Option to Quit Serviio Server
pteeson
Post Tue Apr 09, 2013 6:57 pm
I've suggested this before but here goes again.
On my MacPro Desktop Serviio server is still a process even after stopping it using the Console.
So If I want to re-boot the Mac, e.g. because Software Update wants me to do so before or after installing an update, then Serviio refuses to quit when asked to by the OS. There are of course other reasons to re-boot.
So I have to remember to use Activity Monitor to Force Quit the Serviio process. This is a harsh way to behave IMHO.
A simple option on the Console to Stop & Quit would be much more elegant. And how hard can it be to implement that?
respect....
Peter
Mac Pro OS X Yosemite, Toshiba 55SL500U
Post Wed Apr 10, 2013 8:31 am
Re: Option to Quit Serviio Server
So right click on the console system tray and Exit Serviio doesn't work for you?
pteeson
Post Fri Apr 12, 2013 1:29 am
(MacOS Lion 10.7.5) OK here's my try at clarifying what I mean.
The Serviio-Console app can be quit either by the usual method of Cmd-Q or your suggestion of Ctl- and then select Quit from the popup window.
But that is not what I was referring to. I mean the Serviio server process that shows up in Activity Monitor.
That process will persist even after the Console is Quit. It has the unfortunate side effect of not allowing a Restart or Shutdown of the MacOS.
It has to be Force Quit which is a rather harsh way to terminate a process.
Hope I've clarified things so that we are both on the same page.
If not please let me know. Thanks for your good work on this project.
respect...
Peter
Post Fri Apr 12, 2013 5:21 pm
Via the console, do you select Exit Serviio or Exit Serviio Console?
pteeson
Post Sat Apr 13, 2013 6:17 pm
I don't know how to insert an image of the screen when I do Ctl-click a.k.a. Right-Click for Mac.
Can send it to you by email if you wish.
I just get a pop-up window and it does not show either of those Exit choices you asked about.
I only see Serviio console 1.2.1, Options>, Show all windows, Hide, Quit.
If I mouse over the Options I see Keep in Dock, Open at login, Show in Finder
that's all. What must I be doing wrong to not see your Exit items?
respect....
Peter
Post Sun Apr 14, 2013 11:55 pm
When you start the console, it'll add Serviio icon to the system tray area (top right on Mac). Right click on that icon (not the icon in the dock at the bottom) to get the option.
pteeson
Post Mon Apr 15, 2013 3:01 pm
Thank you for guiding me. My confusion lay in the terminology.
On Mac it is referred to as the status area on the menu bar.
It is as you said....
respect...
Peter
pteeson
Post Thu Aug 15, 2013 11:04 pm
I just installed 1.3 but I no longer see the icon in the "system tray". Did this change in 1.3
Yes I did re-boot...
Pdter
Post Thu Aug 15, 2013 11:12 pm
The icon has been removed in 1.3. You can right click on the dock console icon instead now.
Return to Feature requests
