unable to play live content from windows
psivide
Post Mon Apr 15, 2013 5:53 am
Hello
i am trying to play live tv stream with transcoding on regza rv733 and i have the next issue.
then iplay . m3u8 links everything work ok to the tv but when i try to play stream like
http://212.79.96.134:8003
http://212.79.96.134:8004
the tv can not play it.
Is any script for serviio on windows ???
thank you
psivide
slyguy42o
Post Mon Apr 15, 2013 4:59 pm
Re: unable to play live content from windows
please post of copy of your serviio logs
psivide
Post Tue Apr 16, 2013 3:03 pm
Thank You for you answer.
i have enter the url again
<item>
<title>Nova</title>
<link>http://gogo.jksw.cz:8003</link>
<media:thumbnail url="http://www.lyngsat-logo.com/logo/tv/nn/nova_tv_cz.jpg" />
<enclosure type="video/mp4" url="http://gogo.jksw.cz:8003"/>
</item>
and the stream started for 10-15 sec and after show the error message
from the serviio log file i have the next :
2013-04-16 17:49:26,845 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2013-04-16 17:49:26,945 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2013-04-16 17:49:27,045 INFO [PlaylistMaintainerThread] Finished looking for playlist changes
2013-04-16 17:49:27,156 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-04-16 17:49:27,159 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-04-16 17:49:27,167 INFO [PlaylistMaintainerThread] Started looking playlist changes
2013-04-16 17:49:27,231 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video codec.
2013-04-16 17:50:27,402 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video codec.
2013-04-16 17:51:27,566 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video codec.
2013-04-16 17:52:27,728 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video codec.
2013-04-16 17:53:27,914 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video codec.
thank you
psivide
slyguy42o
Post Tue Apr 16, 2013 4:03 pm
use this guide to provide detailed logs on the issue.
viewtopic.php?f=5&t=7
psivide
Post Tue Apr 16, 2013 5:20 pm
i have change to debug
when i start the stream in the "regna profile" i have direct error issue - no video start
log
2013-04-16 20:00:09,059 INFO [ServiioConsole] Starting Serviio Console
2013-04-16 20:00:10,604 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2013-04-16 20:00:12,086 INFO [Messages] Loaded console message bundle for locale: en
2013-04-16 20:00:34,322 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2013-04-16 20:00:35,180 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2013-04-16 20:06:53,046 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error. Detailed output follows.
'C:\Program' is not recognized as an internal or external command,
operable program or batch file.
and when start the stream with generic dlna profile the video start and work for 15 sec ( but chopsy ) and after with the same error
2013-04-16 20:09:16,439 INFO [WebServer] WebServer shutting down
2013-04-16 20:09:16,439 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2013-04-16 20:09:16,512 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2013-04-16 20:09:16,513 INFO [EventDispatcher] Leaving EventDispatcher
2013-04-16 20:09:16,513 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2013-04-16 20:09:16,551 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-04-16 20:09:16,554 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-04-16 20:09:16,554 INFO [WebServer] WebServer starting on port 8895
2013-04-16 20:09:16,556 INFO [EventDispatcher] Starting EventDispatcher
2013-04-16 20:09:16,584 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth2 (Broadcom NetLink (TM) Gigabit Ethernet) and address 192.168.7.103, timeout = 0
2013-04-16 20:09:16,588 INFO [RendererSearchSender] Searching for Renderer devices
2013-04-16 20:09:19,503 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
thank you
psivide
slyguy42o
Post Tue Apr 16, 2013 9:25 pm
This looks like some kind of an issue, but I'll need someone with a bit more experience with the inner workings to comment on where the problem lies.
Post Tue Apr 16, 2013 10:48 pm
it's not a debug log still
psivide
Post Wed Apr 17, 2013 10:24 am
ok here it is ( i am sorry for bf !!!!)
2013-04-17 13:17:18,857 INFO [WebServer] WebServer shutting down
2013-04-17 13:17:18,858 DEBUG [DiscoveryManager] UPNP device b778a581-1a93-3788-9d8a-04bf1563eb04 (192.168.7.103) is unavailable
2013-04-17 13:17:18,858 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2013-04-17 13:17:18,858 DEBUG [DiscoverySSDPMessageListener] Socket closed: socket closed
2013-04-17 13:17:18,858 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2013-04-17 13:17:18,859 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-04-17 13:17:18,860 DEBUG [LocalContentCacheDecorator] Cleared cache (local_default)
2013-04-17 13:17:18,871 INFO [EventDispatcher] Leaving EventDispatcher
2013-04-17 13:17:18,873 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2013-04-17 13:17:18,906 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP byebye using interface eth2 (Broadcom NetLink (TM) Gigabit Ethernet) and address capt, timeout = 0
2013-04-17 13:17:18,908 DEBUG [DiscoveryManager] UPNP device b778a581-1a93-3788-9d8a-04bf1563eb04 (192.168.7.103) is available
2013-04-17 13:17:18,910 INFO [WebServer] WebServer starting on port 8895
2013-04-17 13:17:18,918 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-04-17 13:17:18,919 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-04-17 13:17:18,958 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth2 (Broadcom NetLink (TM) Gigabit Ethernet) and address 192.168.7.103, timeout = 0
2013-04-17 13:17:18,982 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth2 (Broadcom NetLink (TM) Gigabit Ethernet) and address 192.168.7.103, timeout = 0
2013-04-17 13:17:18,982 INFO [RendererSearchSender] Searching for Renderer devices
2013-04-17 13:17:18,982 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device b778a581-1a93-3788-9d8a-04bf1563eb04
2013-04-17 13:17:18,983 INFO [EventDispatcher] Starting EventDispatcher
2013-04-17 13:17:18,983 DEBUG [RendererSearchSender$RendererSearchWorker] Multicasting SSDP M-SEARCH using interface eth2 (Broadcom NetLink (TM) Gigabit Ethernet) and address 192.168.7.103, timeout = 0
2013-04-17 13:17:18,984 DEBUG [RendererSearchSender$RendererSearchWorker] Sending 1 'm-search' messages
2013-04-17 13:17:18,984 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.7.103:49266s
2013-04-17 13:17:18,985 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.7.103:49266s
2013-04-17 13:17:19,717 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2013-04-17 13:17:20,785 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:08 (advertisement duration is 1800 sec.)
2013-04-17 13:17:24,985 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2013-04-17 13:17:25,766 INFO [FeedUpdaterThread] Started looking for information about online resources
2013-04-17 13:17:25,766 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-04-17 13:17:25,768 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-04-17 13:17:25,770 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-04-17 13:17:25,772 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-04-17 13:17:25,777 INFO [PlaylistMaintainerThread] Started looking playlist changes
2013-04-17 13:17:25,779 DEBUG [PlaylistDAOImpl] Reading all Playlists
2013-04-17 13:17:25,790 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-04-17 13:17:25,790 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-04-17 13:17:25,819 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2013-04-17 13:17:25,829 DEBUG [OnlineContentCacheDecorator] Stored online content 'http://212.79.96.134:8003/' in the cache (online_feeds), returning it
2013-04-17 13:17:28,968 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth2 (Broadcom NetLink (TM) Gigabit Ethernet) and address 192.168.7.103, timeout = 0
2013-04-17 13:17:28,968 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device b778a581-1a93-3788-9d8a-04bf1563eb04
2013-04-17 13:17:29,549 DEBUG [AbstractCDSLibraryIndexingListener] Library updated, notifying CDS
2013-04-17 13:17:30,769 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:08 (advertisement duration is 1800 sec.)
2013-04-17 13:17:38,968 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth2 (Broadcom NetLink (TM) Gigabit Ethernet) and address 192.168.7.103, timeout = 0
2013-04-17 13:17:38,969 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device b778a581-1a93-3788-9d8a-04bf1563eb04
2013-04-17 13:17:40,769 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:04:03 (advertisement duration is 1800 sec.)
2013-04-17 13:18:02,514 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.7.120:32771s
2013-04-17 13:18:02,517 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.7.120:32771
2013-04-17 13:18:02,616 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.7.120:32771s
2013-04-17 13:18:02,616 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.7.120:32771
2013-04-17 13:18:02,963 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:byebye) message from Renderer 7728bbf4-a04d-11de-9850-e89d8797fa73 from address /192.168.7.120:32773
2013-04-17 13:18:03,602 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:byebye) message from Renderer 7728bbf4-a04d-11de-9850-e89d8797fa73 from address /192.168.7.120:32773
2013-04-17 13:18:03,920 DEBUG [ServiioHttpService] Incoming request from /192.168.7.120:50249: GET /deviceDescription/b778a581-1a93-3788-9d8a-04bf1563eb04 HTTP/1.1, headers = [HOST: 192.168.7.103:8895,USER-AGENT: UPnP/1.0 DLNADOC/1.50 Intel_SDK_for_UPnP_devices/1.2]]
2013-04-17 13:18:03,920 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.7.120
2013-04-17 13:18:03,927 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device b778a581-1a93-3788-9d8a-04bf1563eb04 from 192.168.7.120 (headers = [HOST: 192.168.7.103:8895,USER-AGENT: UPnP/1.0 DLNADOC/1.50 Intel_SDK_for_UPnP_devices/1.2])
2013-04-17 13:18:03,927 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.7.120
2013-04-17 13:18:03,928 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.7.103:8895,USER-AGENT: UPnP/1.0 DLNADOC/1.50 Intel_SDK_for_UPnP_devices/1.2]
2013-04-17 13:18:03,929 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.7.120
2013-04-17 13:18:04,218 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:byebye) message from Renderer 7728bbf4-a04d-11de-9850-e89d8797fa73 from address /192.168.7.120:32773
2013-04-17 13:18:04,243 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Toshiba REGZA'
2013-04-17 13:18:04,253 DEBUG [ServiioHttpService] Incoming request from /192.168.7.120:50249: GET /serviceDescription/ConnectionManager HTTP/1.1, headers = [HOST: 192.168.7.103:8895,USER-AGENT: UPnP/1.0 DLNADOC/1.50 Intel_SDK_for_UPnP_devices/1.2]]
2013-04-17 13:18:04,254 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.7.120
2013-04-17 13:18:04,254 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2013-04-17 13:18:04,262 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2013-04-17 13:18:04,272 DEBUG [ServiioHttpService] Incoming request from /192.168.7.120:50249: GET /serviceDescription/ContentDirectory HTTP/1.1, headers = [HOST: 192.168.7.103:8895,USER-AGENT: UPnP/1.0 DLNADOC/1.50 Intel_SDK_for_UPnP_devices/1.2]]
2013-04-17 13:18:04,272 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.7.120
2013-04-17 13:18:04,273 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2013-04-17 13:18:04,273 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.7.120:32771s
2013-04-17 13:18:04,273 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.7.120:32771
2013-04-17 13:18:04,288 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2013-04-17 13:18:04,312 DEBUG [ServiioHttpService] Incoming request from /192.168.7.120:50249: POST /serviceControl HTTP/1.1, headers = [HOST: 192.168.7.103:8895,CONTENT-LENGTH: 269,CONTENT-TYPE: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities",USER-AGENT: UPnP/1.0 DLNADOC/1.50 Intel_SDK_for_UPnP_devices/1.2]]
2013-04-17 13:18:04,312 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.7.120
2013-04-17 13:18:04,313 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.7.120
2013-04-17 13:18:04,313 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.7.120
2013-04-17 13:18:04,376 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.7.120:32771s
2013-04-17 13:18:04,376 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.7.120:32771
2013-04-17 13:18:04,565 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-04-17 13:18:04,568 DEBUG [ServiioHttpService] Incoming request from /192.168.7.120:50249: POST /serviceControl HTTP/1.1, headers = [HOST: 192.168.7.103:8895,CONTENT-LENGTH: 269,CONTENT-TYPE: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities",USER-AGENT: UPnP/1.0 DLNADOC/1.50 Intel_SDK_for_UPnP_devices/1.2]]
2013-04-17 13:18:04,568 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.7.120
2013-04-17 13:18:04,568 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.7.120
2013-04-17 13:18:04,569 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.7.120
2013-04-17 13:18:04,764 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-04-17 13:18:04,903 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:alive) message from Renderer 7728bbf4-a04d-11de-9850-e89d8797fa73 from address /192.168.7.120:32774
2013-04-17 13:18:04,905 DEBUG [RendererManager] Adding renderer Renderer [uuid=7728bbf4-a04d-11de-9850-e89d8797fa73, ipAddress=192.168.7.120, name=40RV733, profileId=13, manuallyAdded=false, forcedProfile=true, enabled=true, accessGroupId=1] to list of active renderers
2013-04-17 13:18:05,518 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:alive) message from Renderer 7728bbf4-a04d-11de-9850-e89d8797fa73 from address /192.168.7.120:32774
2013-04-17 13:18:06,198 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:alive) message from Renderer 7728bbf4-a04d-11de-9850-e89d8797fa73 from address /192.168.7.120:32774
2013-04-17 13:18:06,279 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.7.120:32771s
2013-04-17 13:18:06,279 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.7.120:32771
2013-04-17 13:18:06,408 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.7.120:32771s
2013-04-17 13:18:06,408 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.7.120:32771
2013-04-17 13:18:09,554 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.7.120:32771s
2013-04-17 13:18:09,554 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.7.120:32771
2013-04-17 13:18:09,657 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.7.120:32771s
2013-04-17 13:18:09,657 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.7.120:32771
2013-04-17 13:18:09,762 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.7.120:32771s
2013-04-17 13:18:09,762 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.7.120:32771
2013-04-17 13:18:09,867 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.7.120:32771s
2013-04-17 13:18:09,867 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.7.120:32771
2013-04-17 13:18:09,999 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.7.120:32771s
2013-04-17 13:18:09,999 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.7.120:32771
2013-04-17 13:18:10,102 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.7.120:32771s
2013-04-17 13:18:10,102 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.7.120:32771
2013-04-17 13:18:11,630 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.7.120:32771s
2013-04-17 13:18:11,630 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.7.120:32771
2013-04-17 13:18:11,812 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.7.120:32771s
2013-04-17 13:18:11,812 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.7.120:32771
2013-04-17 13:18:12,011 DEBUG [ServiioHttpService] Incoming request from /192.168.7.120:50249: POST /serviceControl HTTP/1.1, headers = [HOST: 192.168.7.103:8895,CONTENT-LENGTH: 462,CONTENT-TYPE: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse",USER-AGENT: UPnP/1.0 DLNADOC/1.50 Intel_SDK_for_UPnP_devices/1.2]]
2013-04-17 13:18:12,012 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.7.120
2013-04-17 13:18:12,012 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.7.120
2013-04-17 13:18:12,217 DEBUG [ContentDirectory] Browse() called for renderer 40RV733 (profile 13) with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = upnp:class,dc:date,res,res@size, startIndex = 0, count = 120, sortCriteria =
2013-04-17 13:18:12,218 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-04-17 13:18:12,236 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2013-04-17 13:18:12,247 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=0, titleKey=pc5dczc_media_library, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = null
2013-04-17 13:18:12,269 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A, titleKey=audio, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-04-17 13:18:12,279 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_A, titleKey=artists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-04-17 13:18:12,290 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,300 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,310 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,317 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,324 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=AL_A, titleKey=album_artists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-04-17 13:18:12,333 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListAlbumArtistInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,340 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListAlbumArtistsForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,348 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForAlbumArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,355 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,363 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-04-17 13:18:12,371 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=MUSIC_TRACK, idPrefix=FOL, recursive=true, cacheRegion=local_default
2013-04-17 13:18:12,378 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-04-17 13:18:12,386 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioGenresByNameCommand, containerClass=MUSIC_GENRE, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,394 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForGenreCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,401 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_C, titleKey=composers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-04-17 13:18:12,409 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListComposerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,416 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListComposersForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=COM, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,424 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForComposerCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,433 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForComposerAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,440 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-04-17 13:18:12,448 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,455 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForInitialCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,462 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_R, titleKey=random, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-04-17 13:18:12,470 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListRandomSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=no_cache
2013-04-17 13:18:12,477 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_PL, titleKey=playlists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-04-17 13:18:12,485 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioPlaylistsCommand, containerClass=PLAYLIST_CONTAINER, itemClass=null, idPrefix=PL, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,492 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForPlaylistCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,499 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-04-17 13:18:12,507 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=MUSIC_TRACK, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2013-04-17 13:18:12,514 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_S, titleKey=All songs, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2013-04-17 13:18:12,522 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,530 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_AS, titleKey=Artist Songs, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2013-04-17 13:18:12,537 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsByNameCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART_S, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,545 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,553 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_ALB, titleKey=All albums, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2013-04-17 13:18:12,560 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllAlbumsCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,568 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,575 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I, titleKey=image, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-04-17 13:18:12,584 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_A, titleKey=albums, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-04-17 13:18:12,591 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListFlatImageFoldersByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,598 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForFolderCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,606 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-04-17 13:18:12,614 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=PHOTO, idPrefix=FOL, recursive=true, cacheRegion=local_default
2013-04-17 13:18:12,622 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_Y, titleKey=year, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-04-17 13:18:12,629 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,637 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,645 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_T, titleKey=month, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-04-17 13:18:12,652 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,661 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationMonthsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=MON, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,669 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationMonthAndYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,676 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_PL, titleKey=playlists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-04-17 13:18:12,685 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagePlaylistsCommand, containerClass=PLAYLIST_CONTAINER, itemClass=null, idPrefix=PL, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,692 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForPlaylistCommand, containerClass=null, itemClass=PHOTO, idPrefix=S, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,700 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-04-17 13:18:12,707 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=PHOTO, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2013-04-17 13:18:12,715 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_AI, titleKey=All images, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2013-04-17 13:18:12,723 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListAllImagesCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,730 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V, titleKey=video, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-04-17 13:18:12,739 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-04-17 13:18:12,746 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,754 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForInitialCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,763 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_M, titleKey=movies, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-04-17 13:18:12,770 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListMovieVideosByNameCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,779 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_S, titleKey=series, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-04-17 13:18:12,787 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeriesByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SER, recursive=false, cacheRegion=local_resetafterplay
2013-04-17 13:18:12,794 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeasonsForSeriesCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SSN, recursive=false, cacheRegion=local_resetafterplay
2013-04-17 13:18:12,803 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListEpisodesForSeriesSeasonCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2013-04-17 13:18:12,811 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-04-17 13:18:12,820 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=local_default
2013-04-17 13:18:12,828 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LV, titleKey=last_viewed, class=CONTAINER, cacheRegion=local_resetafterplay, browsable = null, editable = true
2013-04-17 13:18:12,836 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastViewedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2013-04-17 13:18:12,844 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LA, titleKey=last_added, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-04-17 13:18:12,852 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastAddedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,860 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-04-17 13:18:12,868 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoGenresByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,876 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForGenreCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,885 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_A, titleKey=actors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-04-17 13:18:12,893 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,902 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,910 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForActorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,918 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_D, titleKey=directors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-04-17 13:18:12,926 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,934 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,943 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForDirectorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,951 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_P, titleKey=producers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-04-17 13:18:12,959 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,968 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducersForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,976 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForProducerCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-04-17 13:18:12,984 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_PL, titleKey=playlists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-04-17 13:18:12,992 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoPlaylistsCommand, containerClass=PLAYLIST_CONTAINER, itemClass=null, idPrefix=PL, recursive=false, cacheRegion=local_default
2013-04-17 13:18:13,000 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForPlaylistCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=S, recursive=false, cacheRegion=local_default
2013-04-17 13:18:13,009 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-04-17 13:18:13,017 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2013-04-17 13:18:13,036 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2013-04-17 13:18:13,051 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2013-04-17 13:18:13,088 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2013-04-17 13:18:13,115 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-04-17 13:18:13,127 DEBUG [ServiioHttpService] Incoming request from /192.168.7.120:50249: POST /serviceControl HTTP/1.1, headers = [HOST: 192.168.7.103:8895,CONTENT-LENGTH: 517,CONTENT-TYPE: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse",USER-AGENT: UPnP/1.0 DLNADOC/1.50 Intel_SDK_for_UPnP_devices/1.2]]
2013-04-17 13:18:13,127 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.7.120
2013-04-17 13:18:13,128 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.7.120
2013-04-17 13:18:13,128 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.7.120
2013-04-17 13:18:13,324 DEBUG [ContentDirectory] Browse() called for renderer 40RV733 (profile 13) with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = res,res@protocolInfo,res@size,dc:date,res@duration,res@dlna:ifoFileURI,@dlna:dlnaManaged, startIndex = 0, count = 1, sortCriteria =
2013-04-17 13:18:13,324 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-04-17 13:18:13,327 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2013-04-17 13:18:13,328 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2013-04-17 13:18:13,333 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-04-17 13:18:14,699 DEBUG [ServiioHttpService] Incoming request from /192.168.7.120:50249: POST /serviceControl HTTP/1.1, headers = [HOST: 192.168.7.103:8895,CONTENT-LENGTH: 465,CONTENT-TYPE: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse",USER-AGENT: UPnP/1.0 DLNADOC/1.50 Intel_SDK_for_UPnP_devices/1.2]]
2013-04-17 13:18:14,699 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.7.120
2013-04-17 13:18:14,700 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.7.120
2013-04-17 13:18:14,700 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.7.120
2013-04-17 13:18:14,894 DEBUG [ContentDirectory] Browse() called for renderer 40RV733 (profile 13) with parameters: objectID = V_OF, browseFlag = BrowseDirectChildren, filter = upnp:class,dc:date,res,res@size, startIndex = 0, count = 120, sortCriteria =
2013-04-17 13:18:14,894 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-04-17 13:18:14,894 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2013-04-17 13:18:14,895 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2013-04-17 13:18:14,903 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000010001571 and profile Toshiba REGZA
2013-04-17 13:18:14,906 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://212.79.96.134:8003/: MPEG_PS_PAL
2013-04-17 13:18:14,906 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://212.79.96.134:8003/: MPEG_PS_NTSC
2013-04-17 13:18:14,908 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2013-04-17 13:18:14,909 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2013-04-17 13:18:14,916 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-04-17 13:18:14,923 DEBUG [ServiioHttpService] Incoming request from /192.168.7.120:50249: POST /serviceControl HTTP/1.1, headers = [HOST: 192.168.7.103:8895,CONTENT-LENGTH: 520,CONTENT-TYPE: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse",USER-AGENT: UPnP/1.0 DLNADOC/1.50 Intel_SDK_for_UPnP_devices/1.2]]
2013-04-17 13:18:14,923 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.7.120
2013-04-17 13:18:14,924 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.7.120
2013-04-17 13:18:14,925 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.7.120
2013-04-17 13:18:15,123 DEBUG [ContentDirectory] Browse() called for renderer 40RV733 (profile 13) with parameters: objectID = V_OF, browseFlag = BrowseDirectChildren, filter = res,res@protocolInfo,res@size,dc:date,res@duration,res@dlna:ifoFileURI,@dlna:dlnaManaged, startIndex = 0, count = 1, sortCriteria =
2013-04-17 13:18:15,123 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-04-17 13:18:15,124 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2013-04-17 13:18:15,125 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2013-04-17 13:18:15,126 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000010001571 and profile Toshiba REGZA
2013-04-17 13:18:15,127 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://212.79.96.134:8003/: MPEG_PS_PAL
2013-04-17 13:18:15,127 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://212.79.96.134:8003/: MPEG_PS_NTSC
2013-04-17 13:18:15,127 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2013-04-17 13:18:15,128 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2013-04-17 13:18:15,133 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-04-17 13:18:16,646 DEBUG [ServiioHttpService] Incoming request from /192.168.7.120:50249: POST /serviceControl HTTP/1.1, headers = [HOST: 192.168.7.103:8895,CONTENT-LENGTH: 520,CONTENT-TYPE: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse",USER-AGENT: UPnP/1.0 DLNADOC/1.50 Intel_SDK_for_UPnP_devices/1.2]]
2013-04-17 13:18:16,646 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.7.120
2013-04-17 13:18:16,646 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.7.120
2013-04-17 13:18:16,843 DEBUG [ContentDirectory] Browse() called for renderer 40RV733 (profile 13) with parameters: objectID = V_OF, browseFlag = BrowseDirectChildren, filter = res,res@protocolInfo,res@size,dc:date,res@duration,res@dlna:ifoFileURI,@dlna:dlnaManaged, startIndex = 0, count = 1, sortCriteria =
2013-04-17 13:18:16,843 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-04-17 13:18:16,844 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2013-04-17 13:18:16,845 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2013-04-17 13:18:16,846 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000010001571 and profile Toshiba REGZA
2013-04-17 13:18:16,847 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://212.79.96.134:8003/: MPEG_PS_PAL
2013-04-17 13:18:16,847 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://212.79.96.134:8003/: MPEG_PS_NTSC
2013-04-17 13:18:16,847 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2013-04-17 13:18:16,848 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2013-04-17 13:18:16,852 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-04-17 13:18:17,060 DEBUG [ServiioHttpService] Incoming request from /192.168.7.120:50250: GET /resource/1000000010001571/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.1, headers = [HOST: 192.168.7.103:8895,USER-AGENT: UPnP/1.0 DLNADOC/1.50 Intel_SDK_for_UPnP_devices/1.2,transferMode.dlna.org: Streaming]]
2013-04-17 13:18:17,060 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.7.120
2013-04-17 13:18:17,062 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.7.120
2013-04-17 13:18:17,066 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.7.120, Profile=Toshiba REGZA'
2013-04-17 13:18:17,068 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000010001571 and type 'MEDIA_ITEM' received
2013-04-17 13:18:17,068 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000010001571 (online)
2013-04-17 13:18:17,068 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2013-04-17 13:18:17,069 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000010001571, format MPEG_PS_PAL and profile Toshiba REGZA
2013-04-17 13:18:17,069 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file http://212.79.96.134:8003/
2013-04-17 13:18:17,069 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://212.79.96.134:8003/: MPEG_PS_PAL
2013-04-17 13:18:17,069 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://212.79.96.134:8003/: MPEG_PS_NTSC
2013-04-17 13:18:17,071 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000010001571 (online)
2013-04-17 13:18:17,071 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2013-04-17 13:18:17,072 DEBUG [VideoDeliveryEngine] Delivering item '1000000010001571' for client 'Identifier=192.168.7.120, Profile=Toshiba REGZA'
2013-04-17 13:18:17,072 DEBUG [VideoDeliveryEngine] Delivering file 'http://212.79.96.134:8003/' using transcoding
2013-04-17 13:18:17,073 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=192.168.7.120, Profile=Toshiba REGZA'
2013-04-17 13:18:17,076 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: http://212.79.96.134:8003/
2013-04-17 13:18:17,077 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -analyzeduration 10000000 -fflags +genpts -threads auto -i http://212.79.96.134:8003/ -y -c:v copy -c:a ac3 -b:a 192k -ac 2 -map 0:0 -map 0:1 -sn -f vob pipe:
2013-04-17 13:18:17,085 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error. Detailed output follows.
2013-04-17 13:18:17,085 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2013-04-17 13:18:25,814 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-04-17 13:18:25,831 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-04-17 13:18:25,831 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-04-17 13:18:25,832 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2013-04-17 13:18:43,577 DEBUG [StreamBasedTranscodingDeliveryStrategy] Transcoded stream is empty, connection may have been lost
2013-04-17 13:18:43,577 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://212.79.96.134:8003/: MPEG_PS_PAL
2013-04-17 13:18:43,577 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://212.79.96.134:8003/: MPEG_PS_NTSC
2013-04-17 13:18:43,578 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-04-17 13:18:43,578 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-04-17 13:18:43,579 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Date: Wed, 17 Apr 2013 10:18:43 GMT,Server: Windows Vista, UPnP/1.0 DLNADOC/1.50, Serviio/1.2.1,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-04-17 13:18:52,295 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.7.120:32771s
2013-04-17 13:18:52,295 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.7.120:32771
2013-04-17 13:18:52,397 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.7.120:32771s
2013-04-17 13:18:52,397 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.7.120:32771
2013-04-17 13:19:22,500 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.7.120:32771s
2013-04-17 13:19:22,500 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.7.120:32771
2013-04-17 13:19:22,603 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.7.120:32771s
2013-04-17 13:19:22,603 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.7.120:32771
2013-04-17 13:19:25,811 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-04-17 13:19:25,830 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-04-17 13:19:25,830 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-04-17 13:19:25,830 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2013-04-17 13:19:43,577 DEBUG [NonClosingPipedInputStream] Closing piped input stream and closing related feeder process
2013-04-17 13:19:52,705 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.7.120:32771s
2013-04-17 13:19:52,705 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.7.120:32771
2013-04-17 13:19:52,808 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.7.120:32771s
2013-04-17 13:19:52,808 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.7.120:32771
2013-04-17 13:20:22,910 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.7.120:32771s
2013-04-17 13:20:22,910 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.7.120:32771
2013-04-17 13:20:23,013 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.7.120:32771s
2013-04-17 13:20:23,013 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.7.120:32771
2013-04-17 13:20:25,808 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-04-17 13:20:25,828 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-04-17 13:20:25,828 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-04-17 13:20:25,828 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2013-04-17 13:20:53,115 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.7.120:32771s
2013-04-17 13:20:53,115 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.7.120:32771
2013-04-17 13:20:53,218 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.7.120:32771s
2013-04-17 13:20:53,218 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.7.120:32771
2013-04-17 13:21:25,805 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-04-17 13:21:25,826 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-04-17 13:21:25,826 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-04-17 13:21:25,826 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2013-04-17 13:21:44,629 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth2 (Broadcom NetLink (TM) Gigabit Ethernet) and address 192.168.7.103, timeout = 0
2013-04-17 13:21:44,630 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device b778a581-1a93-3788-9d8a-04bf1563eb04
2013-04-17 13:21:46,430 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:28 (advertisement duration is 1800 sec.)
2013-04-17 13:22:25,800 DEBUG [PlaylistDAOImpl] Reading all Playlists
2013-04-17 13:22:25,802 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-04-17 13:22:25,824 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-04-17 13:22:25,824 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-04-17 13:22:25,825 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
thank you
psivide
Post Wed Apr 17, 2013 10:51 am
Re: unable to play live content from windows
wow, weird. What Java are you on? Can you try to install the latest one?
Post Thu Apr 25, 2013 7:04 pm
Sounds to me like you have the Windows Firewall on, and the the Serviio ports 23423 and 23424 are not open. They must be open in your router and the Windows Firewall if it is on.
Return to General discussion
Users browsing this forum: Google [Bot] and 25 guests
