play any videos. Occasionally UPnPlay and Skifta do find Serviio, but quite seldom and it takes quite a while (2-5min). I guess the most clients time out too early. The videos are being played without problems when (if) I get a connection with UPnPlay or Skifta, using the same renderers like I tell ServiiGo to use. Any Ideas? Does Serviio automatically transcode? It is set to do so in the console, but I'm not quite sure. What player works best on Android?
My router is set to forward port 8895, but I can't forward 1900 for it is "factory-provided" (at least that's the english translation I found). May that be an issue?
Post Fri Apr 19, 2013 1:01 pm
Post Thu Apr 25, 2013 7:06 pm
Sounds to me like you have the Windows Firewall on, and the the Serviio ports 23423 and 23424 are not open. They must be open in your router and the Windows Firewall if it is on.
Tachi
Post Thu Feb 06, 2014 3:45 pm
I have a similar problem with the standard Video Player app on my Samsung Galaxy S2 phone. I can see Serviio-server on the network but it won't show the contents. I get the following error message: Contents location is not available. Check network status and connected device.
Connecting with BubbleUPnP on my phone works flawless.
I have Serviio installed on my laptop with Windows 7 Enterprise (64-bit) with SP1. I checked following ports on my laptop mentioned with a port scanner: 8895, 23423 and 23424. They're all open. So that should not be the problem.
My phone (Samsung Galaxy S2 - GT-I9100) runs Android 4.1.2.
I have a detailed log, but I'm connected to the university network so I got a lot of non-relevant entries from other clients on the network in my log. I will post a new message as soons as I have a 'clean' log generated in my home network.
Are there any here who might know why the standard Video Player app won't work with Serviio, but BubbleUPnP does.
Tachi
Post Fri Feb 07, 2014 2:25 pm
As promised, the detailed log. It's quite big, so I split it in multiple messages.
2014-02-07 15:09:04,001 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2014-02-07 15:09:04,008 INFO  [MediaServer] ------------------------------------------------------------------------
2014-02-07 15:09:04,008 INFO  [MediaServer] Serviio DLNA media streaming server v 1.4 (rev. c307c4dd528d)
2014-02-07 15:09:04,008 INFO  [MediaServer] Petr Nejedly 2009-2013
2014-02-07 15:09:04,008 INFO  [MediaServer] http://www.serviio.org
2014-02-07 15:09:04,008 INFO  [MediaServer] Java 1.7.0_05-Oracle Corporation
2014-02-07 15:09:04,008 INFO  [MediaServer] OS Windows 7 amd64 6.1
2014-02-07 15:09:04,008 INFO  [MediaServer] File encoding: windows-1252
2014-02-07 15:09:04,008 INFO  [MediaServer] Headless mode enabled: true
2014-02-07 15:09:04,008 INFO  [MediaServer] User: ITACH-PC$
2014-02-07 15:09:04,009 INFO  [MediaServer] User home dir: C:\
2014-02-07 15:09:04,009 INFO  [MediaServer] Temp dir: C:\Windows\TEMP\
2014-02-07 15:09:04,009 INFO  [MediaServer] ------------------------------------------------------------------------
2014-02-07 15:09:04,100 INFO  [WebServer] Socket buffer set to 65535 bytes
2014-02-07 15:09:04,101 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2014-02-07 15:09:04,132 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2014-02-07 15:09:04,133 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2014-02-07 15:09:04,143 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2014-02-07 15:09:04,150 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2014-02-07 15:09:04,918 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2014-02-07 15:09:04,919 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2014-02-07 15:09:04,919 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2014-02-07 15:09:04,920 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2014-02-07 15:09:04,920 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2014-02-07 15:09:04,921 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2014-02-07 15:09:04,921 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2014-02-07 15:09:04,922 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2014-02-07 15:09:04,923 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2014-02-07 15:09:04,923 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2014-02-07 15:09:04,924 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2014-02-07 15:09:04,924 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2014-02-07 15:09:04,925 DEBUG [DBLogDAOImpl] Checking if script 'script-1.1.sql' has been run
2014-02-07 15:09:04,925 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.sql' has been run
2014-02-07 15:09:04,926 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.1.sql' has been run
2014-02-07 15:09:04,927 DEBUG [DBLogDAOImpl] Checking if script 'script-1.3.sql' has been run
2014-02-07 15:09:04,928 DEBUG [DBLogDAOImpl] Checking if script 'script-1.4.sql' has been run
2014-02-07 15:09:04,936 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2014-02-07 15:09:04,945 DEBUG [LicenseValidator] Validating license file (348 bytes)
2014-02-07 15:09:05,072 INFO  [MediaServer] ------------------------------------------------------------------------
2014-02-07 15:09:05,072 INFO  [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2014-02-07 15:09:05,077 DEBUG [LocalAddressResolverStrategy] Resolving host IP address using stored bound NIC name: net4-0
2014-02-07 15:09:05,206 INFO  [Device] Created UPnP Device with UUID: dbe6fccc-5bf2-3883-9929-daf5b210e7ed, bound address: 192.168.1.105
2014-02-07 15:09:05,507 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2014-02-07 15:09:05,508 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2014-02-07 15:09:05,558 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2014-02-07 15:09:05,558 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2014-02-07 15:09:05,567 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2014-02-07 15:09:05,568 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2014-02-07 15:09:05,570 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2014-02-07 15:09:05,570 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2014-02-07 15:09:05,571 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2014-02-07 15:09:05,571 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2014-02-07 15:09:05,572 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2014-02-07 15:09:05,572 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2014-02-07 15:09:05,574 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2014-02-07 15:09:05,574 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sam_ef
2014-02-07 15:09:05,576 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2014-02-07 15:09:05,576 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2014-02-07 15:09:05,576 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2014-02-07 15:09:05,576 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2014-02-07 15:09:05,577 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2014-02-07 15:09:05,577 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012
2014-02-07 15:09:05,580 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2014-02-07 15:09:05,580 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2013
2014-02-07 15:09:05,582 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013)' (id=sony2013)
2014-02-07 15:09:05,582 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2012
2014-02-07 15:09:05,583 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2014-02-07 15:09:05,583 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010
2014-02-07 15:09:05,585 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2014-02-07 15:09:05,585 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010us
2014-02-07 15:09:05,586 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2014-02-07 15:09:05,586 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2011
2014-02-07 15:09:05,586 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2014-02-07 15:09:05,586 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2014-02-07 15:09:05,587 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2014-02-07 15:09:05,587 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2014-02-07 15:09:05,588 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2014-02-07 15:09:05,588 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2014-02-07 15:09:05,589 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2014-02-07 15:09:05,589 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2014-02-07 15:09:05,589 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2014-02-07 15:09:05,589 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2014-02-07 15:09:05,590 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2014-02-07 15:09:05,590 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2014-02-07 15:09:05,591 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2014-02-07 15:09:05,591 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011
2014-02-07 15:09:05,591 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2014-02-07 15:09:05,591 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2010
2014-02-07 15:09:05,592 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2014-02-07 15:09:05,592 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile plps2010
2014-02-07 15:09:05,592 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2014-02-07 15:09:05,592 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2014-02-07 15:09:05,593 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2014-02-07 15:09:05,593 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2009
2014-02-07 15:09:05,594 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2014-02-07 15:09:05,594 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 22
2014-02-07 15:09:05,594 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2014-02-07 15:09:05,595 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011a
2014-02-07 15:09:05,595 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2014-02-07 15:09:05,596 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2014-02-07 15:09:05,596 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2010
2014-02-07 15:09:05,596 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2014-02-07 15:09:05,596 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012us
2014-02-07 15:09:05,597 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2014-02-07 15:09:05,597 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011us
2014-02-07 15:09:05,597 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2014-02-07 15:09:05,597 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonySTR
2014-02-07 15:09:05,598 INFO  [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2014-02-07 15:09:05,598 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonyCMT
2014-02-07 15:09:05,598 INFO  [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2014-02-07 15:09:05,598 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viziotv
2014-02-07 15:09:05,599 INFO  [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2014-02-07 15:09:05,599 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile win8metro
2014-02-07 15:09:05,600 INFO  [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2014-02-07 15:09:05,600 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile panasonicBDT220
2014-02-07 15:09:05,601 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2014-02-07 15:09:05,601 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile philips_streamium
2014-02-07 15:09:05,601 INFO  [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2014-02-07 15:09:05,601 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile roku
2014-02-07 15:09:05,602 INFO  [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2014-02-07 15:09:05,602 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile YamBD
2014-02-07 15:09:05,602 INFO  [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2014-02-07 15:09:05,602 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile TNDC
2014-02-07 15:09:05,603 INFO  [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2014-02-07 15:09:05,603 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile xbox_one
2014-02-07 15:09:05,604 INFO  [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2014-02-07 15:09:05,650 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2014-02-07 15:09:05,650 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile flv_player
2014-02-07 15:09:05,651 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2014-02-07 15:09:05,651 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile ios
2014-02-07 15:09:05,652 INFO  [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2014-02-07 15:09:05,652 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_standard
2014-02-07 15:09:05,652 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2014-02-07 15:09:05,653 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2014-02-07 15:09:05,653 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_hls
2014-02-07 15:09:05,654 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2014-02-07 15:09:05,654 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_gtv
2014-02-07 15:09:05,654 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2014-02-07 15:09:05,654 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile wp8
2014-02-07 15:09:05,655 INFO  [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2014-02-07 15:09:05,681 INFO  [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2014-02-07 15:09:05,681 INFO  [PluginCompilerThread] Started looking for plugins
2014-02-07 15:09:05,682 INFO  [UpdateChecker] Checking if a new version is available
2014-02-07 15:09:05,688 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2014-02-07 15:09:05,691 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2014-02-07 15:09:06,413 INFO  [FFMPEGWrapper] Found FFmpeg: ffmpeg version N-54096-ge41bf19 Copyright (c) 2000-2013 the FFmpeg developers
2014-02-07 15:09:06,416 DEBUG [DCRawWrapper] Invoking DCRAW to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/dcraw.exe
2014-02-07 15:09:06,417 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/dcraw.exe
2014-02-07 15:09:06,471 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2014-02-07 15:09:06,494 DEBUG [LocalAddressResolverStrategy] Resolving host IP address using stored bound NIC name: net4-0
2014-02-07 15:09:06,494 INFO  [WebServer] WebServer starting on port 8895
2014-02-07 15:09:06,615 INFO  [Device] Updated bound IP address of Device with UUID: dbe6fccc-5bf2-3883-9929-daf5b210e7ed, bound address: 192.168.1.105
2014-02-07 15:09:06,619 DEBUG [DiscoveryManager] UPNP device dbe6fccc-5bf2-3883-9929-daf5b210e7ed (192.168.1.105) is available
2014-02-07 15:09:06,619 INFO  [EventDispatcher] Starting EventDispatcher
2014-02-07 15:09:06,619 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2014-02-07 15:09:06,619 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2014-02-07 15:09:06,625 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2014-02-07 15:09:06,758 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net4 (Intel(R) Centrino(R) Ultimate-N 6300 AGN) and address 192.168.1.105, timeout = 0
2014-02-07 15:09:06,760 INFO  [RendererSearchSender] Searching for Renderer devices
2014-02-07 15:09:06,761 DEBUG [RendererSearchSender$RendererSearchWorker] Multicasting SSDP M-SEARCH using interface net4 (Intel(R) Centrino(R) Ultimate-N 6300 AGN) and address 192.168.1.105, timeout = 0
2014-02-07 15:09:06,771 DEBUG [RendererSearchSender$RendererSearchWorker] Sending 1 'm-search' messages
2014-02-07 15:09:06,777 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.105:50980s
2014-02-07 15:09:06,778 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.105:50980s
2014-02-07 15:09:06,820 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net4 (Intel(R) Centrino(R) Ultimate-N 6300 AGN) and address 192.168.1.105, timeout = 0
2014-02-07 15:09:06,821 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device dbe6fccc-5bf2-3883-9929-daf5b210e7ed
2014-02-07 15:09:07,700 INFO  [ServiioConsole] Initializing Serviio Console
2014-02-07 15:09:07,762 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44332
2014-02-07 15:09:07,769 INFO  [ServiioConsole] Starting Serviio Console
2014-02-07 15:09:08,623 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:08 (advertisement duration is 1800 sec.)
2014-02-07 15:09:08,911 DEBUG [SwingHelper] Choosing java look and feel: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
2014-02-07 15:09:10,056 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2014-02-07 15:09:10,056 DEBUG [ServiioConsole] Checking if server is running
2014-02-07 15:09:12,773 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2014-02-07 15:09:13,231 DEBUG [ServiioConsole] Retrieving console settings
2014-02-07 15:09:13,338 DEBUG [ServiioConsole] Setting console locale to be: en
2014-02-07 15:09:13,351 INFO  [Messages] Loaded console message bundle for locale: en
2014-02-07 15:09:13,351 DEBUG [ServiioConsole] Reading application data
2014-02-07 15:09:13,906 DEBUG [ServiioFrameView] Initializing main frame
2014-02-07 15:09:13,985 DEBUG [ServiioFrameView] System tray is supported
2014-02-07 15:09:14,214 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups
2014-02-07 15:09:15,013 DEBUG [RepositoryDAOImpl] Reading all Repositories
2014-02-07 15:09:15,070 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups for Repository (id = 5)
2014-02-07 15:09:15,162 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2014-02-07 15:09:15,714 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2014-02-07 15:09:16,012 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups
2014-02-07 15:09:16,818 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net4 (Intel(R) Centrino(R) Ultimate-N 6300 AGN) and address 192.168.1.105, timeout = 0
2014-02-07 15:09:16,819 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device dbe6fccc-5bf2-3883-9929-daf5b210e7ed
2014-02-07 15:09:18,619 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:08 (advertisement duration is 1800 sec.)
2014-02-07 15:09:21,615 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2014-02-07 15:09:21,808 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2014-02-07 15:09:22,349 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2014-02-07 15:09:22,363 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=0, titleKey=pc5dczc_media_library, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = null
2014-02-07 15:09:22,383 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A, titleKey=audio, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2014-02-07 15:09:22,391 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_ALB, titleKey=albums, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-02-07 15:09:22,397 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllAlbumsCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,405 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,411 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_A, titleKey=artists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-02-07 15:09:22,418 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,425 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,433 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,440 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,447 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=AL_A, titleKey=album_artists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-02-07 15:09:22,455 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListAlbumArtistInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,464 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListAlbumArtistsForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,472 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForAlbumArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,480 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,488 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-02-07 15:09:22,500 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=MUSIC_TRACK, idPrefix=FOL, recursive=true, cacheRegion=local_default
2014-02-07 15:09:22,507 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-02-07 15:09:22,519 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioGenresByNameCommand, containerClass=MUSIC_GENRE, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,528 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForGenreCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,535 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_C, titleKey=composers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-02-07 15:09:22,543 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListComposerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,551 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListComposersForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=COM, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,558 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForComposerCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,564 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForComposerAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,570 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-02-07 15:09:22,577 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,584 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForInitialCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,588 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_R, titleKey=random_music, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2014-02-07 15:09:22,594 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListRandomSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=no_cache
2014-02-07 15:09:22,599 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_RA, titleKey=random_albums, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2014-02-07 15:09:22,604 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListRandomAlbumsCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=no_cache
2014-02-07 15:09:22,609 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=no_cache
2014-02-07 15:09:22,614 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_LVA, titleKey=last_listened_albums, class=CONTAINER, cacheRegion=local_resetafterplay, browsable = null, editable = true
2014-02-07 15:09:22,619 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListLastViewedAlbumsCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_resetafterplay
2014-02-07 15:09:22,625 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_resetafterplay
2014-02-07 15:09:22,629 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_PL, titleKey=playlists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-02-07 15:09:22,635 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioPlaylistsCommand, containerClass=PLAYLIST_CONTAINER, itemClass=null, idPrefix=PL, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,640 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForPlaylistCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,645 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2014-02-07 15:09:22,650 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=MUSIC_TRACK, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2014-02-07 15:09:22,655 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_S, titleKey=All songs, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2014-02-07 15:09:22,660 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,665 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_AS, titleKey=Artist Songs, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2014-02-07 15:09:22,670 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsByNameCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART_S, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,675 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,680 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_AA, titleKey=Artist Albums, class=CONTAINER, cacheRegion=no_cache, browsable = false, editable = null
2014-02-07 15:09:22,685 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForArtistNameCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=no_cache
2014-02-07 15:09:22,691 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=no_cache
2014-02-07 15:09:22,696 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I, titleKey=image, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2014-02-07 15:09:22,700 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_A, titleKey=albums, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-02-07 15:09:22,706 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListFlatImageFoldersByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,711 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForFolderCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,716 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-02-07 15:09:22,721 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=PHOTO, idPrefix=FOL, recursive=true, cacheRegion=local_default
2014-02-07 15:09:22,726 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_Y, titleKey=year, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-02-07 15:09:22,731 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,737 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,742 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_T, titleKey=month, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-02-07 15:09:22,747 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,752 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationMonthsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=MON, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,757 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationMonthAndYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,762 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_PL, titleKey=playlists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-02-07 15:09:22,767 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagePlaylistsCommand, containerClass=PLAYLIST_CONTAINER, itemClass=null, idPrefix=PL, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,773 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForPlaylistCommand, containerClass=null, itemClass=PHOTO, idPrefix=S, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,777 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2014-02-07 15:09:22,783 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=PHOTO, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2014-02-07 15:09:22,787 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_AI, titleKey=All images, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2014-02-07 15:09:22,793 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListAllImagesCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,797 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V, titleKey=video, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2014-02-07 15:09:22,802 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-02-07 15:09:22,807 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,813 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForInitialCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,817 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_M, titleKey=movies, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-02-07 15:09:22,823 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListMovieVideosByNameCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,827 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_S, titleKey=series, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-02-07 15:09:22,838 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeriesByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SER, recursive=false, cacheRegion=local_resetafterplay
2014-02-07 15:09:22,851 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeasonsForSeriesCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SSN, recursive=false, cacheRegion=local_resetafterplay
2014-02-07 15:09:22,857 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListEpisodesForSeriesSeasonCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2014-02-07 15:09:22,867 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-02-07 15:09:22,873 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=local_default
2014-02-07 15:09:22,878 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LV, titleKey=last_viewed, class=CONTAINER, cacheRegion=local_resetafterplay, browsable = null, editable = true
2014-02-07 15:09:22,883 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastViewedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2014-02-07 15:09:22,888 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LA, titleKey=last_added, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-02-07 15:09:22,893 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastAddedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,898 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-02-07 15:09:22,903 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoGenresByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,909 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForGenreCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,913 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_R, titleKey=ratings, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-02-07 15:09:22,919 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoRatingsByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=RAT, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,924 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListMovieVideosForRatingCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,930 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_A, titleKey=actors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-02-07 15:09:22,935 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,940 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,946 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForActorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,950 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_D, titleKey=directors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-02-07 15:09:22,956 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,961 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,966 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForDirectorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,971 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_P, titleKey=producers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-02-07 15:09:22,979 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,984 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducersForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,990 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForProducerCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2014-02-07 15:09:22,995 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_RY, titleKey=release_years, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-02-07 15:09:23,001 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoReleaseYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=Y, recursive=false, cacheRegion=local_default
2014-02-07 15:09:23,006 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListMovieVideosForReleaseYearCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2014-02-07 15:09:23,011 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_PL, titleKey=playlists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2014-02-07 15:09:23,016 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoPlaylistsCommand, containerClass=PLAYLIST_CONTAINER, itemClass=null, idPrefix=PL, recursive=false, cacheRegion=local_default
2014-02-07 15:09:23,021 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForPlaylistCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2014-02-07 15:09:23,026 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2014-02-07 15:09:23,031 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2014-02-07 15:09:23,042 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2014-02-07 15:09:24,412 DEBUG [RepositoryDAOImpl] Reading all Repositories
2014-02-07 15:09:24,414 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups for Repository (id = 5)
2014-02-07 15:09:24,416 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2014-02-07 15:09:24,459 DEBUG [ServiioConsole] Reading application data
2014-02-07 15:09:24,459 DEBUG [RepositoryView$LibraryStatusCheckerThread] Starting library status checking thread
2014-02-07 15:09:26,878 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net4 (Intel(R) Centrino(R) Ultimate-N 6300 AGN) and address 192.168.1.105, timeout = 0
2014-02-07 15:09:26,879 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device dbe6fccc-5bf2-3883-9929-daf5b210e7ed
2014-02-07 15:09:28,679 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:02:58 (advertisement duration is 1800 sec.)
2014-02-07 15:09:32,778 INFO  [FeedUpdaterThread] Started looking for information about online resources
2014-02-07 15:09:32,778 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2014-02-07 15:09:32,778 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2014-02-07 15:09:32,779 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2014-02-07 15:09:32,779 DEBUG [RepositoryDAOImpl] Reading all Repositories
2014-02-07 15:09:32,780 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2014-02-07 15:09:32,780 DEBUG [RepositoryDAOImpl] Reading all Repositories
2014-02-07 15:09:32,781 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2014-02-07 15:09:32,784 DEBUG [PlaylistDAOImpl] Reading all Playlists
2014-02-07 15:09:32,786 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Videos\Films\Anlat Istanbul (2005)
2014-02-07 15:09:32,787 DEBUG [LibraryUpdatesCheckerThread] Looking for removed playlist files in repository: D:\Videos\Films\Anlat Istanbul (2005)
2014-02-07 15:09:32,787 DEBUG [PlaylistDAOImpl] Reading Playlists for Repository (id = 5)
2014-02-07 15:09:32,790 DEBUG [RepositoryDAOImpl] Marking Repository 5 as scanned with current timestamp
2014-02-07 15:09:32,809 DEBUG [LibraryUpdatesCheckerThread] Looking for removed/updated files in repository: D:\Videos\Films\Anlat Istanbul (2005)
2014-02-07 15:09:32,810 DEBUG [MediaItemDAOImpl] Reading MediaItems for Repository (id = 5)
2014-02-07 15:09:32,843 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 5)
2014-02-07 15:09:32,856 DEBUG [RepositoryDAOImpl] Marking Repository 5 as scanned with current timestamp
2014-02-07 15:10:32,785 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2014-02-07 15:10:32,785 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2014-02-07 15:10:43,045 INFO  [ServiioConsole] Initializing Serviio Console
2014-02-07 15:10:43,059 DEBUG [ApplicationInstanceManager] Port is already taken. Notifying first instance.
2014-02-07 15:10:43,065 DEBUG [ApplicationInstanceManager] Successfully notified first instance.
2014-02-07 15:10:43,065 INFO  [ServiioConsole] Exitting Serviio Console
2014-02-07 15:10:43,065 DEBUG [ApplicationInstanceManager] Shared key matched - new application instance found
2014-02-07 15:11:32,787 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2014-02-07 15:11:32,787 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
Tachi
Post Fri Feb 07, 2014 2:29 pm
2014-02-07 15:11:59,734 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.102:50020s
2014-02-07 15:11:59,739 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.102:50020
2014-02-07 15:11:59,938 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.102:47954s
2014-02-07 15:11:59,939 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.102:47954
2014-02-07 15:11:59,940 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:CE:1 from address /192.168.1.102:47954s
2014-02-07 15:11:59,942 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:CE:1 from address /192.168.1.102:50020s
2014-02-07 15:11:59,945 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.102:47954s
2014-02-07 15:11:59,945 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.102:47954
2014-02-07 15:11:59,948 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.102:50020s
2014-02-07 15:11:59,948 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.102:50020
2014-02-07 15:11:59,950 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dmc-samsung-com:device:SyncServer:1 from address /192.168.1.102:47954s
2014-02-07 15:11:59,952 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:samsung.com:device:MainTVServer2:1 from address /192.168.1.102:47954s
2014-02-07 15:11:59,955 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dmc-samsung-com:device:SyncServer:1 from address /192.168.1.102:50020s
2014-02-07 15:11:59,957 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:samsung.com:device:MainTVServer2:1 from address /192.168.1.102:50020s
2014-02-07 15:11:59,960 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:samsung.com:device:RemoteControlReceiver:1 from address /192.168.1.102:47954s
2014-02-07 15:11:59,962 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:samsung.com:device:RemoteControlReceiver:1 from address /192.168.1.102:50020s
2014-02-07 15:11:59,965 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.102:47954s
2014-02-07 15:11:59,967 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.102:50020s
2014-02-07 15:12:00,071 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:54095: GET /deviceDescription/dbe6fccc-5bf2-3883-9929-daf5b210e7ed HTTP/1.1, headers = [User-Agent: DLNADOC/1.50 SEC_HHP_"[Mobile]Tachifoon"/1.0,TIMEOUT: 3000,Host: 192.168.1.105:8895,Connection: Keep-Alive]]
2014-02-07 15:12:00,072 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2014-02-07 15:12:00,081 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device dbe6fccc-5bf2-3883-9929-daf5b210e7ed from 192.168.1.102 (headers = [User-Agent: DLNADOC/1.50 SEC_HHP_"[Mobile]Tachifoon"/1.0,TIMEOUT: 3000,Host: 192.168.1.105:8895,Connection: Keep-Alive])
2014-02-07 15:12:00,081 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2014-02-07 15:12:00,082 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [User-Agent: DLNADOC/1.50 SEC_HHP_"[Mobile]Tachifoon"/1.0,TIMEOUT: 3000,Host: 192.168.1.105:8895,Connection: Keep-Alive]
2014-02-07 15:12:00,083 DEBUG [RendererDAOImpl] Creating a new Renderer (uuid = bf4d555e-870a-4b00-bfad-560afd782a0f)
2014-02-07 15:12:00,126 INFO  [RendererManager] Stored a new renderer: uuid='bf4d555e-870a-4b00-bfad-560afd782a0f', name = 'Unrecognized device', ipAddress='192.168.1.102', profile = '1'
2014-02-07 15:12:00,126 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2014-02-07 15:12:00,249 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2014-02-07 15:12:00,290 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:42796: GET /serviceDescription/ConnectionManager HTTP/1.1, headers = [User-Agent: DLNADOC/1.50 SEC_HHP_"[Mobile]Tachifoon"/1.0,TIMEOUT: 3000,Host: 192.168.1.105:8895,Connection: Keep-Alive]]
2014-02-07 15:12:00,290 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2014-02-07 15:12:00,293 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2014-02-07 15:12:00,311 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2014-02-07 15:12:00,376 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:54551: GET /serviceDescription/ContentDirectory HTTP/1.1, headers = [User-Agent: DLNADOC/1.50 SEC_HHP_"[Mobile]Tachifoon"/1.0,TIMEOUT: 3000,Host: 192.168.1.105:8895,Connection: Keep-Alive]]
2014-02-07 15:12:00,376 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2014-02-07 15:12:00,380 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2014-02-07 15:12:00,407 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2014-02-07 15:12:00,475 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:46457: GET /serviceDescription/X_MS_MediaReceiverRegistrar HTTP/1.1, headers = [User-Agent: DLNADOC/1.50 SEC_HHP_"[Mobile]Tachifoon"/1.0,TIMEOUT: 3000,Host: 192.168.1.105:8895,Connection: Keep-Alive]]
2014-02-07 15:12:00,476 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2014-02-07 15:12:00,479 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service X_MS_MediaReceiverRegistrar
2014-02-07 15:12:00,488 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2014-02-07 15:12:00,529 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:56891: POST /serviceControl HTTP/1.1, headers = [USER-AGENT: DLNADOC/1.50 SEC_HHP_"[Mobile]Tachifoon"/1.0,Content-Type: text/xml; charset="utf-8",HOST: 192.168.1.105:8895,Content-Length: 287,SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#GetSearchCapabilities",Connection: close]]
2014-02-07 15:12:00,530 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2014-02-07 15:12:00,533 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSearchCapabilities"' from 192.168.1.102
2014-02-07 15:12:00,533 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2014-02-07 15:12:00,585 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2014-02-07 15:12:00,962 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:60260: SUBSCRIBE /serviceEventing/ContentDirectory HTTP/1.1, headers = [USER-AGENT: DLNADOC/1.50 SEC_HHP_"[Mobile]Tachifoon"/1.0,HOST: 192.168.1.105:8895,CALLBACK: <http://192.168.1.102:8467/evetSub>,NT: upnp:event,TIMEOUT: Second-300,Connection: close]]
2014-02-07 15:12:00,962 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2014-02-07 15:12:00,966 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent subscription request received for service ContentDirectory
2014-02-07 15:12:00,966 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription registered (uuid=641c4e35-d8df-4ac0-8497-425d810fe796) for service urn:upnp-org:serviceId:ContentDirectory with duration 300 reporting to http://192.168.1.102:8467/evetSub
2014-02-07 15:12:01,129 DEBUG [EventDispatcher] Sending event notification #0 for subscription 641c4e35-d8df-4ac0-8497-425d810fe796 to endpoint http://192.168.1.102:8467/evetSub
2014-02-07 15:12:01,147 DEBUG [RequestExecutor] Sending HTTP request to 192.168.1.102:8467
2014-02-07 15:12:01,385 DEBUG [EventDispatcher] Event notification sent and received successfully
2014-02-07 15:12:27,837 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net4 (Intel(R) Centrino(R) Ultimate-N 6300 AGN) and address 192.168.1.105, timeout = 0
2014-02-07 15:12:27,838 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device dbe6fccc-5bf2-3883-9929-daf5b210e7ed
2014-02-07 15:12:28,022 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2014-02-07 15:12:29,638 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:44 (advertisement duration is 1800 sec.)
2014-02-07 15:12:31,623 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2014-02-07 15:12:32,788 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2014-02-07 15:12:32,788 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2014-02-07 15:13:16,346 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.105:56430s
2014-02-07 15:13:19,346 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.105:56430s
2014-02-07 15:13:22,346 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.105:56430s
2014-02-07 15:13:25,371 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.105:56430s
2014-02-07 15:13:28,371 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.105:56430s
2014-02-07 15:13:31,371 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.105:56430s
2014-02-07 15:13:32,789 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2014-02-07 15:13:32,789 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2014-02-07 15:14:15,348 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.105:56430s
2014-02-07 15:14:18,348 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.105:56430s
2014-02-07 15:14:21,348 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.105:56430s
2014-02-07 15:14:24,372 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.105:56430s
2014-02-07 15:14:27,373 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.105:56430s
2014-02-07 15:14:30,373 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.105:56430s
2014-02-07 15:14:32,791 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2014-02-07 15:14:32,791 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2014-02-07 15:14:32,807 DEBUG [PlaylistDAOImpl] Reading all Playlists
2014-02-07 15:14:32,834 DEBUG [RepositoryDAOImpl] Reading all Repositories
2014-02-07 15:14:32,834 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Videos\Films\Anlat Istanbul (2005)
2014-02-07 15:14:32,835 DEBUG [RepositoryDAOImpl] Marking Repository 5 as scanned with current timestamp
2014-02-07 15:15:16,364 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.105:56430s
2014-02-07 15:15:19,364 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.105:56430s
2014-02-07 15:15:22,364 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.105:56430s
2014-02-07 15:15:25,375 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.105:56430s
2014-02-07 15:15:28,375 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.105:56430s
2014-02-07 15:15:31,375 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.105:56430s
2014-02-07 15:15:32,218 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.102:42585s
2014-02-07 15:15:32,219 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.102:42585
2014-02-07 15:15:32,220 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:CE:1 from address /192.168.1.102:42585s
2014-02-07 15:15:32,223 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.102:42585s
2014-02-07 15:15:32,223 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.102:42585
2014-02-07 15:15:32,225 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dmc-samsung-com:device:SyncServer:1 from address /192.168.1.102:42585s
2014-02-07 15:15:32,228 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:samsung.com:device:MainTVServer2:1 from address /192.168.1.102:42585s
2014-02-07 15:15:32,230 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:samsung.com:device:RemoteControlReceiver:1 from address /192.168.1.102:42585s
2014-02-07 15:15:32,233 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.102:42585s
2014-02-07 15:15:32,792 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2014-02-07 15:15:32,792 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2014-02-07 15:15:37,233 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.102:57355s
2014-02-07 15:15:37,233 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.102:57355
2014-02-07 15:15:37,235 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:CE:1 from address /192.168.1.102:57355s
2014-02-07 15:15:37,237 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.102:57355s
2014-02-07 15:15:37,238 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.102:57355
2014-02-07 15:15:37,240 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dmc-samsung-com:device:SyncServer:1 from address /192.168.1.102:57355s
2014-02-07 15:15:37,242 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:samsung.com:device:MainTVServer2:1 from address /192.168.1.102:57355s
2014-02-07 15:15:37,244 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:samsung.com:device:RemoteControlReceiver:1 from address /192.168.1.102:57355s
2014-02-07 15:15:37,247 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.102:57355s
2014-02-07 15:15:45,113 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:56492: GET /icon/largePNG HTTP/1.1, headers = [Host: 192.168.1.105:8895,Connection: Keep-Alive,User-Agent: AllShare Sample 1/1]]
2014-02-07 15:15:45,113 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2014-02-07 15:15:45,117 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon largePNG
2014-02-07 15:15:45,140 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:56492: GET /icon/largePNG HTTP/1.1, headers = [Host: 192.168.1.105:8895,Connection: Keep-Alive,User-Agent: AllShare Sample 1/1]]
2014-02-07 15:15:45,141 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2014-02-07 15:15:45,144 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon largePNG
2014-02-07 15:15:45,158 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:56492: GET /icon/largePNG HTTP/1.1, headers = [Host: 192.168.1.105:8895,Connection: Keep-Alive,User-Agent: AllShare Sample 1/1]]
2014-02-07 15:15:45,158 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2014-02-07 15:15:45,161 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon largePNG
2014-02-07 15:16:14,760 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net4 (Intel(R) Centrino(R) Ultimate-N 6300 AGN) and address 192.168.1.105, timeout = 0
2014-02-07 15:16:14,760 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device dbe6fccc-5bf2-3883-9929-daf5b210e7ed
2014-02-07 15:16:15,336 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:45519: SUBSCRIBE /serviceEventing/ContentDirectory HTTP/1.1, headers = [USER-AGENT: DLNADOC/1.50 SEC_HHP_"[Mobile]Tachifoon"/1.0,HOST: 192.168.1.105:8895,SID: uuid:641c4e35-d8df-4ac0-8497-425d810fe796,TIMEOUT: Second-300,Connection: close]]
2014-02-07 15:16:15,336 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2014-02-07 15:16:15,338 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent renewal request received for service ContentDirectory and subscription uuid:641c4e35-d8df-4ac0-8497-425d810fe796
2014-02-07 15:16:15,338 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription renewed for service urn:upnp-org:serviceId:ContentDirectory and subscription 641c4e35-d8df-4ac0-8497-425d810fe796
2014-02-07 15:16:16,561 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:02:59 (advertisement duration is 1800 sec.)
2014-02-07 15:16:32,794 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2014-02-07 15:16:32,794 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2014-02-07 15:17:32,795 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2014-02-07 15:17:32,795 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2014-02-07 15:18:32,796 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2014-02-07 15:18:32,796 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2014-02-07 15:19:16,172 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net4 (Intel(R) Centrino(R) Ultimate-N 6300 AGN) and address 192.168.1.105, timeout = 0
2014-02-07 15:19:16,172 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device dbe6fccc-5bf2-3883-9929-daf5b210e7ed
2014-02-07 15:19:17,972 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:31 (advertisement duration is 1800 sec.)
2014-02-07 15:19:32,797 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2014-02-07 15:19:32,797 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2014-02-07 15:19:32,807 DEBUG [PlaylistDAOImpl] Reading all Playlists
2014-02-07 15:19:32,836 DEBUG [RepositoryDAOImpl] Reading all Repositories
This should be sufficient. If you need more lines I can always add more.
curtmcgirt
Post Tue Mar 04, 2014 11:33 pm
Re: Serviio server on pc, can't be seen on Galaxy S2 mobile
+1
galaxy s3 4.3, default music and video players can "see" serviio as Nearby Devices, but neither can connect to serviio's content. bubbleupnp works fine on the same phone.
Iveky
Post Wed Mar 05, 2014 5:31 am
try also MediaHouse.
forget stock application?
mhawaldar
Post Sat May 17, 2014 7:14 pm
curtmcgirt wrote:+1
I have same problem with Galaxy S5 (4.4.2).
The default Video app in my S5 is able to see the serviio. But is not able to see any content published on my serviio server. I'm attaching screenshots for reference.
adsltrunks
Post Sat Mar 21, 2015 8:31 pm
Same here with note 3, note 10.1, S2 and S3
adsltrunks
Post Sat Mar 21, 2015 8:48 pm
The gallery app of asus tablet crash when try to access serviio
Users browsing this forum: No registered users and 166 guests
