No audio transcoding possible?
Zek
Post Sun Jan 09, 2011 9:30 am
Is it possible to config the profile to not transcode at all if the container has both an audio and a video stream that is compatible with the client?
More specifically, I love the fact that Serviio is not transcoding my carefully encoded AVC streams in my MKV containers. However I'd love it if it just muxed my pure AC3 streams as well since my Bravia supports them. If it did this it would just be a a pure transmux operation and my NAS could even do that... More importantly I am hoping a mux would lessen my small AV sync isues I have.
Possible?
Cheers,
Zek
Sony Bravia KDL-55NX810 | Serviio 0.5 (rev. 975aa458693c) | Synology DS-1010+
Post Sun Jan 09, 2011 12:46 pm
Re: No audio transcoding possible?
Of course. whatever is specified as targetACodec will be used. If you don't provide it on the config or if the original codec is the same, it just copies the stream.
Zek
Post Mon Jan 10, 2011 8:18 am
That is awesome. If I have both a DTS stream and an AC3 stream in my MKV, does it just mux in the AC3 as-is then, regardless if it's the first audio stream?
Cheers,
Zek
Post Mon Jan 10, 2011 9:30 am
Serviio only knows about the first stream FFmpeg provides. Transcoding is triggered based on this track (so if there is another one that would make the file playable natively, it'll still transcode and mux the first track only)
Zek
Post Mon Jan 10, 2011 9:39 am
zip wrote:Serviio only knows about the first stream FFmpeg provides. Transcoding is triggered based on this track (so if there is another one that would make the file playable natively, it'll still transcode and mux the first track only)
Very good to know thanks. Going to remux my media and put a cheap 192k AC3 track first then.
Cheers,
Zek
Users browsing this forum: Majestic-12 [Bot] and 10 guests
