ILIVE - A Video Livestreams Server Collection
Both links work fine for me in ffmpeg and Serviio so there is something wrong with your setup. Suggest you post in relevant threads since this one is for ILIVE plugin problems.
Re: ILIVE - A Video Livestreams Server Collection
jhb50 wrote:Both links work fine for me in ffmpeg and Serviio so there is something wrong with your setup. Suggest you post in relevant threads since this one is for ILIVE plugin problems.
Ok thanks, I will move my problems over to the Panasonic thread. Damn Panasonic.
I see the folder and it opens up nicely-but cant really play anything.Trying sky sports 1 and few others no luck.
You have made 17 posts most of which say nothing works, so I suggest you either have a bad system or you have not setup as instructed. ILive works fine for me.
You might try testing your streams and checking the debug log as per my signature, to analyse your problems.
Thanx for the prompt reply-yes as a noob- I do have my problems.But a lot of media is working fine for me and even Ilive worked fine before.It may be those few channels.Let me try again and if not I will post the log.
Thank You for all your efforts.
Ok final verdict-most channels work as they take mighty long time to appear on screen sometimes more than 2 mins.Playboy tv didn't work and I dont expect everything to be working anyway.Patience is the key here.
Serviio takes about 5 seconds to start a stream playing on mediabrowser, so anything longer is due to your TV or the stream's source server. Ilive takes about 25 seconds for me.
Well than something is definitely wrong on my end-lol.You are going to hate me now-what is this mediabrowser ?how to setitup?
comes with serviio pro. Just open http://localhost:23424/mediabrowser/ in your browser.
Again you my friend is absolutely right.But why is it taking longer to play it as a media server thru my wdtv live+?Any tricks or fixes.
The WDTV live series has very small buffer allocation thats why it takes so long as its designed for local storage items as opposed to online media
Thanx for the prompt reply-so I should assume that there is no way around it.
V12 posted to support changed ip address.
Thanx a ton-master.You are on top of your game.
I'm not seeing anything here is it me or is it down
Na, it is down.
Both actually. Its back up now and V13 posted to support changes.
Thank you Master for the quick fix.Works like a charm.
Looks like it is losing channels
LOL what does that mean? Which of the 175 channels that are currently active on my system have you lost?
