ERRORS:version mismatch, Invalid argument, error: parseerror
ThaDraGun
Post Mon May 14, 2012 11:52 pm
I installed Serviio_0.6.2_b7_arm-x19.qpkg on my QNAP TS-212
After I installed it I went to set it all up and these are the errors I was getting:
Under the status Tab:
Warning: Invalid argument supplied for foreach() in /share/HDA_DATA/.qpkg/Serviio/web_ui/view/status.php on line 144
Library Tab:
Warning: Invalid argument supplied for foreach() in /share/HDA_DATA/.qpkg/Serviio/web_ui/view/library.php on line 27
Presentation Tab:
Warning: Invalid argument supplied for foreach() in /share/HDA_DATA/.qpkg/Serviio/web_ui/view/presentation.php on line 8
It wouldn't allow me to do anything. Couldnt add library, couldnt even start the server.
So then I tried to update the webUI to see if that would fix the problem. I dont know if I did it right but bascally I just downloaded "WebUI v1.0.1" from http://wiki.serviio.org/doku.php?id=phpwebui and went to \\QNAPNAS\.qpkg\Serviio\web_ui and overwrote all the files.
Now I get different errors:
At the top it says
WARNING: There is a version mismatch between Serviio and Web UI. There may be a loss of functionality.
If I try anything, like add folders or even just to start the server it gives me an error.
error: parseerror
Error:Errror: Invaild XML
I have reinstalled Serviio several times, I even tried installing java. (not 100% sure if this is ok, but it did say install successful) and I have also reset my NAS several times.
Any ideas how to fix this???
papikoms
Post Fri Apr 12, 2013 11:32 am
Re: ERRORS:version mismatch, Invalid argument, error: parsee
Can someone please advise on a solution to this problem? I experience same.
