[solved] file with accents not added to the library
thenamelessthing
Post Wed Apr 17, 2013 3:40 am
Hi! I have noticed when I have some files with accents they are not added to the library. If I remove the accent, it was added.
I use UTF-8 encoding for files name, this mean it's not the problem...
Any advices is appreciated!
Thanks you..
Last edited by thenamelessthing on Fri Apr 19, 2013 1:53 pm, edited 1 time in total.
My Setup : BDT220 Panasonic Bluray player, TC-L55ET5 and TC-L42ET5 Panasonic TV. My home media server run Serviio 1.4.2 Pro under GNU/Linux Ubuntu 14.04 LTS server x64 and the hardware is Amd 1045t Phenom II X6, 6Gb DDR3 1333 mhz on SSD and data on soft raid 5 (3x1tb).
Post Wed Apr 17, 2013 10:38 am
Re: file with accents not added to the library
read the FAQ
Post Wed Apr 17, 2013 11:32 am
thenamelessthing
Post Wed Apr 17, 2013 6:33 pm
I already read the faq. If I understand correctly, it's far better to name the files without the "episode name"? It's more simple to use name convention like: Spartacus S01E03.avi and not : Spartacus.S01E03.Légendes.avi He doesn't appreciate the accentued "é" character?
Post Fri Apr 19, 2013 12:44 pm
You don't need the episode names if you use online metadata.
thenamelessthing
Post Fri Apr 19, 2013 12:49 pm
yes, is what i have understand.
Thanks you.
Users browsing this forum: No registered users and 49 guests
