[SOLVED] Failed changing "profiles.xml"
Schichtie
Post Tue Apr 16, 2013 2:20 pm
Hello all together.
First of all, i´m a newbie in using serviio, so if my issues seems to be "very stupid", please don´t be too angry. ;)
I searched for this problem, but i couldn't find a matching topic, and also Wiki couldn´t help me, so:
I´ll tried to integrate the "BubbleUPnP" profile after an update to the new release 1.2.1, without success. I don´t know why. Maybe someone would like to explain me where´s my bug.
After replacing the original profiles.xml and rebooting Serviio opens a pop up saying "Cannot connect to Serviio server, it does not seem to be running. Exiting..." :shock:
Thank you very much!!!
profiles.xml
Including BubbleUPnP
(75.17 KiB) Downloaded 470 times
Post Tue Apr 16, 2013 3:54 pm
Re: Failed changing "profiles.xml"
Your profiles.xml is not 1.2.1 compatible, where did it come from ?
Post Tue Apr 16, 2013 3:56 pm
Insert following profile on official profiles.xml file :
   <Profile id="Android" name="BubbleUPnP" extendsProfileId="1" >
      <Detection>
           <HttpHeaders>
               <X-AV-Client-Info>BubbleUPnP?.*</X-AV-Client-Info>
           </HttpHeaders>
       </Detection>
         <Audio targetContainer="mp3">
            <Matches container="mp4" />
            <Matches container="flac" />
            <Matches container="ogg" />
            <Matches container="lpcm" />
            <Matches container="adts" />
            <Matches container="asf" />
         </Audio>
      <OnlineTranscoding>
      <!-- NOTE: Other rules are inherited from profile 1 -->
         <Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video" maxVBitrate="4000">
            <Matches container="flv" vCodec="vp6" />
            <Matches container="asf"/> <!-- to support mms:// streams -->
         <Video targetContainer="mpegts" targetACodec="ac3" >
            <Matches container="flv"/>
            <Matches container="mp4"/>
      </OnlineTranscoding>
      <Subtitles>
         <SoftSubs mime-type="text/srt" />
      </Subtitles>
Schichtie
Post Wed Apr 17, 2013 6:53 am
Good Morning Illico.
Thank you for your help.
The profiles.xml was the original of the version 1.2.1.??? I get it from "C:\Program Files\Serviio\config". It seems to bee an Installation issue.
So i try this evening to uninstall the whole Program and make a clean new installation. Then i will change with your profile.
At this moment, thank you very much!!! I´ll post my result!!
Have a nice day....
Schichtie
Post Wed Apr 17, 2013 2:25 pm
Hello again.
My test failed. Of course, my first profiles.xml was false, you´re right. But if I changed, the same issue: "Cannot connect to Serviio server, it does not seem to be running. Exiting..."
Where is my issue? :o (I don´t think it´s a problem with the programm, I think it´s one of the user! Me, myself and I....)
Thanks!!!!!!!!
profiles.xml
Changed file
(92.9 KiB) Downloaded 490 times
Schichtie
Post Wed Apr 17, 2013 2:38 pm
It runs, it runs!!!!!!!!
I don´t know why, after the third rebbot my Sytem makes no Problem!!!!! :D
Illico.... a whole lot of thanks!!!!!!!!! :mrgreen:
slyguy42o
Post Wed Apr 17, 2013 4:29 pm
Re: [SOLVED] Failed changing "profiles.xml"
if you have an invalid profile entry in your profiles.xml then serviio will not start correctly and you will get the "serviiio is not running" message
Users browsing this forum: No registered users and 224 guests
