File not playing
railfrog
Post Sun Apr 21, 2013 1:44 pm
File not playing
Hi All
I have a file that does not play. I have posted the FFMPEG details.
What other information is needed?
C:\Program Files\Serviio\lib>ffmpeg.exe -i "C:\Users\Paul\Videos\Cloud.Atlas.201
2.720p.BluRay.x264-BiDA [PublicHD]\Cloud.Atlas.mkv"
ffmpeg version 1.1.1 Copyright (c) 2000-2013 the FFmpeg developers
built on Feb 5 2013 21:59:54 with gcc 4.7.2 (GCC)
p --enable-fontconfig --enable-libfreetype --enable-zlib --extra-libs='-lrtmp -l
polarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-
runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-
mingw32- --pkg-config=pkg-config
libavutil 52. 13.100 / 52. 13.100
libavcodec 54. 86.100 / 54. 86.100
libavformat 54. 59.106 / 54. 59.106
libavdevice 54. 3.102 / 54. 3.102
libavfilter 3. 32.100 / 3. 32.100
libswscale 2. 1.103 / 2. 1.103
Input #0, matroska,webm, from 'C:\Users\Paul\Videos\Cloud.Atlas.2012.720p.BluRay
.x264-BiDA [PublicHD]\Cloud.Atlas.mkv':
creation_time : 2012-12-21 00:20:30
Duration: 02:52:07.35, start: 0.000000, bitrate: 4749 kb/s
Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x532 [SAR 1:1 DAR 320:133
], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 448 kb/s (default)
Post Mon Apr 22, 2013 12:03 am
Re: File not playing
  • what renderer (tv, player,etc) are you using;
  • what profile have you selected in Serviio for this device;
  • what other profiles have you tried (always try Generic to see what that does with the file);
  • what do you mean by not playing. Does it show up in the media list on the tv? Does it start and then freeze? Does it stutter? etc;
  • do other mkv files play. If so may pay to post details of one of them for comparison.
  • for mkv's (and mp4 and avi files) MediaInfo can often show better info. Post the output from MediaInfo for the file(s);
  • a detailed log from Serviio may be needed (later)
Post Mon Apr 22, 2013 7:17 am
@DenyAll, I think I'll use your post as a signature now ;) Very complete request.
Users browsing this forum: No registered users and 62 guests
