Serviio not found after reboot
Twentet
Post Mon Apr 15, 2013 2:32 pm
I searched for this problem, but couldn't find a matching topic:
I have a trouble with Serviio. In my old home, I had a wired connection between my computer (WinXP) and my router. After installing Serviio, it worked immediately. I got an Philips HTS home cinema set, with also a wired connection with my router. Everything worked fine.
In my new home I changed the setting. My computer became wirreles due the distance between the router and computer. After connecting everything my phone and Philips HTS couldn't find Serviio anymore. After deleting and reinstalling Serviio, everything works fine again. But when I shut down the computer and restart it, the problem returns. My phone and Philips HTS just don't find Serviio. Deleting and reinstalling Serviio solves the problem, untill the next reboot. The fact is, that the computer does find the phone and Philips HTS!
I think the problem could might be in the changed setting (old: computer wired connection -> new: Computer wireless connection)
(I use a Sitecome 300N X2 USB wireless adapter)
slyguy42o
Post Mon Apr 15, 2013 5:08 pm
Re: Serviio not found after reboot
have you turned off the firewall on your serviio server?
Twentet
Post Mon Apr 15, 2013 5:22 pm
slyguy42o wrote:have you turned off the firewall on your serviio server?
Does Serviio got an own firewall? In my windows firewall I got the 8895 opened. But even with my Windows and router firewall disabled, it won't work.
Post Mon Apr 15, 2013 10:13 pm
Post detailed log of what happens after reboot. it's possible your network is not up yet when the service starts, or that it binds to another Ip address.
Twentet
Post Tue Apr 16, 2013 7:15 am
zip wrote:Post detailed log of what happens after reboot. it's possible your network is not up yet when the service starts, or that it binds to another Ip address.
Here is the log: (I tried to delete as many library warnings as I could:
2013-04-16 08:46:40,343 INFO [MediaServer] Serviio DLNA media streaming server v 1.2.1 (rev. a2aa56064460+)
2013-04-16 08:46:40,343 INFO [MediaServer] Petr Nejedly 2009-2013
2013-04-16 08:46:40,343 INFO [MediaServer] http://www.serviio.org
2013-04-16 08:46:40,343 INFO [MediaServer] Java 1.7.0_15-Oracle Corporation
2013-04-16 08:46:40,343 INFO [MediaServer] OS Windows XP x86 5.1
2013-04-16 08:46:40,343 INFO [MediaServer] File encoding: windows-1252
2013-04-16 08:46:40,359 INFO [MediaServer] Headless mode enabled: true
2013-04-16 08:46:40,359 INFO [MediaServer] User: SYSTEM
2013-04-16 08:46:40,359 INFO [MediaServer] User home dir: C:\Documents and Settings\LocalService.NT AUTHORITY
2013-04-16 08:46:40,359 INFO [MediaServer] Temp dir: C:\WINDOWS\TEMP\
2013-04-16 08:46:40,359 INFO [MediaServer] ------------------------------------------------------------------------
2013-04-16 08:46:41,187 INFO [WebServer] Socket buffer set to 65535 bytes
2013-04-16 08:46:41,218 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-04-16 08:46:41,375 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-04-16 08:46:41,375 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-04-16 08:46:41,453 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-04-16 08:46:56,640 INFO [MediaServer] ------------------------------------------------------------------------
2013-04-16 08:46:56,640 INFO [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2013-04-16 08:46:56,750 INFO [Device] Created UPnP Device with UUID: 12486d15-079e-3f2f-932c-6be88964d93a, bound address: 127.0.0.1
2013-04-16 08:46:58,343 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2013-04-16 08:46:58,593 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2013-04-16 08:46:58,656 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2013-04-16 08:46:58,656 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2013-04-16 08:46:58,656 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2013-04-16 08:46:58,671 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2013-04-16 08:46:58,687 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2013-04-16 08:46:58,703 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2013-04-16 08:46:58,703 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2013-04-16 08:46:58,718 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2013-04-16 08:46:58,734 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2013-04-16 08:46:58,734 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2013-04-16 08:46:58,734 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2013-04-16 08:46:58,734 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2013-04-16 08:46:58,734 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2013-04-16 08:46:58,734 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2013-04-16 08:46:58,734 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2013-04-16 08:46:58,734 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2013-04-16 08:46:58,734 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2013-04-16 08:46:58,734 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2013-04-16 08:46:58,734 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2013-04-16 08:46:58,734 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2013-04-16 08:46:58,734 INFO [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2013-04-16 08:46:58,734 INFO [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2013-04-16 08:46:58,734 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2013-04-16 08:46:58,734 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2013-04-16 08:46:58,750 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2013-04-16 08:46:58,750 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2013-04-16 08:46:58,750 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2013-04-16 08:46:58,750 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2013-04-16 08:46:58,750 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2013-04-16 08:46:58,750 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2013-04-16 08:46:58,750 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2013-04-16 08:46:58,750 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2013-04-16 08:46:58,750 INFO [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2013-04-16 08:46:58,781 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2013-04-16 08:46:58,781 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2013-04-16 08:46:58,781 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2013-04-16 08:46:58,781 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2013-04-16 08:46:58,937 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2013-04-16 08:46:58,953 INFO [UpdateChecker] Checking if a new version is available
2013-04-16 08:46:58,953 INFO [PluginCompilerThread] Started looking for plugins
2013-04-16 08:47:03,812 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-04-16 08:47:03,984 INFO [WebServer] WebServer starting on port 8895
2013-04-16 08:47:04,015 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-04-16 08:47:04,015 INFO [EventDispatcher] Starting EventDispatcher
2013-04-16 08:47:04,031 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-04-16 08:47:04,062 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface lo (MS TCP Loopback interface) and address 127.0.0.1, timeout = 0
2013-04-16 08:47:04,078 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2013-04-16 08:47:04,093 INFO [RendererSearchSender] Searching for Renderer devices
2013-04-16 08:47:30,156 INFO [FeedUpdaterThread] Started looking for information about online resources
2013-04-16 08:47:30,187 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-04-16 08:47:30,203 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-04-16 08:47:30,203 INFO [PlaylistMaintainerThread] Started looking playlist changes
at java.lang.NumberFormatException.forInputString(Unknown Source)
at java.lang.Integer.parseInt(Unknown Source)
at java.lang.Integer.valueOf(Unknown Source)
at org.serviio.library.local.metadata.extractor.embedded.MP3ExtractionStrategy.extractMetadata(MP3ExtractionStrategy.java:78)
at org.serviio.library.local.metadata.extractor.embedded.EmbeddedMetadataExtractor.retrieveAudioMetadata(EmbeddedMetadataExtractor.java:191)
at org.serviio.library.local.metadata.extractor.embedded.EmbeddedMetadataExtractor.retrieveMetadata(EmbeddedMetadataExtractor.java:129)
at org.serviio.library.local.metadata.extractor.MetadataExtractor.extract(MetadataExtractor.java:47)
at org.serviio.library.local.LibraryManager.extractMetadata(LibraryManager.java:225)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.addNewMediaFile(LibraryAdditionsCheckerThread.java:178)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.searchForNewFiles(LibraryAdditionsCheckerThread.java:145)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.searchForNewFiles(LibraryAdditionsCheckerThread.java:134)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.run(LibraryAdditionsCheckerThread.java:83)
at org.serviio.library.playlist.M3UParserStrategy.matches(M3UParserStrategy.java:61)
at org.serviio.library.playlist.PlaylistStrategyFactory.getStrategy(PlaylistStrategyFactory.java:21)
at org.serviio.library.playlist.PlaylistParser.parse(PlaylistParser.java:61)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.addNewPlaylistFile(LibraryAdditionsCheckerThread.java:226)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.searchForNewFiles(LibraryAdditionsCheckerThread.java:149)
2013-04-16 08:48:02,453 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video file type.
2013-04-16 08:51:24,953 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2013-04-16 08:51:26,609 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2013-04-16 09:06:10,921 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2013-04-16 09:06:10,921 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2013-04-16 09:06:10,937 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2013-04-16 09:06:10,937 INFO [EventDispatcher] Leaving EventDispatcher
2013-04-16 09:06:10,984 INFO [WebServer] WebServer shutting down
2013-04-16 09:06:12,468 INFO [WebServer] WebServer starting on port 8895
2013-04-16 09:06:12,468 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-04-16 09:06:12,468 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-04-16 09:06:12,468 INFO [EventDispatcher] Starting EventDispatcher
2013-04-16 09:06:12,484 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface lo (MS TCP Loopback interface) and address 127.0.0.1, timeout = 0
2013-04-16 09:06:12,484 INFO [RendererSearchSender] Searching for Renderer devices
2013-04-16 09:06:14,078 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
Post Tue Apr 16, 2013 11:49 am
It binds to 127.0.0.1. which is wrong. Can you post detailed log of the same? Just the portion of before it starts the library scanning.
Twentet
Post Wed Apr 17, 2013 3:10 pm
zip wrote:It binds to 127.0.0.1. which is wrong. Can you post detailed log of the same? Just the portion of before it starts the library scanning.
Sorry, i'm a little confused... This was a detailed log, right?
slyguy42o
Post Wed Apr 17, 2013 4:28 pm
127.0.0.1 is an internal loopback network.. if it's binding to this address it's not going to be able to communicate over your network.
What do you have selected for the bound IP address under the status tab of your console? you should have your primary network adapter selected.
Twentet
Post Wed Apr 17, 2013 4:48 pm
slyguy42o wrote:127.0.0.1 is an internal loopback network.. if it's binding to this address it's not going to be able to communicate over your network.
I got 2 options: automatically detected or 192.168.1.54 (Wireless adapter 300N X2 )
I got it saved on option number 2: the wireless adapter. But my phone and Philips Blue Ray still don't find Serviio. I got the app Serviidroid, which does show my server. Strange...
Twentet
Post Wed Apr 17, 2013 5:52 pm
Important edit: I found out that if I go to Windows services interface and stop Serviio and restart it, it immediately got found at the other devices! I think we are close to the problem now... Anybody?
Post Thu Apr 18, 2013 1:10 pm
Your log was not detailed log, there were no DEBUG statements.
It looks like it takes your network a long time to start. There is 30 seconds wait time in Serviio, which should wait for your preferren NIC to be available. So it might be too short for your case, but I need the log to confirm it.
As a solution you can try to change the Serviio service startup to Delayed.
Users browsing this forum: No registered users and 296 guests
