synology and transcoding
Post Fri Apr 05, 2013 8:51 am
Re: synology and transcoding
I think the NAS doesn't show the number of FFmpeg instances correctly, it starts just 1 for the first movie. Then, if you watch the same movie on another player, at the same time, it should just reuse the transcoded file from the first ffmpeg job. If it doesn't it might be a bug - in that case enable detailed log and try to reproduce it, then post the log here.
You would only have multiple (2) instances of FFmpeg if you run 2 different transcoded movies with 2 different players at the same time.
deibral
Post Sat Apr 20, 2013 11:55 pm
Have been away for a longer time. Will try to provide you with logs soon.
As for now I only have problems with playing 1080 files - CPU goes to 80-95% but the movie doesn't transcode on the fly - meaing it shutters. I am still looking for a solution.
I have noticed some other minor bugs: if the title of the movie or the directory, in which you have the movie file, contains characters like ',' (comma), '+' (plus) or "[]" (square bracket) the serviio will give errors (it will not play the movie saying that there is on access to the server).
For example sometimes using "," (comma) is usefull when the movie title is let say "The Avengers" and you want to make it sort from A to Z and change the directory title to "Avengers, The". In this situation servio will fail to play the movie inside the directory, but it will see the file in this directory. Still using Sony HX850.
Post Sun Apr 21, 2013 12:30 am
These failing movies, are they with burned subtitles on? Can you provide detailed log of this happening?
deibral
Post Sun Apr 21, 2013 12:36 am
You mean these 1080 or these with commas in the file name?
Will provide log in few days.
There is new version of ffmpeg (1.2) since 15/03 - doeas Servio 1.2.1 has it inside?
Post Sun Apr 21, 2013 12:41 am
well, both :-)
1.2.1 has FFmpeg 1.1
deibral
Post Sun Apr 21, 2013 12:49 am
Do you think ffmpeg 1.2 will bring better performance?
Post Mon Apr 22, 2013 12:01 pm
Don't think so, at least not drastically
Satras
Post Mon Dec 08, 2014 1:33 pm
Hey, sorry for bumping this thread but I got some questions regarding Synology and Serviio and was wondering if you could help.
Synology now got the 214/414 Play devices witch got an Hardware Encoder for x264 Videos, so I was wondering if Serviio could use this to speed up encoding ?
Do you believe 1080p/24 would be supported in real time ?
Also I saw that Synology lacks of DTS Transcoding, would Serviio do the it ?
Post Mon Dec 15, 2014 12:30 am
Patters would be the guy to answer this - I believe he was looking into this, but I think he found something that prevented it working correctly.
Satras
Post Mon Dec 15, 2014 8:30 am
Thanks, I contacted him.
patters
Post Wed Dec 17, 2014 6:22 pm
Hi - yes it does work though it was a little unstable. I have something built, but it won't hardware encode into an FLV container. This is fine for most DLNA devices, but it does mean that you can't use Serviio's Media Browser, since that uses a Flash Player. In my limited testing it did seem to work nicely for IOS devices.
I was holding back because I was in contact with Synology's developer support, but they haven't been able to fix the issue and had been delayed significantly by their own OS refresh project (Synology DSM 5.1). Their latest position was that I should wait until the DSM 5.1 sources have been released and that we would use those as a baseline for experimentation. I had hoped to release this by now but I am finding it very difficult to dedicate some time to it.
Satras
Post Thu Dec 18, 2014 9:03 am
Thanks for your Input.
This is a bummer, as I would need the transcoding feature just for the MediaBrowser. For everything else I got a WDTVLive, so no transcoding needed.
Which Synology NAS would you suggest for 1080p transcoding then ? I understood that the DS1515+ would do 3 * 1080p fine. Quiet expensive thing, I I just need transcoding every now and then when I'm not at home :S
Previous
