Unable to edit "remote" tab
avengingod
Post Sat Apr 13, 2013 11:26 am
first time posting in forum, I'm using Serviio free since a couple of weeks ago, and I can say it's a great piece of software, thank you all.
Now, i got a problem related to "remote" tab, I can edit every other tab in the program, the only thing I can't do is set password for local access, so even if i go to
http://localhost:23424/mediabrowser/ and I enter the password it keeps saying "unable to login, please check your password and try again".
Serviio is working, just tested it via Xbox on lan, the only problem is i can't access media browser from local pc, which is quite disappointing because I can't check if I add rss feeds correctly before moving to my xbox. Any help will be apreciated :P
Tnx for support
Post Sat Apr 13, 2013 12:29 pm
Re: Unable to edit "remote" tab
Remote access is a PRO only feature, hence the remote tab is disabled. Having said that, it would be a bit more user friendly if MediaBrowser actually said that it is disabled because of licence, rather than saying the password is wrong.
avengingod
Post Sat Apr 13, 2013 3:42 pm
oooook, thank you a lot for your answer :P
Users browsing this forum: No registered users and 331 guests
