Upgraded to 1.2.1 - Video Skipping
dempc
Post Tue Apr 23, 2013 3:17 pm
I upgraded to 1.2.1 and now all my HD movies are skipping. I was in the middle of watching Life of Pi.. decided i wanted subtitle support... downloaded and installed 1.2.1 and now my movies stutter and skip.
??? Any suggestions.
I've never had issues with Serviio before. I dedicate all four cores and 4GB ram to the app. Disk space is also not an issue.
Thanks,
JD
slyguy42o
Post Tue Apr 23, 2013 3:34 pm
Re: Upgraded to 1.2.1 - Video Skipping
did you change the sub title options in the serviio console? using the burned in subs option can use alot more resources.
dempc
Post Wed Apr 24, 2013 12:49 am
WOW.... my CPU utilization dropped almost 80% when I unchecked that.. good find.
Skipping still continues, however.
Let me bounce the services and check again.
dempc
Post Wed Apr 24, 2013 1:02 am
slyguy42o wrote:did you change the sub title options in the serviio console? using the burned in subs option can use alot more resources.
So far so good.. thanks for your help!! :D
Users browsing this forum: Baidu [Spider] and 26 guests
