MKV keeps cutting off on Samsung UE40C6510
hyperjase
Post Thu Apr 11, 2013 5:03 pm
Hi all,
It seems for the past two versions (I always upgrade on request) that certain MKV files just keep cutting out after 4/5 minutes, if I go back to the same video then play again it'll cut out in a different place, jumping to the next video. I've NEVER had this issue prior to the recent updates, the only issue I did encounter was that pausing on my TV ended up crashing the video a few minutes after resuming playing.
I'm not fussed about the extra features that a "Pro" copy gives, I'm just very content with a good quality streamer as Serviio but recently it seems to have encountered issues.
If there's a way of downgrading I'll be more than happy to do that.
Many thanks,
HJ
Post Thu Apr 11, 2013 7:59 pm
Re: MKV keeps cutting off on Samsung UE40C6510
Might not be due to Serviio but could be:
- your TV firmware update
- your network quality
- your router quality
- traffic on your network
- etc.
hyperjase
Post Fri Apr 12, 2013 6:05 pm
Many thanks for the reply, however nothing other than the update of Serviio has changed, the network still works and hasn't been altered, no notification of update on TV. I can't categorically say that Serviio is at fault but out of the components it's the only thing that has changed.
Post Fri Apr 12, 2013 10:17 pm
Are you on wifi or wired? If wifi, it could be down to higher traffic on your channel.
hyperjase
Post Sat Apr 13, 2013 3:32 am
Always wired, don't trust or feel WiFi could handle streaming. I've never experienced this issue previously, Serviio has been a trusted part of my pc reinstall time after time, and this won't change - it's perfect for what I need, I just need to find out if it's Serviio causing this -- as I said there is an issue with pausing, it'll cut out after a few mins after unpausing.
rgill90
Post Mon Apr 15, 2013 2:22 pm
I've had exactly the same issues on samsung kit. The files which cut out are ALWAYS ones which i couldn't fast fwd or rwd. With my problem the file ALWAYS cut out in EXACTLY the same place though so it could be a different problem to yours. Someone else tried it with plex and the same file cut out so it looks like the problem is the Samsung, but i never prooved that conclusively. For me, renaming the files to .m2ts worked a treat - give it a go and let me know.
FYI my previous thread is here: viewtopic.php?f=10&t=8608
hyperjase
Post Mon Apr 15, 2013 6:48 pm
Thanks, I'll give that a go, for me it's more intermittent, no particular point of an MKV, just every 5/6 minutes (happened again last night). I have to admit that I have Virgin Superhub which seems to be really letting me down connection-wise so it's possible that may not be helping the issue (thanks Virgin!)
Cheers.
rgill90
Post Tue Apr 16, 2013 7:52 am
ah fair enough. A good thing to do to would be to run a continuous ping from your serviio server (mac? windows? nas machine?) to the ip address of your samsung whilst you're watching a movie. When the movie cuts out, ctrl-c and check the ping output and see if all the sequence numbers are in sequence and none are missing. Also check the packet loss %age. If there's no packet loss you can probably conclude your network is OK.
hyperjase
Post Tue Apr 16, 2013 5:21 pm
It's running from my PC, although this issue has only recently started and have been using it steadily for a few years now, that's why I'm confused but the "Shyte-Hub" provided by Virgin is definitely a suspect!
How would I run a continuous ping from my pc? I know how to ping, just not repeatedly.
Many thanks
rgill90
Post Wed Apr 17, 2013 12:17 pm
Love the nickname for the virgin kit.
OK - just do ping -t <ip address of samsung telly> and it'll just pinging until you ctrl-c it.
Also - are they fairly recent mkvs which are cutting out? Or are ones cutting out which previously worked? Anyway - give that rename a go as well.
hyperjase
Post Wed Apr 17, 2013 5:58 pm
Thanks will give that a go, I watched one last night with no issues, but the previous night it happened multiple times trying to watch a 1 hour programme - it does appear to be hit and miss.
I'll probably be trying again tonight so will let you know results.
